Question about Microsoft Excel for PC
Populate a cell based on a specific criteria in Excel
I have excel file with a huge collection of data. Datas are the Business names. Now I want to create new coloumn named "Category" and want to give a category to each Business names. I want to do this automatically specially by a formula or a macro which ever is easy or available.
The data look likes this..
Ristorante L'arca Ristorante
Bellavista Agriturismo
Hotel Ristorante Park Pensione
Mediterraneo Residence.
There are also 4 type of business. Those are
1.Ristorante
2.Agriturismo
3.Pensione
4.Residence
So, you can see that each business name does have its category names at their end.
I just want to populate the Category Coloumn based on this names.
Example
If a Business has a name like::
Ristorante L'arca Ristorante.
Then the respective category should be "Ristorante". I want this to be done automatically.
    Problem Solver:
  • 15 Answers
[formula in the new Category Column]
=RIGHT(A1,LEN(A1)-SEARCH(" ",A1,LEN(A1)-11))
Where A1 is the cell that stores the Business names.
Posted on Jun 02, 2008
Hyperlink other document in excel button
The easy way (but labor intensive) is to put the file names in a column (can be any name you want or the pdf file name), right click on a cell, hit insert hyperlink, and in the address field at bottom, put in the file pdf file name. You would have to do this for each of your 100 files.
If you want to automate it, create a column with the directory path name, a 2nd column with the full file names, a 3rd column where you concatenate the two previous columns to create the full path, and then use the hyperlink command to provide the link:
Folder name Filename Concatenated LINK ../excel/ file1.pdf ../excel/file1.pdf file1.pdf ../excel/ file2.pdf ../excel/file2.pdf file2.pdf ../excel/ file3.pdf ../excel/file3.pdf file3.pdf
Here are the formulas behind this:
A B C D Folder name Filename Concatenated LINK ../excel/ file1.pdf =CONCATENATE(A2,B2) =HYPERLINK((C2),B2)
../excel/ file2.pdf =CONCATENATE(A3,B3) =HYPERLINK((C3),B3)
../excel/ file3.pdf =CONCATENATE(A4,B4) =HYPERLINK((C4),B4)
This should work like a charm and the other advantage is that excel won't rename your path locally depending on weather a file is open or not).
Feb 21, 2014 | Microsoft Excel for PC
Size of the excel file increased from 721 KB to 50MB
Many businesses use Excel to track their data and expenses.
However, you can run into problems when files grow too big.
Try reducing the size of your Excel files in different ways to eliminate your storage problems.
Remove unnecessary graphics and fonts from the Excel file.
Simple report data doesn't need a lot of excess formatting to make it attractive.
If you need to keep different fonts in your file, reduce some of the font sizes you originally used.
Reduce the number of pivot tables you allow in your data analysis.
Run your pivot table wizard when dealing with involved calculations.
When given options to format the file, choose those that allow the data to refresh instead of adding a new table.
Input your data, close the file and save as an Excel (XLS format) file and as an HTML (XML format) file.
To do this, choose "XML Data" in the "Save as type" drop down box.
Change the name of your document as well, so you can tell the difference between the two files.
Open the XML file and save it back into the regular XLS file to create a smaller file than the original.
Again, rename this file, as well as changing its type. This act removes odd programming left from past calculations since the last "save."
Check into file compression software such as OzGrid.
These products exist because you cannot open a file once it gets too big.
Compress the XLS data by compelling the program to recalculate the cells used for your file.
Excel File Size Reduce Software 7.0
http://www.newfreedownloads.com/Business/Spreadsheets/Excel-File-Size-Reduce-Software.html
http://www.ozgrid.com/
or
Microsoft Excel files can contain thousands of cells filled with data.
When you combine this information with graphics, such as charts and graphs, as well as ever-expanding links to other worksheets, you can end up with an enormous file that takes up precious system space and slows Excel down.
While there are many software programs available that promise to shrink Excel files, there are many ways to reduce the bulk without downloading a new application.
1. Click on any cell in the Excel file you want to reduce.
Open the "Go To" dialog box in Excel 2007 by clicking the "Find" drop-down arrow on the Home tab of the ribbon and selecting "Go To."
In Excel 2003 or earlier, go to the "Edit" menu and select "Go To."
You can also use the keyboard shortcut "Ctrl+G" in any version of Excel.
2. Click the "Special" button on the "Go To" dialog box.
Select "Blanks" and click "OK." Click the "Clear" drop-down in the "Editing" group in Excel 2007 and select "Clear All."
In Excel 2003 or earlier, go to the "Edit" menu, point to "Clear" and select "All." This will clear any blank cells to help reduce the file size.
3. Go to the very last cell containing data in the Excel file.
Select the entire row beneath this cell by clicking the number to the left of it.
Hold "Ctrl+Shift" and then press the down arrow key to select all of the cells beneath this point.
4. Click the "Clear" drop-down in the "Editing" group in Excel 2007 and select "Clear All."
Select the column to the right of the last cell. Hold "Ctrl+Shift" and then press the right arrow key. Again, select "Clear All."
5. Repeat Steps 1 through 5 for any other Excel files that are linked to the workbook you are trying to reduce.
Save the files and then check the new file size by clicking the "Office Button" in Excel 2007.
Point to "Prepare" and then click on "Properties." In Excel 2003 or earlier, go to the "File" menu and select "Properties."
The file size will be listed on the "General" tab.
http://www.ozgrid.com/Excel/ExcelProblems.htm
Apr 22, 2013 | Microsoft Office Professional 2010
Reduce the size of excel file
or
Apr 22, 2013 | Microsoft Office Computers & Internet
Dear Sir, In case there are atleast 80 files or more having same format containing datas in columns in each file with different figures, I want to merge all file in a single sheet in one shot. Kindly...
