Greetings from GoVacuum.com,
It sounds like you may have a bad thermal switch inside the machine. Most vacuum cleaners have a switch connected to the motor, so if the vacuum cleaner is running hot, it will shut off to prevent any damage to your motor. You did all the right things by checking the bag, making sure the hose was NOT clogged, and replacing HEPA filter.
Most of the time on canister vacuums, the reason is caused by a clog in the hose, or somewhere in the powerhead. If you're sure that there is no clog anywhere, it is going to be the thermal switch on the motor.
Here's a link to the parts schematic for the Bosch upright vacuum. I hope it helps you in determining how to access the thermal switch. A word of warning to you before you try it, this is a very tough vacuum cleaner to work on, you may want to bring it in to a vacuum repair shop, as this is not an easy repair.
Here's the link;
http://www.essco.net/Customer/SchematicFrame.asp?FileName=Turbo%20jet%20upright.pdf
Please let me know if you have any other questions,
Chris Jones
GoVacuum.com
1-866-468-2288
[email protected]
mY VACUUM DOESN'T HAVE ANY POWER WHEN I PLUG IT IN
