Question about Broadxent Computers & Internet
Modem problem Hi! I have a Broadxent modem, and all the lights are on except the Internet light. This modem is connected to a linksys router, and everything is right connected, but suddenly I lost my Internet connection, could youl guys can help me?
I need a driver for modem de5625 and ships codes or nck please
Posted on Sep 20, 2012
Do you have a 2.4ghz phone. If You do please unplug it.
Posted on May 20, 2008
RESET USERNAM AND PASSWORD
Resetting the linksys router in just six easy steps..
1. Turn on the router.
2. Reset the router, wait until the power light is blinking and then press and hold the reset button for 10 second.
3. Turn off the router and turn on again.
4. Wait for the power light to stop blinking, if the power light does not stop blinking, turn the router off, wait approx 30 second , and then turn it on again.
5. Connect the router to your computer, when it is connected to a computer with an ethernet cable, the ethernet port light will light up.
6. Connect the router to your modem, the modem is connected to the internet port is your computer. The router is connected to the modem.
If you are not able to reset the linksys router password then call linksys router support phone number 1-888-494-1155 (Toll-free) USA.
Apr 18, 2014 | Linksys Wireless-G WRT54G Router
My router is connected, but there is no internet connection.
Actually, Linksys WRT160N is meant to be used as a router not an access point. It can be but with at
Jul 26, 2011 | Linksys WRT160N Wireless Router
Can connect to internet directly through modem. When connected through Linksys WRT54GS router, all lights are ok on both modem and Linksys--including internet. (Have had this router for 2 years...no...
As last resort you might want to use a JTAG cable and debricking programming software. If your router is brikced or you want to change the firmware this cable can do it. The cable will connect to your parallel port and your wireless router so you can repair your router. They are about $5.95.
Jan 11, 2010 | Linksys Wireless-G WRT54G Router
I am using linksys router but its internet light not on. i have configure fully the router but still the status showing is down..& not UP
Check the cable connection between the modem and the router.
You said that the Internet light is not on on the modem or on the router.
If you connect the computer directly to the modem does it work ?
If yes then connect the computer and the modem to the router and open the router set up page.
Set up the router manually.
Click Here for more info about router set up
Nov 30, 2009 | Linksys WRT300N Wireless Router
Hi, I'm an idiot! PLEASE HELP
you may be suffering from mixed Cat 5 and Cat 6 cabling.
The wiring is slightly different and they don't work well when mixed in routers and modems etc. One or the other will work , but when they're mixed it'll do what you have going on here...
I would recommend wiring everything with cat 6 ethernet cabling. Look on your cable and you will find the labeling on the outer casing.
Sep 20, 2009 | Computers & Internet
Need to redo wireless setup betw linksys & westell
You will need to assign a different ip address to the Westell modem - I am assuming that both the router & modem are using the same ip address 192.168.1.1? If that is the case, then assign 192.168.1.2 to the modem.
Mar 15, 2009 | Linksys Wireless-G WRT54G Router
Cant get to internet thru linksys etherfast cable/dsl router
Reset the modem while the router is plugged into it. Do this by disconnecting the power to the modem and then reconnecting.
Nov 09, 2008 | Linksys EtherFast Cable/DSL Router
Can Connect to internet via cable modem, but cannot connect from Cable Modem to LinkSys WRT54G router to PC to Internet ?
1. Make sure your cable modem is connected to the Internet port of the router.
2. Your computer should connected to one of the 4 ports at the back of the router.
3. Check the lights that are lit. Make sure the you have power(steady green), Internet, WLAN and Ethernet port light.
4. Press and hold the reset button on the router for 15 seconds.
5. After 15 seconds, release the reset on the router and turn it off.
6. Turn the cable modem off, too.
7. Wait for a minute. Turn the modem ON first. Wait for the lights on the modem to be ready.
8. Turn on the router. Make sure you have good lights on the router.
9. Check for Internet connectivity.
Nov 08, 2008 | Computers & Internet
I need help!!!!!!!!!!!!
What is you modem? Who is the ISP? First you have to check if the internet is working when your pc is connected to the Ethernet port of the modem and not the USB port if there is any. check the ip address of the pc connected to the modem and make sure that the DEFAULT GATEWAY is not the same as 192.168.1.1. if the address is the same you have to change the linksys router ip address from 192.168.1.1 to 192.168.2.1.
set the internet connection type of the linksys to obtain an ip. then save it.
switch off the linksys router then connect the modem to the WAN / INTERNET port. Plug the power adapter back in then wait for the lights to be stable. please note that the power light must be solid green. if it's blinking it's bye-bye to the router.
lastly check the internet if it's working.
May 24, 2008 | Linksys BEFW11S4 Wireless-B Broadband...
Remote access to my work desktop
Your modem is what connects you to the internet, your Mac airport is a router...One of the quirks about Apple's AirPort Base Stations is that they are routers, but not modems. As a quick refresher: a router enables you to create a network that connects various devices together (Macs, iPhones, iPads, hard drives, printers and so on); whereas a modem connects your network to the wider internet.
Feb 05, 2018 | Broadxent Computers & Internet
Computers & Internet Logo
128 people viewed this question
Top Broadxent Computers & Internet Experts
David Payne
David Payne
Are you a Broadxent Computer and Internet Expert? Answer questions, earn points and help others