If the column names and orders are same across files, then you can directly use the MS Excel's import data function, this will do your job.
Alternatively, if you want to do it manually, import each file in separate excel worksheet using data import wizard or simple copy paste of data (in latter case you have to use Text-to-Col feature of excel), and then manually append all figures (copy-paste in one go) to any external excel sheet.
Then finally, export/save as that external sheet to any filename of your choice.
Hope this helps.
Thanks.
Mar 24, 2009 | Microsoft Excel for PC
How to convert Excel data in to Tally a accounting software
Select ASCII. Give output file name Eg:d:/exp Open the file using EXcel.Select Delimite  nexxt comma finish.Export is completed or You can do 2 things , first you could export as text and import it back to excel using the text file you created , secondly you can select HTML and give the file name as eg-XYZ.xls
or Try using UDIMagic Free Edition to Export Tally data. Download it fromhttp://www.rtslink.com/images/udimagic-free-edition-setup.zip
Jan 06, 2009 | Microsoft Excel for PC
Invoice & Order Minimize Data Entry - Especially Name and Address
Do you have Microsoft Access? If so, you could use that to create a database and an invoice form. You could also use Access to "dump" the info into Excel to track and record.
Otherwise, try searching for "Import Data" in the Excel help. It would be very difficult to walk you through the whole process, but if you have specific questions about certain steps, that would be more manageable.
How to convert exel file to foxpro file
You can import the Foxpro file after you've used the DataConnection Wizard. You'll find this under the Data tab in Excel 2007 - under Get External Data section and click on From Other Sources
http://office.microsoft.com/en-us/excel/HP102017101033.aspx?pid=CH100648471033#Importing%20data%20by%20using%20the%20Data%20Connection%20Wizard
Aug 04, 2008 | Microsoft Excel for PC
Excel Formula
Lets say your data (cars) is in range "D1:D21".
You need to know how many are Dodge and Ford in cell E1.
=COUNTIF(D1:D21,"Dodge") + COUNTIF(D1:D21,"Ford)
Hope this helps.
Apr 22, 2008 | Microsoft Excel for PC
Export data in excel shld yoeet through VB
When i first figured out how to pull data from SQL and put the results in an excel file i referenced these two articles....
Reading and writing excel file using VB.NET (http://www.codeproject.com/KB/vb/Work_with_Excel__VBNET_.aspx)
Get the Values From DataBase and Stored into excell Sheet (http://www.codeproject.com/KB/vb/Getvaluesfromdatabase.aspx)
This is the code i ended up using.... (check out those links to see how you need to import the ms office excel reference file with visual basic)
Const stcon As String = "Provider=SQLNCLI;server=xxxxx;database=xxxxx;uid=xxxxx;pwd=xxxxx;DataTypeCompatibility=80"
Dim stSQL As String = "select * from scs_rate_class_money where irate_book = 124 and snew_used = 'U' and sclass = '2' and splan = 'T4' and sopt_code = 'F1'"
Dim cnt As New ADODB.Connection
Dim rst As New ADODB.Recordset
Dim fld As ADODB.Field
'Open the connection.
cnt.Open(stcon)
'Open the recordset.
With rst
.CursorLocation = ADODB.CursorLocationEnum.adUseClient
.Open(stSQL, cnt, ADODB.CursorTypeEnum.adOpenForwardOnly, _
ADODB.LockTypeEnum.adLockReadOnly , _
ADODB.CommandTypeEnum.adCmdText)
.ActiveConnection = Nothing 'Disconnect the Recordset.
End With
'Close the connection
cnt.Close ()
Dim exp As Export = New Export()
Dim xlApp As New Microsoft.Office.Interop.Excel.Application
Dim xlWBook As Microsoft.Office.Interop.Excel.Workbook = xlApp.Workbooks.Add(Microsoft.Office.Interop.Excel.XlWBATemplate.xlWBATWorksheet )
Dim xlWSheet As Microsoft.Office.Interop.Excel.Worksheet = CType(xlWBook.Worksheets(1), Microsoft.Office.Interop.Excel.Worksheet)
Dim xlRange As Microsoft.Office.Interop.Excel.Range = CType(xlWSheet, Microsoft.Office.Interop.Excel.Worksheet).Range("A2")
Dim xlCalc As Microsoft.Office.Interop.Excel.XlCalculation
Dim i As Short
'Turn off Excel's calculation.
With xlApp
xlCalc = .Calculation
.Calculation = Microsoft.Office.Interop.Excel.XlCalculation.xlCalculationManual
End With
'Write the fieldnames.
For Each fld In rst.Fields
xlRange.Offset(0, i).Value = fld.Name
i = i + 1
Next
'Populate the range.
xlRange.Offset(1, 0).CopyFromRecordset(rst)
'Close the recordset.
rst.Close()
'Make Excel available to the user.
With xlApp
.Visible = True
.UserControl = True
'Restore the calculation mode.
.Calculation = xlCalc
End With
'Release variables from memory.
fld = Nothing
rst = Nothing
cnt = Nothing
xlRange = Nothing
xlWSheet = Nothing
xlWBook = Nothing
xlApp = Nothing
Jan 03, 2008 | Computers & Internet
Running SQL queries on Excel
Another way to do it is to use the SQL Drill freeware Excel addin (http://www.sqldrill.com)
hth
Aug 14, 2007 | Microsoft Office 2003 Basic Edition...
Open Questions:
See all Microsoft Excel for PC Questions
Microsoft Excel for PC Logo
135 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
