Amana ALW540RA Top Load Washer
Problem for Amana ALW540RA Top Load Washer
Leaking washing machine
By Jan1464 on May 20, 2008
Washing machine (6 yrs old) has been leaking water onto the floor. Removed front pannel found rusty looking residue on the backside and around the inside on the bottom drip pan. While in the spin cycle can see a slow drip on front of motor housing. I'm guessing the pump needs to be replaced if so, where can I find step-by-step instructions to replace pump. Thanks! Jan
Best Solution
posted on Jun 17, 2008
Helpful)
Lumpy816
Rank: Guru
Rating: 93%, 279 votes
Jan, if your pump needs to be replaced, I haven't seen a step by step instruction on it so far, so I hope this will do. First Unplug the machine and remove the remaining water from inside of it.(even after the spin cycle, water remains inside the bottom of the tub, the pump and the drain hose) The easiest way to do this is using a wet /dry vac, attaching it to the end of the drain hose that goes into the wall and sucking the remaining water out. Next pull the unit forward and tilt the top of it back about 45 degrees. (when you have it tipped back far enough, the top will rest against the wall behind the machine instead of tipping forward) Remove the belt from the pulleys underneath the machine. Remove the 3 bolts holding the pump to the base of the machine. Use a pair or pliers or channel locks to remove the clamps on the hoses attached to the pump. Install the replacment pump you've purchased from a local appliance parts sttore or bought from the manufactures web site on line by reversing the process. Run a quick fill/ spinto make sure you have no leaks.
Was this helpful?
Yes
No
Popular Solutions for Amana ALW540RA Top Load Washer
Questions and Unsolved Problems for Amana ALW540RA Top Load Washer
Do you recommend Amana ALW540RA Top Load Washer?
Answer
Answer
water will not spin out with a full load of towels is it the belt slipping?
Answer
agitates and spins only in gentle cycle. Timer?
Answer
The door lock will not unlatch and no water will run into the machine and it makes a funny noise
Answer
Our amana top load washer just smelled like burning belt in a big way. I drained the water and took... (More)
Answer
Our belt on this washer went out and we ordered a new belt. We are now trying to put the new belt on... (More)
Describe your Washing Machines problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
