Question about Logitech Cordless Desktop EX110
Progaming function keys
On my logitech ex110 keyboard i need to program my email key to look at my current outlook 2003,and not pick up a new version
    President:
  • 8,637 Answers
Normal 0 Go to Control Panel.
1. Click on Keyboard.
2. When the Keyboard Properties come up, CLICK on Key Settings.
3. Then set up the keys by selecting the Key to be changed.
Hope this will help some. Bud
Posted on Jan 20, 2009
I have a Logitech cordless ex110 keyboard that I would like to find an online manual for....I have no idea what the 'F' keys do and every once in a while I hit something (?) that converts my /,...
Did you install the Logitech Set Point software? If you did, you can edit the Function key assignments by opening that program. There are other ways to change your keyboard settings, pressing Left Alt and Shift can do this with Windows 7 by default. To check this in Windows 7, click Start > Control Panel. Under Clock, Language, and Region select Change Keyboard or other Input method. Once that window opens, click on the Keyboards and Languages tab and click Change Keyboards. Then select the Advanced Key Settings tab. There is a section marked Hot Keys for Input Language.
The manual and other documentation for the Logitech ex110 is available here: http://www.logitech.com/en-us/433/154?selectedcrid=433&selectedcid=154&WT.z_sp=Product&osid=&bit= .
I hope this helps.
May 20, 2011 | Logitech Computers & Internet
How do I progam the programmable keys
I was going to type this out but found the help on logitec is pictorial and might make more sense ;-]
Q: Customizing my S 510 Keyboard Function Keys with Logitech software (SetPoint) trnsp.gif 1954.1.0.jpg How do I use Logitech's Mouse and Keyboard software (SetPoint) to customize my S 510 keyboard Function Keys?
Cordless Desktop S 510
Model Number:
Y-RAK73 (Keyboard)
M-RBN114 or M-RBG114 (Mouse)
trnsp.gif The Function Keys, or F-Keys, are the keys on labelled F1 through F12 above the number keys.
NOTE: To use the programmed F-Key, make sure to toggle on Enhanced F Keys Mode by pressing the F Mode key. The F Mode LED on the receiver will be off in Enhanced F Keys Mode.
11994.1.0.jpg Similar to the Programmable Keys, the F-Keys can also be programmed to perform certain functions.
  1. Click the My Keyboard tab on the top of the screen and select the Keyboard F Key Settings tab on the left.
  2. Select the F key you wish to customize.
  3. Now select the task you want the button to perform under Select Task. You can also click Help to find detailed descriptions of these options.
  4. Click on Apply then click on OK to close SetPoint.
May 04, 2010 | Logitech Cordless Desktop S 510
How do I program the home key in upper right corner of keyboard?
You don't program it, it is a standard key on a keyboard. If you are scrolling or something and want to return to the top you just hit the home key.
Thanks,
Lee
Mar 25, 2010 | Logitech Cordless Desktop EX110
When i use the right shift key it does not capitalize the letter but brings menus up
http://www.logitech.com/index.cfm/433/154&hub=1&cl=in,en?section=downloads&bit=&osid=14
There's all the info at the link above.
Also try Holding the CTRL key and push the right shift key.......this keyboard has layered functions, it seems.
Mar 04, 2010 | Logitech Cordless Desktop EX110 Keyboard
F keys suddenly not working
The "F mode" button toggles on and off the F keys. If you press it (accidentally) as I did, the keys will no longer function.
Simply press the "F mode" key again (it is directly above the "End->" key between F12 and Insert on this model keyboard) and functionality will be restored.
Apr 08, 2009 | Logitech Computers & Internet
My Logitech EX110 wireless keyboard has no light indicators for CAPS LOCK and NUM LOCK. Should it have those indicators?
Your EX 110 receiver has 3 indicator lights (LEDs) that display the status of the Caps lock, Function key, and the Num lock during normal operating mode. These lights will also flash when the connect button on the receiver is pressed.
LED A: Indicates that the Caps Lock (Capital lock) key is on when lit.
LED F: Indicates that the F keys are in Standard F Keys Mode when lit and in Enhanced F Keys Mode when the LED is off.
  • Your EX 110 keyboard has an Enhanced F Keys Mode for F keys that provides additional functions you can program. See Knowledge Base article 9526.
LED 1: Indicates when the Num Lock (Number lock) key is on. This function allows the number pad to produce only numbers
Mar 27, 2009 | Logitech EX110 SP CORDLESS Keyboard/Mouse
I need to program my email key to look at my current outlook 2003,and not pick up a new version
The steps for configuring keyboard drivers in Windows XP are different than in other operating systems. Use the following steps if you have already downloaded and installed the latest HP keyboard driver for Windows XP. Step 1: Configure Internet and shortcut buttons
  1. Click Start , and then Control Panel .
  2. Click Printers and Other Hardware and then Keyboard or click Keyboard if you are in Classic view. The Keyboard Properties window appears.
  3. Click the Buttons tab. You will see a list of Internet and shortcut buttons.
  4. Double-click the button you want to configure (such as, CONNECT or Internet).
  5. Configure the button to open a Web page or software. The figure and table below explain how to use each field in the Configuration window.
  6. After you have made your changes to the button's configuration, click OK .
  7. On the Keyboard Properties window, click Apply .
  8. Repeat the previous steps for each button you want to configure.
  9. After you have configured the buttons, click OK on the Keyboard Properties window.
May 20, 2008 | Computers & Internet
Problems with Logitech keyboard
Install the software on the CD that came with the keyboard.
The program will allow you to edit what the three keys on the top right do and the special F keys.
If you don't have the CD google
EX110 Software or EX110 Drivers
Nov 10, 2007 | Logitech Cordless Desktop EX110
Logitech Cordless Desktop EX110 Logo
122 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
