Question about Microsoft Zune JS8-00001 Digital Media Player
Zune symbol flashes while trying to charge
I have a problem with my Zune that use to work but I left it outside. I tried to charge it but it just flashes the Zune symbol when I plug it in. I figured that if it were fried, it wouldn't get that far. Would this be accurate? How can I fix it?
  • Anonymous Jan 16, 2009
    unable to switch off also
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If this fails, then there is a hardware issue that cannot be resolved without replacement.
Posted on May 26, 2008
My Zune 4gb won't sync with my software and will not charge
I had a similar problem with my 30GB Zune. The first normal solution is to make sure that the USB port is providing enough power to the Zune to charge it by trying a different port or computer, but since your other Zune charges it is likely not the problem.
Other possibly solutions are performing a hard reset on the Zune (hold back and up until it resets), or allowing the zone to completely discharge and try again. In my case, none of these solutions worked and I was forced to send my Zune in for a new battery, which Microsoft was willing to replace for free.
Jul 29, 2009 | Microsoft Zune JS8-00001 Digital Media...
Zune won't respond to any key presses.
I would first allow the Zune to completely charge (the battery symbol should be full and green[i believe--it's been a while since I first got mine]).
I would then unplug the device and restart the computer. Once your computer has completely rebooted connect the device to the computer and see if it detects the device. It should work. Also you might try another USB port.
Jun 07, 2009 | Microsoft Zune JS8-00001 Digital Media...
My Zune 30GB Is Menuless...
Try this....
Reset Zune: Press and hold the back button while pressing up on the control pad.
Connect Zune to a power source: If the Zune device is in sleep mode, this action will wake the Zune device and turn it on. If the battery does not have a charge, you may have to wait several minutes for the Zune device to turn on.
Also, make sure that the hold button on top of your zune is turned to the off position.
Hope this helps!
May 08, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My zune just stopped working
run the battery completey dead or you could possibly reset the device to factory default...
Try this....
Hope this helps!
Mar 22, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My zune won't turn on
Check the Lock button. Push it all the way to the right, then all the way to the left. I'm continually having to do that w/ mine, even when the orange Lock symbol ain't showing.
What do you mean by "tried to reset it"? By holding the Back button (on the left) and pressing the top of the Control Pad until you get the Zune logo?
Try these steps. They may work.
Mar 04, 2009 | Microsoft Zune JS8-00001 Digital Media...
Zune 80 GB - Won't Charge
i lost my drivers microsoft lifecam vx-1000
Feb 07, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune freezes on black screen
I just had this problem. Try an emergency restart. Hold down the <- arrow button (the button on the left) while pressing the up button on the pad. Hold untill it until the zune symbol comes on screen. Hopefully that will fix it, thats what I did...
Jan 14, 2009 | Microsoft Zune JS8-00001 Digital Media...
Zune won't charge
now what you do is if the zune just has a black screen with a battery symbol and it stays that way forever when on the charger. you, take the zune off the charger and press the play/pause button and if it turns on for a second with the low battery symbol then turns off, your in luck, just hold the play/pause button for 10 - 20 minutes. the zune will have turned on and off alot agitating the battery. once you hold it for 10 - 20 minutes put it on the charger, then presto it works. let charge fully then die completly for every time you use it for a bout a month to let the battery get back into it's normal cycle. ~Dan herzberg~ Thank you*
Feb 18, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Mirosoft zune froze up
To restart the Zune device, follow these steps: 1. Set the Hold switch to the unlocked position. Note To make sure that the Hold switch is in the unlocked position, you may have to move the switch back and forth until the switch is in the correct position. 2. Press and hold the Back button zune_button_back.gif while you press the top of the Zune pad
Dec 26, 2007 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Battery crash on installation
it is either the sync cable or where the sync cable plugs in, i had the same problem myself i had to take it back and exchange it
Sep 01, 2007 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Microsoft Zune JS8-00001 Digital Media Player Logo
399 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
Mister Danger
Will Mishler
Will Mishler
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
