Question about Canon 24-70mm f/2.8 Lens
Reading the light meter on my camera
I have a Canon Rebel. Am I seeing a light meter reading, when I compose my shot and just don't know what I'm looking at?
Thanks.
  • Wendy Sue May 21, 2008
    Excellent help, and also gave me a link to get me going and learning in the right direction.
    Thanks Fixya!
    wst
  • 2,016 Answers
You didn't mention whether your Rebel was a film version or digital, but as best I can see from the manuals they are quite similar with regards to your question.
The camera does have a light metering function, but you won't see a needle like some of the older film cameras had. Instead, you will see in the viewfinder the shutter speed and the aperture settings. For example, 500 4.5 would indicate that the camera has determined that the shutter speed will be 1/500th of a second and the aperture f/4.5 to properly expose the shot. Depending on what mode you are in, you can control one or both of these numbers. If either number (or both) are flashing, it indicates that the shot will be overexposed or underexposed, and you must take some type of corrective action that the camera cannot do itself with the current mode settings.
Canon has manuals available online for all the digital Rebels and many of the film Rebels. See this link. Select EOS (SLR) Camera Systems in the top box, and choose the appropriate categories in the next two boxes, then click Go.
Posted on May 20, 2008
On the outside of the back bottom right corner red light
The LED on the right is flashing when the camera access the memory, while writing or reading the pictures. I did not know it is red on the Canon EOS.
Dec 03, 2013 | Canon EOS 600D Rebel T3i Digital Camera
Canon T2i viewfinder issue
Try increasing the ISO rating, see if that gives you a different reading - you may indeed be underexposing if there is insufficient light
Sep 17, 2017 | Canon EOS 550D EOS REBEL T2i Digital...
My Rebel xti will not display live view but will display shots taken - can you help?
This model does not have a live view capability. To compose the shot you must use the viewfinder and then you can check the result on the lcd screen. This the norm on semi professional and professional DSLR's
Jan 27, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
Canon eos 400d how do i get the screen on rear to show the view before i take the picture
I'm afraid you can't view the image on the rear screen before you take the shot. On cameras like these,( semi and professional DSLR's) this is the norm. You view and compose the shot through the viewfinder and then you can check the result and view all your shots on the lcd screen afterwards
Nov 05, 2010 | Canon EOS 400D / Rebel XTi Digital Camera
How do I connect an older film lense to a Canon Rebel XS Digital body?
Check the mountin type of the old lens, I use nikon myself and can use my old 50mm lens from a FG on my D70- as they have the same bayonet mounting. Though doing this the camera will only take a shot when it is set to manual- and I'm unable to use the D70's light meter.
If your looking to fix a really old screw in lens to your rebel- i imagine you will have hunt around for an adaptor of some sort.
Seein as thats something I have never done had a root around some resources i use- maybe this will help you a bit more, be warned its fairly dense reading material.
http://www.bobatkins.com/photography/eosfaq/manual_focus_EOS.html
Another thing using a non-digital lens on a digital body can cause problems- something to do with the lens being designed to put a image onto a 35mm shot of film and not a little digital sensor- You'll probably find that what you see in the viewfinder does not appear in the final image. Fairly sure there are conversion tables for the size of lens and what it shoots when used on a digi- body. For example a 50mm lens will be giving a image area equivelant to using a 85mm lens (thats off the top o my head), I'm fairly sure this varies from camera but that info is fairly easy to find.
Nov 06, 2009 | Canon Rebel XS / Eos 1000D Digital Camera...
Canon Digital Rebel XT auto focus
Auto Focus does not determine exposure. Only sharpness. "Wrong" exposure could be due to the metering mode being set in Spot Metering. Set it back to Evaluative Metering which may improve the overall even exposure of your shots. Test your shots in full auto or P mode. M (Manual) mode will require you to check the exposure setting manually (you can see the indicator in the viewfinder when you half-press the trigger)
Nov 05, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Can't take good pictures with new Canon Rebel xsi
You will need to read the manual. I f you have a basic understanding of how ISO, shutterspeed & Aperture width combine to determine the 'right exposure.
Try this:
Set the camera to Av (aperture priority mode). Half press the shutter button and see the light meter indicator to see how well exposed your shot will be. For most cases you would be aiming for a value of 0 (properly exposed). The metering mode determines what part of the frame is used to compute the correct amount of light. For starters begin with pattern metering. Try and aim for a shutter speed of 1/125 or more if you are using the 17-55 mm EF-S f3/5-f5.6. Try and shoot at 40 mm F/5.6 (in Av mode this can be set by rotating the dial near the shutter button.
All the best
Mar 29, 2009 | Canon EOS Rebel XSi Digital Camera
Vewing the shot before I take it on the lcd
Hi Janet;
On most DSLR cameras you cannot compose or shoot using the LCD screen. The ability to preview the image using the LCD is fairly new to SLR's, and is known as "live view" on most models. So, like yourAE1, you still need to compose using the eye-level finder, then review your effort on the LCD later.
Jan 18, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Spot Meter on Canon Rebel XT?
there's a metering mode setting.
from the manual:
(metering mode on first menu1)
evaluative metering - standard setting, takes account off all areas of scene.
Partial metering - effective when background is much brighter than the subject due to backlighting etc.
Centre weighted average metering - the metering is weighted at the centre then averaged for entire scene.
pressing the right hand button of the two little ones top right corner of camera brings up display on lcd, using thumb wheel you can select where the metering takes place. in the viewfinder the display lights a red dot for areas selected.
Try these settings to see if this helps in your situation.
Nov 12, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Hello, new user for canon rebel. read manual for basic instructions & still get message : no image when i attempt to take a picture. how do i get the camera to show the image i'm aiming at?
Unless you have a Rebel XSi with "live view", you're not going to see the image on the LCD before you take the picture. No digital SLR made before 2007 had this option. You compose your picture using the optical viewfinder, and only see your picture after you have taken it. (But at least you don't have to wait until the film is developed. ;-) )
Aug 02, 2008 | Canon Cameras
Canon 24-70mm f/2.8 Lens Logo
221 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
