Question about Thorens TD-170 Turntable
Turntable must be started by hand
When I throw the switch to start, nothing happens and I must revolve the platter by hand to get the machine working. Doing this also causes the tone arm to travel about 85% the way through its travel. The machine was purchased new about seven years ago and has been used infrequently.
    New Friend:
    Problem Solver:
  • 18 Answers
There is only one place for Thorens repair that I trust. Trained and mentored by the original swiss technicians on the correct Thorens specifications and traditional procedures, their company. STS Turntables is hands down the worlds best.
Posted on Nov 25, 2014
  • 1,342 Answers
  • 555 Answers
This sounds like the stepper motor that drives the turntable is failing. Are there any good DJ shops near to you?
Posted on May 20, 2008
Why did it stop revolving?
The driving element, be it belt or rubber puck, may have failed. It's not an unusual failure in a turntable that is several years old and rarely used.
Jan 08, 2016 | Audio Players & Recorders
When I push start button turntable doesn't rotate
Technics SL-QD33 doesn't turn - Vinyl Engine
Jun 3, 2010 - 15 posts - ‎3 authors
It powers up, lights come on but the platter won't spin. ... However when I press "start", nothing happens and the platter won't spin when ... the arm towards the record without pressing the "start" button. ... SL 7, SL-10... and / or any of the fully automatic Technics turntables using optical record detection......etc Marantz 6300 question...
Nov 21, 2009
Dual CS505 turntable won't auto-start
Aug 16, 2009
More results from
Help!! My Turntable won't spin - AVS Forum ' Home Theater ...
18 posts - ‎7 authors
Dec 21, 2015 | Audio Players & Recorders
I recently took my turntable out of the box after being in there for years because someone wanted to buy it, but it dose not work.
If the turntable is a belt drive, most likely the belt has probably disintegrated due to ozone contamination over time and must be replaced if this is the case. Once you have the platter off you can see the spindle that drives the platter to see if it is moving.
Nov 22, 2014 | Audio Players & Recorders
Arm not working. Stop/start light flashes red instead of staying solid
Don't try and force anything that won't move. Try this. With the power unplugged, place the tonearm over the record, if it will move freely, while rotating the platter by hand. Move the tonearm slowly over the surface of the platter until the end. Continue turning the platter by hand and see if the tonearm picks up and returns to the rest. See if that fixes your issue. For more information or further questions, please visit my website at Thank you.
Dec 09, 2013 | Technics Audio Players & Recorders
Received a Numark TT usb back in 2007. Just plugged it in for the first time ever. Installed EZ Converter on my powerbook, was all psyched to get going. The turntable powers on, but nothing happens when I...
Try moving the tone arm lever to raise the arm, if it has one.(MAKE SURE YOU HAVE RELEASED THE ARM CLIP!) Then with the arm raised move the arm over towards the platter. If platter still doesn't rotate, and its a belt drive, A. The belt is bad. or B. The belt has come off the platter or motor pulley.
Jul 31, 2011 | Numark ttUSB Turntable
How do I remove the turntable platter from the ion ittusb05 turntable?. The belt is dislodged and the platter will not revolve.
Lift the rubber mat off the platter and notice the two large holes for your fingers to fit into. Simply lift the platter off the base by pulling.
Oct 07, 2010 | RCA ION-ITTUSB05 Turntable
JVC - problem. The turntable does not move,
Most modern day turntables are semi-automatic. You move the tonearm from the rest post
over to the record and the platter will start turning. There is a small microswitch inside
either below the arm base or near. There should be a flat bar connected to the base of the arm
and this will actuate the microswitch. The switch is wired in series to the rotation motor.
Solution: 1. Obviously verify the belt is on. Take off the rubber mat and rotate the platter.
The rotation motor is on the left and it has a small brass spindle. The belt should
be visable through the holes in the platter. If not pull the platter gently up, there will
be some resistance. The belt wraps around a smaller inner ring on the underside
of the platter and the rotation motor spindle. If it is degraded it will be stuck to the
platter or fall apart. Generally there 3 common sizes. ( 21.4 / 23.6 / 25 inch) they
readily available on E-Bay, search term "turntable belt".
2. Obviously check power.
3. Check the microswitch, it should "click", verify with ohm meter.
4. Some turntables have a "cut" or stop function. The arm must return first to rest before
starting again, again the microswitch is the trigger.
Apr 07, 2009 | JVC AL A158BK Turntable
Stanton ST150 turntable won't spin
Hello DeKay,
I just had a spindle lock issue this past Sunday at my gig. I had the turntables out in my car and brought them in. I let then warm up for 2hrs before plugging them in.
Everything was good. Then mid set my right side turntable started spinning really fast and then DEAD STOP.
I was pushing the platter and it really hard to turn. I took off the platter and tried to turn it with my hand. It was dead locked, WTF?!!
So I limped through with one turntables since I use Traktor Scratch Pro and made it through the whole night successfully.
I searched the net and it was suggested to lubricate the 1200 spindle with 15W40 motor oil. Since the motor design is indentical, I picked up some 10W40 motor oil since I couldn't find 15W40.
I oiled both turntables to be on the safe since. I tapped the spindle on the locked turntable to help loosen it.
I drove back home which is pretty much an hour drive and let the tables sit for another 2 hrs.
I decided to grab a thick towel and vice grips to work on the locked spindle.
Clamping down on the towel with the vice grips on the brass fitting for the platter I was able to free the spindle quite easily.
I was then able to turn it by hands so I did in both forward and reverse directions to work the oil down into the spindle bearings.
I put the platter back on and spun it manually to check for resistance, it was spinning nicely!
Plugged in the turntable, set the pitch at 0 and watched the stobe dots. There was no waver in the strobe dots. YAAAAAAAY!
My turntable is back to new and since I only use them on the road they stay stored most of the time.
So I would suggest just oiling the spindles every so often to keep them tip top.
Hope this helps you!
DJ Quartz
Nov 06, 2008 | Stanton ST-150 Turntable
Technics sl 1210 will not start up
did you ever open the turntable. It sounds like the on/off switch is bad. Remove the platter and screws with a phillips screw driver and just make sure the connections are in place. make sure you disconnect the power first. let me know what happens afterwards.
May 24, 2008 | Technics SL-1210 Turntable
Nothing happen when pressing the Start/Stop button.
One ov my decks (same Gemini PT-1000 II) had the same problem. Just open it and clean the micro switches underneath the big buttons. It worked fine for me.
Apr 11, 2008 | Gemini PT-1000 II Turntable
Thorens TD-170 Turntable Logo
587 people viewed this question
Top Thorens Audio Players & Recorders Experts
Ben Armstrong
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Thorens Audio Player and Recorder Expert? Answer questions, earn points and help others
