My tower won't turn on. I checked and it is plugeged in to a working outlet... the screen light is on and even one light on the tower is on -- but when I press the on button NOTHING happens.
  • jenstylesrn Apr 26, 2009
    yeah, same problem. My husband has been using the hp pavilion a700n and as soon as i brought it home to my house, i plug in a power cord and it won't turn on. the green light in the back turns on, but no fan, no other lights or sounds, and the power button on the front acts as though i didn't even push it at all. No response there. could there be a secret turn off swith that he could have activiated to prevent me from using it? i have used different power cords that fit well, could it be that i need the exact same power cord that it came with? or will any cord suffice as long as it fits
  • 36 Answers
Hi ,
you can try this solution
unplug all cables , powerflee the system by pressing the start button for 30 sec , release it then replugg all the cables and check wheather it is working or not , secondly check wheather the powers supply fan on the back of tower is working or not, still it doesnt work turn off the tower and unplugg the tower and then openthe tower , check all cables and reset the RAM on the mother board ...you can try this basic troubleshooting , it will help u... waiting for response
Posted on May 20, 2008
I have a 55" Panasonic flat screen that won't turn
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Sep 29, 2013 | Televison & Video
Philips GC 2510 won't light up or heat up
If the iron doesn't heat, make sure power is on to the outlet,,test the outlet with desk lamp for to see if working. check the electrical cord, and check the thermostat + fuse inside replace if necessary.
Jan 25, 2013 | Philips GC 2510 Iron
My monitor no display and light is blinking
if the monitor light is blinking this suggests that, there is no display signal coming from the tower. This could be because of the following .
1. Bad video card 2. Bad video software
To check,where the problem is , power of the system tower and remove the power cord from the back of the tower. Press and hold the power buttoon for 10 seconds and the reconnect the power cord and turn the tower on. Check if there is any display or the status of the light changes from amber to green for even a small instance.
If the light changes to green and back to amber the video port on the tower is bad
Alternatively you can connect the monitor to another desktop or laptop to check if the same is working correctly.
Thanks for using fixya
Proton
Oct 13, 2012 | Computers & Internet
Siemens xlm1600 drum doesn't turn - motor running - full load of wet washing. Inlet/outlet checked and cleaned - ok. Won't even turn when empty. Whats up?
something jammed between outer drum and inner drum or bearings jammed, if any off these then belt will be burnt Re: Jeff
Apr 12, 2012 | Siemens Washing Machines
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
Sylvania 730SVD flat screen with built in dvd... Can't eject dvd inside and when turned on the digital words show up and keep flashing black gray green red... The remote won't even work..
Try resetting the TV by disconnecting it from the mains outlet for 1/2 hour, then connect to the main outlet and switch on the TV.
Feb 03, 2012 | Televison & Video
Daughter's TV was on during bad electrical storm. Screen went black and made high pitched sound. cable, internet and telephones all digital through Time Warner Cable. Now TV will not even turn on;...
Ur Main Fuses in the circuits breaker box must be to be restart it back.Turn off/on all the fuses on the main circuits breaker box to all the fuses in the box of the box to restart.All ur electical power outlets should work again.If not those power plug in outlets are shorted and dead must have to be replaced.
Aug 22, 2011 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Plugged it in to a wall outlet, turned on the computer, the microsoft screen scene appeared, the jingle played, then it turned itself off and won't turn back on.
Unassemble the battery and after 5 minutes reassemble it, then plug it in another wall outlet and when the charging light turn on, turn on the notebook.
Jul 21, 2011 | Dell Lattitude D610
Tower won't turn on
Brandi,
Please check the following:
1. Make sure the the surge protector is securely plugged into the wall. Test this by plugging in a light / lamp to it, to make sure it's working.
2. Make sure that the surge protector is turned on.
3. Check to make sure that the power cable from the computer to the power surge protector is securely plugged in.
4. Check to see if the computer will power on now.
5. If this still isn't working, remove the power strip/surge protector and connect the computer directly to the wall.
6. If this STILL isn't working, try plugging your computer into a different outlet in the house to see if the outlet in your home might be bad.
6. If your computer STILL isn't powering on then I'm afraid the worse has happened, which is one of the following issues:
1. Bad power supply (they are cheap, around $20-40)
2. Bad motherboard (they are sort of pricey, around $50-200)
3. Bad CMOS battery (they are cheap, around $5-10)
I can fix all of the above and order parts for all of the above, if you are in need of parts.
I hope this troubleshooting guide helps you! If this resolves your issues, please mark this question as resolved and select my answer. This will assure customers that I can help them with their issues.
Thank you,
Larry Braziel
May 12, 2009 | HP Computers & Internet
Computers & Internet Logo
2,771 people viewed this question
David Payne
David Payne
