Question about Indesit Washing Machines
When i turn my washing machine on the door lock light and the extra rinse light both flash quickly. my model is the wil1235 1200 thanks
Door lock and extra rinse light flashes
is it the tub that clunks?was it very noisy in the spin cycle?if so the spider gear is gone and it would be cheaper to replace the should only be adding two tablespoons of soap that's it,alot of people use to much soap and it eats at the spider gear,if you look inside the tub at the back wall you'll see a piece sign,that's the gear located on the back of the tub
Nov 09, 2017 | Washing Machines
WIDL126 flashing light No3 extra rinse). Machine starts to fill with water then the drum spins twice (a little too fast I think), then drains and just stops and the door lock light flashes fast along with...
If spin speed happening during what should be Wash speed then sounds like faulty speed control module/ could also be Tacho has fallen off end of motor;small round coil operated by a magnet which pulses a speed control circuit in the module/check also pump is okay and filter clean.Try resetting if you can,book will show you how to..Good luck
Apr 07, 2011 | Indesit Washing Machines
Quick Rinse light was flashing at end of cycle. Opened and closed door and pushed Start. Quick Rinse and Cancel/Drain light are now flashing and machine won't start. Turned off power supply (30 seconds) /...
Ok try this, open the door and then hit these buttons in the following combination. HI TEMP - DRY - HI TEMP - DRY...then close door and press cancel...then wait for the pump to shut down. you should be able to run a cycle after this...If this fails to fix the problem give me the make and model # of the dishwasher, this can normally be found just inside the door.
Jun 22, 2009 | Dishwashers
Unusual display on panel (padlock) machine can't be programmed door is not locked however
i just went through the same need to hold the option and extra rinse buttons simultaneously for 6 seconds, this will unlock turn the machine on and press the two icons, dont worry about the beeping and flashing after 6 seconds the padlock symbol will go and you can use the machine as usual.....i wish they put that 'minor detail' in the manual...cheers!!
May 31, 2009 | Electrolux EW1000i Front Load Washer
revisar el nivel puesto que las lav tienen un sistema de anti bibracion que el cual la detiene
Aug 05, 2008 | Washing Machines
Indesit washing machine
washing machine working until final drain, rinse and spin then 3 lights flashing, door lock, stain removal and extra spin.
Unable to empty machine or unlock door.
any suggestions
May 15, 2008 | Washing Machines
Indesit WIL143S flashing lights
sounds like your power board is damaged. Did you get any washes out of it before it went wrong
Oct 08, 2007 | Washing Machines
Washing Machines Logo
530 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
