Question about Philips Magnavox 9P6034C 60" Rear Projection Television
9p6031c103 power light on the front comes on but the unit itself will not power up.
  • Anonymous May 25, 2008
    turn on tv no pic and no sound power light stays on
  • Anonymous Mar 17, 2009
    I have the same problem can anyone help me and the other guy plez
  • Philips Master
  • 3,459 Answers
I had the same exact same problem. You can get a repair kit from this site. http:///www.magnavoxhelp.com
Posted on Jun 21, 2008
Philips Magnavox 9P6031C103 projection tv quit working 2 years ago (before, the picture began to shink and expand until it finally quit completely with no audio nor video -- turned it on two years later to...
Based on what you described I would say your TV has the "shrinking and expanding" fault. Its a common problem on that model and the symptoms can range from the video shrinking and expanding or no video or no audio....You can read more about this fix on the site www.TvRepairKits.com
Jan 13, 2013 | Philips Magnavox 9P6034C 60" Rear...
Buzzing with no picture
If the lights on the front of the unit are flashing(remote light) then the bulb may have blown. I had the same problem with a panasonic. Bulbs are about 50 bucks
Oct 23, 2012 | Toshiba 62HMX84 62" Rear Projection HDTV
At first the tv picture would shrink then get back larger. Now the power green light is on, but the screen is black.
I had the same problem. After doing some research here I went to www.tvrepairkits.com and I ordered this kit: (TV-KIT-001-9P6031C103) Philips Magnavox 9P6031C103 Shrinking & Expanding Video Or No Video Kit. It costs about $53.00 plus about $12.00 freight.
According to the research and discussions this should fix the problem.
Jul 03, 2011 | Philips Magnavox 9P6034C 60" Rear...
My samsung DVR 4 channel will not turn on. There is a red light in the rear inside, but the unit itself will not come on. I noticed a beeping sound coming from the unit every 10 minutes or so.
Will it show any lights on the front display at all? If there are no front light, then there may be a power problem, try plugging the unit into another socket and if the red light inside the unit returns and wont display anything else the I suspect that it may be a burnt out power pack, which will need to be replaced by a service technician due to the high voltages with power sources.
Hope this has helped :D
Any more questions please just ask!
Nov 23, 2010 | Samsung 4 Channel Dvr
I have a brother 2140, I have replaced the toner car, the yellow light still comes on and the printer will not print
Remove toner/drum unit, remove toner by itself...remember to shake the toner right-left to loosen the toner before putting back in the unit. To reset the printer before you replace the toner/drum, and with the front door still open, hold the GO-Control button down until all lights are on, then let go, reinstall the toner/drum, & close up front door. Power off & back on and you should be set.
Oct 21, 2009 | Brother HL-2040 Laser Printer
Overload light on Aims 5000w inverter
try to disconnect all cables from front and back, then turn the unit on and let all the stored charge drain and reconnect and test...make sure the unit grounded
Sep 06, 2009 | Inverter AIMS Power 5000 / 10000W
Power goes off
Try resetting the unit.
Make sure there is no disc in the unit. With the unit on, go to the front panel and look for the STOP (square) button.
Hold it down until the unit shuts off by itself. Turn it back on it shoudl work fine.
Jul 01, 2009 | Samsung HT-X40 System
Dlp samsung
There are instructions to replace the lamp in the user's manual. The light comes up but if the lamp has now already several hours of use the resistance of the lamp increases and shut down the power supply of the lamp. Second, the lamp power supply could be bad too, but lets be optimistic and just replace the lamp first.
Apr 07, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
9p6031c103
This is a common problem with older Philip Magnavox projection sets. Over time one of the IC chips on the main power board begins to fail. You can find replacment chips and repair instructions on www.magnavoxhelp.com.
May 22, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
110 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
