Question about Microsoft Windows Vista Ultimate Edition
Soundcard my sound card is not working properly it ony play 2 speakers and a sub but its a 5.1 when i am using xp sp2 my speakers are playing but vista is not working
  • 407 Answers
You u change sound driver properties then setup it ...restart your pc .
Posted on May 21, 2008
Sound only coming from 3 of 6 speakers
A 5.1 sound card will give output in all channels only if the audio being played is also 5.1.
Normally out of 6 Speakers only 2 front and sub woofer will play sound, in case of a DVD or Movie which has 5.1 encoding, all 5 will come alive.
Also, Dolby Prologic II and Dolby Digital will convert a 2 channel input into psudo 5.1 enviornment but Dolby has to be in hardware or speakers or Receiver.
Jan 21, 2014 | Creative Labs MegaWorks THX 550 Computer...
No sound upon installing E-MU 0404 pci card and driver
Hey ya'll.
I had the same problem with everything installed,icons on the screen etc...I took my stuff to my computer wizard and he came with the following solution which is:
Make sure that you have a Windows XP "SP2 or GREATER" this is the kicker.Go to the requirements sheet if you need more info.
Anyway I did that upgrade from SP1 to SP2 and it works like a charm with pristine sound.
Good luck fellows.
monsieur M.
Mar 18, 2009 | E-Mu 0404 Sound Card
Software to install the soundcard
my soundcard not working after i format n finish installing windows xp
Nov 28, 2008 | Intel Premier Resources 4-Channel 32-Bit...
Windows Media Player cannot play the file because there is a problem with your sound device. There might not be a sound device installed on your computer, it might be in use by another program, or it might...
I have an Fujitsu Siemens Amilo D7830. I was updating chipsets to the laptop when it bluescreened. I had to reformat the HDD and reinstalled Windows Xp Pro SP2. Since then I have installed every conceivable Windows Update file there is and have updated all other drivers and chipsets. However, my soundcard is no longer working.
When clicking on the device in question in the device management screen, the following error messages are displayed for the Realtek AC'97 soundcard: This device cannot start. (Code 10), PCI bus 0, device 31, function 5.
I have attempted at downloading and installing almost every drive I can find for this device, and have followed the standard Microsoft help routines. i.e. uninstalling the device and reinstalling the device still with no luck.
I hope you will be able to assist, as my last resort will be to take it into the a techie shop i.e. PC World for them to have a look at it.
Kind regards,
Sean
Sep 28, 2008 | Audio Players & Recorders
5.1 surround not working
I uninstalled the previous audio software that the computer had. (Realtek HD audio) and turned off the onboard sound card in the BIOS settings. Then I went back and uninstalled all the new audio software and reinstalled it with all antivirus programs turned off. The main trick was to make sure that the matrix is turned off. If it is on it will play sound from all the speakers at once as if it were mono. Turning it off after changing the BIOS and uninstalling the old software and reinstalling the new allowed it to work properly. I hope this helps.
Sep 10, 2008 | Logitech Z-5300 Computer Speakers
Sound
hi sirs or mrs
this prob that u have maybe it s the cords are cuted inside the speackers by checking . so that i advice u to take them to some responsible person for make it
Aug 17, 2008 | Audio Players & Recorders
Sound from 4 speakers cut off..
To troubleshoot a speaker system where sound is not issuing from all speakers, please do the following:
  1. Verify that all cables are plugged in correctly. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the center/sub audio port is orange. If you do not have a surround sound card, make sure you obtain the proper adapter (discussed in the next paragraph) or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details.
  2. Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. For 5.1 systems, the card should have a front, rear, and center/sub, output. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, you can use the source selector switch or the M3D button on the controller unit (if available). You can also use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound.
  3. Try connecting the speakers to a portable sound device such as a walkman or portable CD player. Plug the speakers into the headphone jack, but make sure the volume is lowered so the speakers are not over powered. You can do this for both the front, rear, center/sub speakers to verify that they work. If the speaker system works on the walkman, then you are experiencing a configuration issue with your sound card. Please contact your sound card manufacturer.
  4. Check the system Volume Control located in the System tray. Make sure that the volumes are at a reasonable level and are not checked for Muting.
Try these articles as well:
Manual
Setting up the Z5500 with PC, Mac, Xbox, Playstation, DVD Player, etc.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
May 20, 2008 | Logitech Z-5500 Computer Speakers
No Sound
it may look fine, but i think there is some trouble with the installation of motherboard on the new case take a review on it.
it happened to me before.I just reinstall it to the new nase and chechk for any lose connection or any busted chips. in that case try some new motherboard
Apr 07, 2008 | ASUS P4C800 Deluxe Motherboard
Laptop speaker
You need to install the drivers for your soundcard. Try to find out what model of soundcard do you have and what version of Windows and try to search for the specific driver on the internet.
You can try these websites:
http://www.driverguide.com/
http://www.soft32.com/c/Windows/Drivers/2-52.html
Here's a tutorial on how to install a driver: http://www.totallydrivers.com/resources/directions_installation.asp
If you still can't hear sound try these steps, maybe it's not from your soundcard:
-Plug in the speakers
-Turn on the speakers.
-Turn-up the volume in Windows and on the speakers.
-Uncheck the mute checkbox in sound control panel.
-Verify a sound should be playing. In the Control Panel, play some Windows sounds. Play a music CD.
-Plug the speakers into the right hole on the sound card.
-Are the speakers plugged into the sound card and not the MODEM?
-Is the sound card installed correctly?
-Is the power converter for the speakers plugged into a wall outlet or surge protector?
-Is the power converter plugged into the speakers?
-Try other speakers or a head phone?
Jan 27, 2008 | Compaq Presario 700 470024-192 Notebook
Playing MPEG's
* The MPEG Playback function works in M. PLAY mode only. * You can play moving picture images on the Memory Card. * To hear sound during MPEG4 playback, you must hook up to a PC and listen to the PC's speaker. (You cannot hear it from the speaker on the camcorder or a TV) 1. Set the mode switch to MEMORY CARD position. 2. Set the power switch to PLAYER mode. 3. Press the MENU button and turn the MENU DIAL to highlight MEMORY. 4. Press the ENTER button to enter sub-menu. 5. Use the MENU DIAL to select MPEG4 from the sub-menu. (M. PLAY SELECT) 6. To exit the menu, push the MENU button. 7. Using the (FWD) and (REV) buttons, search for the moving picture that you want to playback. 8. Press the PLAY/STILL button. The moving pictures recorded on the MEMORY CARD begin playing back.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Microsoft Windows Vista Ultimate Edition Logo
63 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
