Question about Sharp Actius A250 Notebook
Sharp Actius A250 PC: Can the screen be replaced?
Just wondering if the screen can be replaced... It doesn't light up at all. Otherwise the computer still works fine. It may be something on the board but I'm not sure what to check.
Thanks
  • Actius user May 23, 2008
    An external monitor works so I'll track down parts. I tried finding a replacement LCD screen, but no one seems to have the replacement for the Actius A-250. Any suggestions?
    Problem Solver:
  • 5 Answers
I'm a laptop technician and this is a very common fault. It sounds like the backlight or invertor for the laptop screen has failed.
The easy way to check this is to plug the laptop into a normal PC monitor (if you can) via the monitor out port on the laptop - you may have to press Ctrl + F5 to get a display on the PC screen. If you can get the laptop to show an image on the PC screen then the main laptop itself is fine, and the problem is almost certainly a failed invertor or backlight.
Assuming you *could* see an image on the PC screen, you should then press Ctrl + F5 so that you *can't* see an image on the PC screen any more (this is very important). Next unplug the laptop from the PC monitor (if you did the above) and look VERY closely at the laptop screen. You will hopefully *just* make out a very, very feint and very dark image on the laptop screen. Bear in mind that you may need to re-boot the laptop to get a moving image that you can detect (like the Windows boot up screen for example). If you *can* see a very, very dark and feint image on the screen then the backlight has failed. If the screen is plain bright white or there is no image then the invertor has gone.
The invertor is a smaller circuit board that sits in the screen housing, the backlight is a very thin "flourescent" kind of tube light that is built into the screen itself. The invertor can be removed and replaced pretty easily by most competent people without much trouble (takes maybe 30-45 minutes to do). The backlight on the other hand is very hard to remove without damaging the screen itself and should only be attempted by a specialist laptop repair company.
I hope this helps.
Posted on Jan 04, 2009
  • 100 Answers
First plug an external monitor and toggle the screen with ALT+F5 to make sure the rest of the hardware is working. If the image in the external monitor is Ok you probably have a hardware problem in the inverter or the LCD screen.
You can get the replacement parts here, and change it yourself:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ObjectPath=/Shops/demo132390/Products/%22Pantallas%20portatil%22
Posted on May 23, 2008
  • Hello. There is not a specific screen for the Actius A250. Sharp uses the same screens in most of their laptops. We just have to find out what is the part number. Just post the part number printed at the back of the screen. I'll try to find that screen or a compatible model.
    Regards,
    Ignacio del Olmo
    comercial@piezas.biz
I forgot the password on my sharp actius av18. how do i bypass the password screen and get to the windows screen?
The only way to get that fixed is to call Sharp, and they will assist you in doing a full restore of the computer, what info you had will be lost during this process,
Feb 06, 2013 | Sharp Actius AV18 Notebook
HOw do you remove the HDD
to put it in easy terms all computers are constructed in a module way using plug-in connectors for each pheripheral item,or ribbon cable etc.
When it comes to laptops this is the case also but bear in mind space is limited so things have to be compact and fit flush etc,
get yourself a fine screwdriver set and see if indeed your pc is user-serviceable
Sep 13, 2010 | Sharp Actius A250 Notebook
Need a user manual
You can purchase a manual from this WEB site.
Use this link.
http://www.9manuals.com/?gclid=CMP1ibvsmpsCFSRPagodggNUpQ
Jun 14, 2009 | Sharp Actius A250 Notebook
Ram type for Sharp Actius Pc-RD 10 notebook
My Frenn Don't Bother Yourself, Issues With Your Laptops Doesn't Worth That. Use The Link Below For Your Laptop's Specifications..
http://laptops.alege.net/comments/5893/
You Need To Contact Manufacturer Of The PC To Buy The Parts ..
May 23, 2009 | Sharp Actius RD10 Notebook
Where can I find the AC input on the A250- what sign?
Look underneath the brick of the AC adapter/Power adapter. You should be able to find it there?
Should say Input. Normally 110-230V.
Feb 08, 2009 | Sharp Actius A250 Notebook
I lost my ac adapter for Sharp Actius A250 PC Notebook
office depot / neighborhood computer stores /mite try ebay or just typeing in search engine for sharp actuis cheap power cord ...lala linda
Jun 05, 2008 | Sharp Actius A250 Notebook
Dsound.dll
It means that ur sound drivers are corrupted and u need to reinstall ur drivers again
Mar 11, 2008 | Sharp Actius A250 Notebook
Hard drive
Open your machine, check if the hdd is SATA of PATA (with pin). From here you can buy hdd that supported by your machine
Feb 01, 2008 | Sharp Actius A250 Notebook
Sharp Actius A250 Notebook Logo
144 people viewed this question
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Ricky Ostrom
Ricky Ostrom
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
