Question about Canon PowerShot A300 Digital Camera
Shutter I can't take pictures or see anything on the display screen except for pics that I had already taken. Everything else seems to be ok. Thanks
  • Anonymous May 26, 2008
    I can't see anything on the display screen except for the pictures I have already taken.
  • Anonymous Jun 10, 2008
    view screen will not focus sometimes
  • 2,016 Answers
Check this link.
Posted on May 20, 2008
CAnnon Powershot A630 LCD screen will not light up when trying to take a pic. I can, however view old pics that I've already taken.
First press the DISP or DISPLAY button to see if that corrects the problem. If not, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 09, 2011 | Canon PowerShot A630 Digital Camera
--cannot view anything to take a picture of--the view screen is black but I can see al menu items and can display settings. Flash works. I can see cannon signal clearly when camera is turned on. I am...
The A6XX series is prone to stuck shutter problems, particularly if the camera isn't used very often. Lens lubricating grease can coagulate on the shutter, immobilizing it. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 29, 2011 | Canon PowerShot A630 Digital Camera
My LCD screen is black. The camera seems to take
its actually probably the display. there is 3 different displays. 1. shows picture with icons 2. shows just the picture and 3. is a solid black screen. just hit the display button to cycle through until your desired display is present
Feb 07, 2010 | Canon PowerShot A620 Digital Camera
Camera works but the screen went black A640 except for video and color swap. Did I press a button? I was shooting in cold weather.
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
But if you've already tried this, have you also tried downloading any of your photos taken with the black screen to your computer? Are the photos also black? If so, you might instead be experieincing a stuck shutter (possibly due to the cold weather).
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Jan 03, 2010 | Canon PowerShot A640 Digital Camera
I have a powershot s3 is and when I turn it on I have no pic. It just started doing this and last time I hit the display button and the pic came up. It will show images of pics that I have already taken....
Nov 08, 2009 | Canon Cameras
Whenever i want to take a picture the screen reamins black
A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 08, 2009 | Nikon COOLPIX L18 Digital Camera
LCD Display Blank
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Jul 31, 2008 | HP Photosmart R607 Digital Camera
Lens
No live view or black pictures, but readable menus means a bad CCD or less likely, possible shutter on cameras equipped with one (more scarce on newer digitals)
Apr 22, 2008 | Sony Cyber-shot DSC-N2 Digital Camera
Camara powers on but will not snap picture!
did you just try to press the shutter button halfway?if yes...press in all the way through...if still does not take a picture..master reset...
-press menu
-press right to go to setup
-go down to reset
-highlight yes then press menu to ok it
-turn off then on then try to take a picture
hope it will help...(",
Dec 26, 2007 | Samsung Digimax S500 Digital Camera
Canon PowerShot A300 Digital Camera Logo
32 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
