Question about RCA P52960 52" Rear Projection Television
Sounded like a light bulb burst...
A friend of mine has a p52960 52in tv and she was watching it and heard a pop (like a light bulb burst) then she smelt a metallic smell. Do you happen to know what it could be and how we can fix it?
  • 2 more comments
  • khamby_06 May 26, 2008
    Yes the power led lights up when power is pressed.
    I don't exactly know what it looks like. I have looked on several sites to find one and am having no luck.
    no I haven't , but what will they look like if they are blown?
    ok will look
  • RCA Master
  • 8,617 Answers
Sounds like a capacitor blew or the Flyback has shorted. Does the power led light up when power is pressed?
Posted on May 20, 2008
  • 1 more comment
  • Sonny Berry
    Sonny Berry May 26, 2008
    have you checked inside the cabinet to see if you can see a capacitor blown?
  • Sonny Berry
    Heres a picture of what a capacitor looks like they are just little cans.
  • Sonny Berry
    They will either be swelled up, or stuff coming out of the bottom or they can actually be loose laying in the chassis.
Toshiba 37" LCD flat screen. I heard a small
Get a quote from a TV repairer then you can decide if it us worth repairing.
Mar 30, 2013 | Televison & Video
My tv made a loud popping sound. Now the bottom right 1/4 o the screen is black with different colored lines on it
Check for any bursted electrolytic capacitors on its main power supply regulator board. The sound you heard might be to this burst. Take care, and unplug the TV from AC mains supply wall socket, before opening and checking this board. See examples of bulged [bursted] capacitor.
Jul 10, 2012 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Hitachi clu-4591av stopped working - popping sound
The power supply regulator section should be troubleshooted. The "Pop" sound you heard might be of a bursted electrolytic capacitor in the AC mains rectifier section inside the TV. All the related commponets, rectifier diodes, protection zener diodes etc:- should be checked before switch ON the TV further.
May 15, 2012 | Televison & Video
Samsung HLR5078W pop sound followed by a loud buzz then shut down
Your lamp burst. This model uses a lamp housing which does not have a filter screen on it. When the lamp bursts, hot pieces of glass and mercury (very toxic) drop straight down into the cooling fan below it. Although FixYa.com (implies I'm suppose to tell you how to fix it) I am going to tell you to call a servicer and have them clean that mess out of there. It's a health issue, I don't want someone unknowingly exposed to mercury on my watch. Let the servicer know what he is getting into. I hope this helps.
Mar 18, 2010 | Samsung HLR5087W 50" Rear Projection HDTV
CHANGE BULB SOUND WORKBUT NO PICTURE.GREEN LIGHT
If you still have red light , it means the temperature of the lamp is too much. Did you buy the original part number of the lamp.
Jul 24, 2009 | Televison & Video
Tv picture does not come on
my first question is have you checked the bulb. the loud pop sound like the bulb blew and the rattling sounds like the lamos trying to fire. remove the bulb cover and unscrew the bulb
Mar 18, 2009 | RCA Scenium M50WH187 50" HDTV
Nothing happens. power on,can hear click
I had the same problem, but I saw the events leading to it. I was watching TV, went to help the wife, heard a pop, came back to find the TV off. Turned it on, heard the same click you described. I believe you need a new bulb. Mine lasted around 2 years of heavy use. Bought two on ebay. Make sure to consult your manual for the particulars on the bulb.
Jan 07, 2009 | Sony KP-57WS500 57" Rear Projection...
Made a pop sound then screen went black- won't power back on
I'm sure you've resolved this by now, but I am brand new to this site and have the same TV, and have had the same issue. Sorry it's a bit late.
The pop was definitely the bulb bursting. You can pretty easily do this bulb replacement yourself as Panasonic has provided a nice little pull out module that can be removed by popping the front plate off (which requires no tools at all) and then opening the hatch where the bulb assembly is and loosening just one screw. Once that is done you will be able to slide the entire bulb assembly out of the TV. Though they don't always shatter, I suspect that since you heard it "pop", you will find this assembly full of broken glass.
You can either buy an entire new assembly such as this one...
http://www.alltvlamps.com/product_p/ty-la1000.htm
and just slide the new one in,
or if you're comfortable with it, you can open this lamp assembly up by removing just a few more screws (about 4) and just replacing the bulb. I did need to buy a very long #2 Phillips head screw driver to reach one of the screws.
If you search Google for TY-LA1000 you will find both the lamp kit and just the bulb. Be careful though for the really cheap bulbs, it does make a difference, so if it seems drastically cheaper than all the others, there is likely a reason.
Hope this helps you and sorry for the slow response.
-R
Nov 23, 2008 | Panasonic PT-44LCX65 Television
Read replace lamp then afew weeks later heard pop noise and now black screen
Two things in your TV can make that popping sound. One is the bulb of course and the other is a capacitor. Have you pulled out the bulb to inspect it? My guess is that you have broken glass in the cooling fan, which is why there is a grinding sound. Most bulbs tend to contain the glass from getting everywhere as it's only the filament inside that pops creating little diamond looking pieces inside the lens. If a surge was strong enough or if the bulb was poorly manufactured, the whole unit can explode inside spraying glass everywhere.
If the bulb looks fine, the pop must've been a capacitor on one of your circuit boards resulting in no display. Since the TV still powers on, your power supply and it's fuse appear to be fine. Check the bulb first and go from there.
Oct 17, 2008 | Panasonic PT-60LCX64 Television
RCA P52960 52" Rear Projection Television Logo
65 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
