XEROX XC865 flashing light no manual
I don't have a manual for my Xerox XC865 machine and bought it used from a private party.  I put a new toner cartidge in, fired it up for the first time, and on the control panel front of the machine - in the diagram of a copier the first light is flashing red. It looks like maybe an eye or an arrow pointing up.  Not knowing what this is I don't know what the next step is.
I paid $5 for the machine but I have put $95 into the new cartridge.  I am willing to put a little more money into it if it will work but at this point that light just flashes and it won't do anything.
Dave Zinn 541.788.5043 dave@davezinn.com
    President:
  • 2,072 Answers
Needs a drum/print cartridge.
Posted on May 20, 2008
Xerox Copier (XC865) IS FLASHING "H4". WHAT IS THIS CODE?
Posted on Aug 05, 2009
Xerox phaser 6360 smearing magenta toner only
that's the developer assembly that has gone bad. If you're using 3rd party toner it wears down a lot quicker. You'll need to replace the magenta developer unit, part number is 848K03850.
http://www.iteminconline.com/848k03850_848k03850-xerox-6360-developer-assembly-magenta-oem-new-genuine.htm
Feb 09, 2016 | Xerox Office Equipment & Supplies
Cannot get new cyan toner for 7435 to be recognized.. may of been changed before asked for by machine... not sure what to do next
Call Xerox. The Corporation needs to take responsibility for selling a machine that has toner available. //They should tell you where to get the toner or provide some for you. Start out nice but don't let the push you around; insist if you need to. Xerox can't sell a machine with no toner.
May 23, 2014 | Xerox Workcentre 7435 Color Multifunction...
Hello, we have a Xerox Workcentre 7545, the waste toner cartridge needs replacing but we don't have the part yet. Can I manually empty the cartridge in the meantime so we can still use the machine? ...
If you can remove the waste toner cartridge go ahead and empty it out manually. Make sure that it is completly clean out. I use compressed air to flush out any residue.
Sep 22, 2011 | Xerox WorkCentre M-24 Color Copier
There are 3 lights on the xerox 1020 first one
you replaced the drum too soon, replace old drum until red light flashes then install new drum.
Jan 22, 2010 | Xerox Office Equipment & Supplies
Xerox phaser 6360 is ghosting. replaced transfer roller but no help thanks Bruce
Most common cause of this is the use of 3rd party toner. This isnt true for all printers but some of the newer Xerox are notorious for it as the 3rd party toners are not produced to the exact specs as xerox. If your not using genuin Xerox toner you have your cause.
If your mechanicaly savy you can completely dissasemble most of the printer in order to clean out the toner. Then start over with new Xerox toner cartridges. I have had to service 2 of these printers in this way, and both were like new when done.
Dec 16, 2009 | Xerox Phaser 6360 Laser Printer
Machine will not make copies
Your out of toner and the machine cant set up.
May 20, 2009 | Xerox Office Equipment & Supplies
Schematic of the Xerox XC865
google The Parts Drop, Give them a call, ask for Britt he can help you most likely.
Mar 10, 2009 | Xerox CopyCentre C123 Copier
Cracked fuser drive gear for Xerox copier XC865
There is a metal clip that holds it on the roller. Look in the machine for it.
Jan 31, 2009 | Xerox CopyCentre C123 Copier
XEROX XC865 - No image
You are not getting any transfer. There are two types of transfers:
1- Corona wire; a set of very thin wires (hair thin and usually gold) that sit exactly against the drum. they are eiher broken or the unit is shorting out
2- a black spongy roller, usually don't go bad may need some recalibration
other possibility is the Developper unit,
which may be going bad look at it does it have a coat of toner on it? if no and you can see the long roller (it should be a silver magnet roller) if you can see the silver then there is not enough toner on the roller, it should have a thin solid layer of toner all the way xerox%2520xc810%2520drum%2520cartridge.gif
Aug 07, 2008 | Office Equipment & Supplies
555 people viewed this question
jasbo
jasbo
