Question about Mitsubishi WS-65315 65" Rear Projection HDTV-Ready Television
COLOR &CONTRAST NOT GOOD
SOME DAY COLOR & CONTRAST ARE OK SOME DAYS VERY POOR
  • 927 Answers
Good Day, LEE-M;
Try this :
White raster with no signal, washed out looking video with signal. Access the service menu, "menu 0357" use the audio button to select "video chroma" adjustments, use the video button to select item "40 - AGIW", use the adjust button to change the setting to 0, then press the enter button to store the change. Good Luck, big IRISH.
Posted on Sep 01, 2008
Sinotec
check the antenna u may be getting poor reception,if the video is ok on dvd then the antenna is , if not the tv is faulty on its video output need a tech to check it
Jul 10, 2013 | Televison & Video
I have a JVC 32050 and have a slight red shadow (ghosting). is there an adjustment for this?
Try to adjust the color setting in the menu adjust the contrast or the sharpness feel free to send feed back good day and best regards.
Aug 14, 2011 | JVC AV-32050 32" TV
Have est7 printer .... won't print without 'good' color cartridge. can't reset to go 'black only' . is this a design issue or just poor documentation.? I bought Kodak because of its...
first up
in a printer to get good black grey contrast etc, color is used
next when you get set to print, press settings and then click on black
make default and ok
Kodak reputation is not universal because it is average quality
Nov 04, 2017 | Office Equipment & Supplies
Toshiba 37XV505D. Sound but no picture
Since sound is ok but there is no picture, you should try the following:
1) check whether brightness & contrast controls are adjusted properly. If necessary increase level of these controls.
2) If brightness & contrast are ok and even then there is no picture then most probably, there is fault in the horizontal supply circuitry which drives picture tube and is responsible for picture to appear on the screen. you will have to take the TV to service center.
Good luck and Good day.
Rating the solution is appreciated please.
Aug 19, 2010 | Toshiba Televison & Video
Print quality poor for mp780. Had s800 which
There seems to be a calibration problem. Follow the calibration test from the manual.
If you are using original cartridges, go to canon for repair.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 23, 2010 | Canon PIXMA MP780 All-In-One InkJet...
I wanna send a fax
Sending Faxes.
* Flow of Sending Faxes.
The operation flow of sending faxes is as follows.
Step 1:
Load the original to send on the Platen Glass or the ADF.
Step 2 :
Adjust the fax quality and scan contrast.
Step 3 :
Dial the receipent' s number.
Step 4 :
Send Faxes
- Using the Platen Glass
1) Press the Color or Black button.
If you have two or more pages of the original, load the next page on the Platen Glass and press the Color or Black button
2) After scanning all the pages of the original, press the OK button to send the fax.
- Using ADF
The fax is sent automatically.
* Before sending Faxes
- Adjusting the Scan Contrast or the Image Quality (Fax Resolution)
** Adjusting the Scan Contrast
Contrast is the degree of difference between light and dark. Increasing the scan contrast setting further blackens dark areas and whitens bright areas, whereas decreasing the contrast setting reduces the difference between bright and dark areas. You can adjust the contrast among the 3 contrast levels.
1) Press the FAX button, then press the FAX Quality button.
2) Press right or left arrow ot select the contrast.
Pressing the left arrow button decreases the contrast, and pressing the right arrow button increases the contrast.
3) Press the OK button.
** Adjusting the Image Quality (Fax Resolution)
You can adjust the image quality (fax resolution) of the document you send. The higher you set the image quality setting, the better the output quality will be at the other end, but the longer it will take for the transmission. Adjust the image quality according to the type of document you are sending.
1) PRess the FAX button, then press the FAX Quality button two times.
2) Press the right and left arrow keys to select the resolution.
FAX RESOLUTION - STANDARD
Standard : Suitable for text-only documents.
FINE : Suitable for fine-print documents.
PHOTO : Suitable for photographs.
*Sending Faxes - There are 4 methods for sending functions
a) Memory sending
b) Manual sending
c) Dialing the coded speed dial
d) Redial
a) Memory sending
1) Prepare for faxing
a) Turn on the machine,
b) Load the original on the Platen Glass or the ADF.
Note : You cannot scan double-sided documents from the ADF.
c) Press the FAX bitton.
d) Adjust fax settings as necessary.
2) Start faxing.
a) Dial the receipient's number using the Numeric buttons or coded speed dialing.
b) Press the Color button for color sending, or the Black button for black and white sending. I
c) When the following message is displayed, lad the next page on the PLaten Glass.
Scan Next -> Start
Transmit-> OK
If only one document go to step f).
d) Press the same button as you pressed in step b).
e) Repeat step c) and d) to scan in all pages of the document.
f) Press the OK button.
Manual Sending
1) Connect a telephone to the machine.
2) Prepare for faxing.
a) Turn on the machine.
b) Load the original in the ADF,
c) Press the FAX button.
d) Adjust the fax settings as necessary.
3) Lift the handset of the telephone connected to the machine.
4) Dial the receipient's number on the telephone.
5) Talk through the handset to the recipient.
If you hear a high-pitched signal instead of the recipient's voice, go to step g),
6) Ask the recipient to set recipient's fax machine to receive faxes.
7) When you hear a high-pitched signal, press the Color button for sending color sending, or the Black button for black & white sending. Then hang up the handset.
Dialling The Coded Speed Dial
1) Prepare for faxing.
2) Press the Coded Dial button.
3) Press the Numeric buttons to enter the two-digit code (00-19) assigned to the number you want to dial.
4) Press the Color button for color sending, or the Black button for black & white sending.
Hope this helps. Please rate my response.
Thanks
Have a good day.
Nov 27, 2009 | Canon PIXMA MX310 All-In-One Printer
Having problem with getting the color and contrast right?
Good Day;
Turn your color down all the way, do you get a good Black and White picture with good black, white and grays? If not your picture tube may be going bad. It can be adjusted sometimes to get a 'better' picture.
If picture is a good B&W; adjust britness level: 50% > contast: > 90/95 % >color: 50%.
Sep 25, 2008 | Televison & Video
What's the best settings for Toshiba LCD 42RV530U for color, contrast and size?
Good Day, kwlao;
TV's have adjustments, why? Because everybody is different. So, adjust picture settings to what you like.
Aug 13, 2008 | Toshiba Televison & Video
Panasonic PT-47WX54J --- Picture Problems
Yes,try cleaning your mirror inside of tv they do get real dirty, also clean dirt off of tube lenses there are 3 of them red,green,blue. these are your picture tubes. Thank You for using FixYa and Have a nice Day.
Feb 05, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Something with lcd
try to lower the colour depth & adjust contrast
Feb 03, 2008 | Olympus SP-350 Digital Camera
Mitsubishi WS-65315 65" Rear Projection HDTV-Ready Television Logo
54 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
