Question about Refrigerators
Samsung american style fridge freezer power loss after internal light blew
Opened freezer, light blew and all power went off. I've chanegd the plug fuse for two different fuse's which I know work and nothing. Samsung going to take 48 hours by which time my food has gone off - help!
  • SwissT May 20, 2008
    Hasn't worked, just managed to get someone from Samsung to orgnise a repair tomorrow - he thinks it's a circuit board as well.
    Thanks for trying to help - looks like I've got to wait it out.
  • 770 Answers
Try to unplug for 2 min and plug back in to reset the unit otherwise sounds like you cooked a board
Posted on May 20, 2008
Fridge/freezer freezing up
common issue on uk samsung rsh1 american style appliances
easy cured - diy repair kits been on the market a few years now
watch this youtube video for some extra help
Jun 10, 2014 | Samsung RSH1DTMH American Style Silver 524...
Hi my Samsung fridge is freezing up? What do i do?
samsung fridge freezer problem click here
hi what model do you have - if its the american style one
fridge freezer up is a common prob with samsung
you could have a look on youtube - there a guy who has a dedicated youtube - samsung fridge freezer repair channel
heres one of the videos >>>>>>ebay links below videos where you can pruchase spares
hope this helps , if you require parts look under youtube videos as there are links you can click onto that will take you to this guys ebay samsung spares shop ..">
Dec 28, 2010 | Samsung Refrigerators
Hi there- recently my samsung fridge began to make a bit of a knocking noise like the fan was dying down whenever I opened the fridge door. Now my fridge won't cool down below 58 degrees. From what I can...
It sounds like the defrost is not working properly and ice has built up inside where the fan is and the ice is restricting normal operation of the fan.Try fully defrosting over 24 hours if possible the defrost heater will still need investigating.
Hope this helps.
May 18, 2010 | Refrigerators
No light in fridge compartment, Not freezing. Light in freezer co
Your door switch is bad.  When doors are opened, the fan stops.  No cooling.  When it closes, fan starts.  Bulb is just an indicator of no power to unit...probably burned out contact in switch.
Nov 12, 2008 | Refrigerators
Water Dripping Inside
Sounds like a blocked defrost drain. By "American" I presume you mean side-by-side.
I had a similar problem with a freezer-on-top style Samsung. The solution to that was to defrost the freezer, remove the false backing plate in the freezer (required removal of the ice cube tray. the panel just pops out with a bit of pulling). The drain hole beneath the freezer coils was blocked with ice. This drain passes down into the fridge and then out the back of the fridge into the evaporation pan next to the motor. There is a collector pan under the freezer coils, this and the drain hole were filled with ice. When the freezer goes into its self-defrost cycle the water collects here and then overflows into the fridge.
I removed the ice with hot water/vinegar mixture (so it doesn't re-freeze immediately) and simultaneosuly used a bit of chiselling with a screwdriver to clear the drain plug. I did this from inside the fridge working up the drain hole into the freezer. The whole job took about an hour.
Aug 24, 2008 | Freezers
Samsung american style fridge/freezer needs repairing
Spray a good quantity of WD-40 on the spindle of the fan motor where it enters the motor itself. This should get the fan working smoothly with no noise. This will probably solve the other problems, as the fan prevents various components from overheating and shutting down.
Apr 01, 2008 | Refrigerators
Open Questions:
Refrigerators Logo
128 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
