Question about Logitech Z-5500 Computer Speakers
Sound from 4 speakers cut off..
Just put together my z-5500 system and started to play music. everything worked fine for about 20 minutes, then all the sounds diminshed from 4 of the 5 speakers. Only the left front speaker is outputting full volume. the other four have minimal sound coming out of it with a bit of static. I can go to my soundcard configuration in the sound options in the control panel and test the speakers individually. When i test my front right speaker, sound comes out with a lot of static. i do this for 3-5 more times (with static diminishing each time) and full sound comes back to all of my speakers. After about another 30 minutes or so, same problem comes back. My sound card is: http://www.newegg.com/Product/Product.aspx?Item=N82E16829102012
anyone know what's wrong? help is much appreciated.
  • 1 more comment
  • Anonymous Oct 13, 2008
    ALL SOUND STOPED FROM MY SPEAKERS
  • crew_acg Dec 08, 2008
    I have encounters the same issue where only the left rear plays its true output while the others are diminished and/or static. The only trouble is that I don't use it with my computer, so it is not a sound card issue. The system was working fine before using a 3-to-1 headphone splitter from my iPod to the 3-wire connection to the control pod.
  • beecrcrateof Dec 12, 2008
    i have a pair of old memorex 305s old i know but i like them...they work for a few minutes the cut oout ...do i need a new amo or are the speaker fuses or coils ruined please help an tell me how to fix them thanks
    President:
  • 2,712 Answers
To troubleshoot a speaker system where sound is not issuing from all speakers, please do the following:
  1. Verify that all cables are plugged in correctly. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the center/sub audio port is orange. If you do not have a surround sound card, make sure you obtain the proper adapter (discussed in the next paragraph) or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details.
  2. Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. For 5.1 systems, the card should have a front, rear, and center/sub, output. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, you can use the source selector switch or the M3D button on the controller unit (if available). You can also use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound.
  3. Try connecting the speakers to a portable sound device such as a walkman or portable CD player. Plug the speakers into the headphone jack, but make sure the volume is lowered so the speakers are not over powered. You can do this for both the front, rear, center/sub speakers to verify that they work. If the speaker system works on the walkman, then you are experiencing a configuration issue with your sound card. Please contact your sound card manufacturer.
  4. Check the system Volume Control located in the System tray. Make sure that the volumes are at a reasonable level and are not checked for Muting.
Try these articles as well:
Manual
Setting up the Z5500 with PC, Mac, Xbox, Playstation, DVD Player, etc.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 24, 2008
  • Swilin Sampson
    Swilin Sampson Jun 01, 2008
    This thread has gone 7 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
2006 infiniti m35 no sound from speakers
Yes an amp that is not working could cause this to happen. But I would check it out a little more because when you did the speaker test and all the speakers worked then that doesn't sound right. Find the amp and it could be just a loose connection that is giving you all these problems. Good Luck
Mar 12, 2014 | Car Audio & Video
Speakers cut out after 7 minutes
It sounds as if something is not grounded properly. Check your wiring and make sure all connections are made.
Feb 12, 2014 | Cars & Trucks
My speakers haven't been working properly for a while and I was wondering how to fix this. They sometimes work (very rarely) but then they just cut off, the music will still be playing but I won't be
If it always works with headphone - without fail - then it is likely the fault is within the headphone socket. You'll appreciate that when you plug in headphone, the speakers in the laptop are cut off - which is a mechanical break in connection caused by the plug. Sadly, it sounds like it is staying disconnected.
Nov 24, 2013 | Computers & Internet
Hiya i have recently moved my computer from the front room to a bedroom and plug everything in, i thought everything was fine until i tried to play some music so i checked all the connections/leads and...
Hi try looking over it again with the help of this https://www.download.p4c.philips.com/files/s/spa7300_79/spa7300_79_dfu_eng.pdf just make sure all connections are pushed in properly as those plugs have a tendency to not plug in all the way
May 04, 2017 | Philips SPA7300 2 Speakers
ILive Bar Speaker not playing sound
I have an iLive bar speaker ipod dock and it has worked great until today. The sound isn't working. You can hear that it is on, but it isn't playing music. The display works and everything. Is this fixable?
Apr 18, 2010 | GPX iLive IB-R2807DPBLK Portable Music...
When i play a game such as Battlefield Bad Company 2 on the Xbox 360. The sound works, like you can hear the water flowing, aircraft etc etc, all that is is fine. But when it comes to audio of different ...
Most of the sounds you are hearing good are background sounds. If you are running a surround system, you might want to try adjusting the output of your primary speakers, checking for the correct setting on your receiver, and verifying that your central audio is in the correct section ( receiver output ).
If you are not using surround sound,
Check the in-game menu (Pause) for an audio section, some games allow you to turn the character voices up and the music down. If you don't have that option, try using a new output cord from your xbox to Tv.
Mar 10, 2010 | Logitech Z-5500 Computer Speakers
Logitech Z-5300 subwoofer from computer to i-pod problem...
The best thing to do is to contact the manufacturers. From this i understood that your speaker system is new. You surely have the manufacturer's guarantee. So its better to contact them than to get it repaired or replaced for free. Sir please do not try to open the sub as it will void the guarantee policy.
Hope your subs come into play as soon as possible.......
All the best...
Jan 05, 2010 | Logitech Z-5300e Surround Sound System...
Static noise panasonic home theater
Simply unplug the machine for more than one minute. Then plug it back in again. That makes the system reset and the problem went away.
Sep 03, 2009 | Panasonic SC-HT700 System
Bose Acoustic Wave music system popping speaker
Had the same problem on the same machine 15 or so years ago...took it to the Bose factory shop in Framingham (or real close )Massachusetts, and they fixed it in 20 minutes...cost around $50...at the time they said it was a real common problem, and an easy fix.
Jan 20, 2009 | Bose Acoustic Wave music system II -...
Jensen vm9511ts cuts out
It sounds like the phone mute is going on and off, but I'm just guessing because I don't know your grounds, speaker wire hookup configuration, etc. Look at the screen when the music cuts off and goes back on and if you see a little red phone with the cross through speaker symbol (aka mute) it's probably the phone mute feature which is supposed to be hooked up to bluetooth and mute the stereo when you get a call. Like I said I'm just guessing, but if so there's a brown wire in the back that needs to be hooked up.
Jun 19, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Logitech Z-5500 Computer Speakers Logo
458 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
