Question about Alpine MRP-M450 Car Audio Amplifier
Power turns on briefly
It's not a wide setup, amp is going to 2 woofers like it did in my previous vehicle.
HU powers up w/car, amps power light briefly turns on and then back off.
Not sure whats up...
Tested power - 12v
The light turns on which kind of tells me its getting signal from the HU, ie remote wire.
Suggestion?
  • 15,935 Answers
Sounds like a protection problem. A relay may be stuck, or there really may be an internal problem you cannot see. Take it to a shop to have it bench tested independent of your vehicle.
Posted on Dec 22, 2008
Amp power light is on, but sub not making sound ?
If you have power, and the amp has previously worked.
Check your audio input and make sure you do not have any filters on like a sub woofer crossover, that you do not want.
If that still doesn't work try hooking up a different speaker for testing purposes.
I hope this helps
Nov 15, 2016 | Car Audio & Video
My subwoofer doesn't receive power, all amp fuses are fine, amp powers on, remote wire and rca wires are connected and intact. Before it stopped working all together the woofer would cut out and after...
If you are getting power to the amp, try this....Find a small speaker, unhook your sub and wire speaker to amp. Turn on your system at a low volume....If the other speaker is playing through amp, then your sub is shot.....If the small speaker doesnt work, then its either your channel is gone on the amp or the rcas have quit off off your head unit.
Oct 07, 2010 | Kenwood eXcelon X1200M Car Amp
What amplifier should I use for 2 650W Subs?
HI DUDE .. I JUST GIVE suggestions Boss Car Audio D5504 "Diablo Series" 4-Channel Car Amplifier 2200 Watts ITS REALY GOOD FOR SOUND SYSTEM DUDEaaf1faf.jpg
Jun 10, 2009 | Pioneer GM-6300F Car Audio Amplifier
Protection light keep coming on
Make sure your head unit is off.
Reset the amplifier using the manufacturers specified method. Usually this is just power down briefly and then back up. I usually pull the amp fuse and make sure all LED's on the amp go out. Wait 10 seconds, and then put the fuse back in.
If the LED comes back on when you reconnect power, without the HU being on, you've got a bad amp.
If the LED does not come back on after reset, then check for short circuits on the speaker leads. Still leaving everything off, from the amp terminals, remove both wires to a specific speaker and check for shorts.
Mar 21, 2009 | Car Audio & Video
Amp turns off
Sounds like remote turn on wire is bad. If using aftermarket HU, find another location to power amp. Try the the power antenna wire on the HU to run the REM.
Jan 24, 2009 | Pyle PLAM1200 2-Channel Car Amp
Jl audio with 2 12kickers cvr
it sounds like you don't have enough power to run the amp, or else it is a built in (MOSFET) overload device inside the amp. the woofer is from your discription blown. when you choose a amp and woofer you need the woofer to be able to handle more watts (MAX) than the amp can give or you will blow every woofer you connect up. you can solve the power outage by fitting a "CAPACITOR" which stores power and provides it to the amp as and when it is needed, or you will need to install another battery for the amp alone.
Jan 15, 2009 | Jl Audio 250/1 Car Audio Amplifier
Amp not working properly
yes that is the cause sorry..i have done it before when i was younger a few times thats how i know..sorry man
Dec 05, 2008 | Car Audio & Video
If my jl amp e1200 is on green, but no power is going to the sub
your audio wires from the head unit have been pinched or discontected or the head unit is not putting out a signal
Nov 29, 2008 | Jl Audio E1200 Car Audio Amplifier
No sound out of subs
Check the ohm of your soeakers again. If it doesn't say 2 ohm thats the prob. Keep in mind that 2 ohm can be any where from 1.7 too 2.3 but any reading on you DVOM that gives you two decimal places is also wrong. i.e. 2.17. This would mean that you have a woofer shorted.
If thats not it and you have already fixd a ground then use your meter to check the ground; to do this set the DVOM to ohms and touch one lead to a true gound, by that I mean scratch the paint and primer off of a spot you can hide untill you see bright mirror like metal. Then disconnect the ground wire from the amp and touch the other lead to it. You should read anything from 0.3 to 0.1 any higher and your ground isn't that great.
If thats not it, The only thing left is to hook the amp up out side of the vehicle away and not connected to ANYTHING that has to do with the car. Get a battery and a diskman or a playstation, anything that can pass sound out of RCA's (Maybe even a diff radio if poss). Hook it up. If it works its in the car and let me know. I'll tell you some more to check, If not its the amp. Good Luck
Dec 03, 2007 | AudioBahn A1300HCT Car Audio Amplifier
No Sound coming out of amp to subwoofer
check the fuse box and make sure there is no loose connection there. also check the wire that feeds power to that amp. good luck
May 23, 2007 | AudioBahn DUB Mag Audio DUB1002 Car Audio...
Alpine MRP-M450 Car Audio Amplifier Logo
133 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
