Question about Microsoft Windows XP Home Edition
Only able to view 4 bit colour
16 bit high colour not available since system failure.
All pictures are barely visible.
Can't access video footage.(Trying to access such data closes down internet suggesting there is an error)
    Problem Solver:
  • 6 Answers
Install the video driver.This driver could be available in your motherboard cd.
Posted on May 20, 2008
Why there is 1024 bites in 1kilo bite... ?
because it is derived from binary base system and the data in the memory chip is either 0 or 1 for each bit. The memory is actually bytes this depends on the data bus used 8 bits = 1 byte on an 8 bit data bus. 16 bits - 1 byte on a 16 bit memory data bus.
each lot of bits being bytes sits at an address. So 1 kilo byte of memory is stored in 1024 memory addresses. this uses 10 address lines. If you add one more address line 2^11 you get 2048 memory stores . As the 11 th bit can be 1 or 0 but allows access to another 1024 memory addresses.
  • 2 ^0 =1
  • 2^1 =2
  • 2^2 = 4
  • 2^3 = 8
  • 2^4 = 16
  • 2^5 =32
  • 2^6 = 64
  • 2^7 =128
  • 2^8 =256
  • 2^9 =512
  • 2^10 = 1024 = 1 kb
Feb 17, 2016 | Cars & Trucks
Lost footage trying to get it back
You can try to recover your recoding with the help of data recovery application. Download one such application from http://www.fileundelete.org/ and recover all your deleted or lost data.
Mar 12, 2013 | Sony Handycam Video Cameras
Toshiba 7140CT laptop only recognizes 65000 kb of new 250gb hdd when started with FDisk
An nice old machine!
If I recall correctly, FDISK low level formats partitions and I don't think the new hard drive will accept it without struggling. The bios on the mother board will not accept a drive as large as 250Gb as they didn't exist when the Bios was made.
Try partitioning as you require and format either FAT16 or FAT32 with another machine and see if it will accept it. I think the Bios was restricted to 6Gb drives so you may need to set up a lot of partitions!
Hope this helps.
Processor
Mobile Intel® Pentium® III processor, 500 MHz, 256 KB 2nd level cache, 100 MHz Front Side Bus Memory
Standard 64 MB SDRAM, expandable to 320 MB Hard disk
6.0 GB1) capacity, S.M.A.R.T. hard disk Internal video modes
1,024 x 768 x 16.7 million colours Display
13.3" (33.8 cm) TFT active matrix colour display Battery
Removable lithium-ion battery, 2-3 hrs battery life, with extra high capacity battery up to 5 hrs Size and Weight
Diskette drive
External: 3.5" 1.44 MB/720 KB
DVD-ROM drive2)
6-speed (max) with optional DVD Network Dock II, 12 cm (5.25") and 8 cm (3.5") disks, data transfer 3,600 KB/sec, average access time: 140 ms
Graphics adaptor
128-bit graphics accelerator, SVGA-/VGA compatible, AGP bus, 64-bit BiTBlT, 4 MB internal Video RAM
External video modes
640 x 480 x 16.7 million colours,
800 x 600 x 16.7 million colours,
1,024 x 768 x 16.7 million colours,
1,280 x 1,024 x 65,536 colours,
1,600 x 1,200 x 65,536 colours
Up to 85 Hz refresh rate
Keyboard
86 keys, 12 function keys, 8 dedicated cursor keys, inlaid numeric keypad, 8 Hot Keys, 2 Windows® keys, AccuPoint™ II, Euro key
Sound System
16-bit stereo Sound Blaster Pro compatible, 3D-wide mode, MIDI & Wavetable synthesis, volume dial, built-in speaker and microphone
BIOS
ACPI (1.0b) enabled BIOS, SM BIOS V. 2.3
Expansion
2 x PC Card Type II or
1 x PC Card Type III,
CardBus support, memory expansion
Communication
Integrated international V.90 modem (56 Kbps data, 14.4 Kbps fax)
Interfaces
FDD connector, external monitor, USB, Fast Infrared Port, RJ 11 modem jack, headphone, external microphone, slot for Kensington Cable Lock
With I/O Adaptor:
serial, parallel, PS/2™ mouse and keyboard
With Docking Station (DVD Network Dock II):
serial, parallel, external monitor, PS/2™ mouse and keyboard, video out (NTSC/PAL), line-in, line-out, integrated FDD, includes built-in Ethernet (Wake-On-LAN and Service Boot support), 6-speed DVD-ROM drive
Power supply
Autosensing 100-240 V AC adaptor for world-wide usage
Casework
Magnesium alloy
Bundled software
Windows® 95 and Windows® 98 selectable installation, Windows® NT 4.0 on request (limited language versions available), PC Card management software, Toshiba utilities and drivers (all preinstalled on the hard disk)
Bundled hardware
External diskette drive, autosensing AC adaptor, I/O adaptor
Special features
Toshiba Hibernation and Resume, Toshiba Power Extensions, System Password Securities, HDD password on request, SecureSleep™, LANDesk Client Manager (LDCM), Wake-On-LAN and Service Boot support (with manageability software and LAN chip), Recovery CD, 3-year international warranty
Options
DVD Network Dock II, carrying case, extra high capacity battery, battery charger, 32, 64, 128 and 256 MB memory modules
Jan 23, 2011 | Toshiba Portege 7140CT Notebook
Toshiba Portege 7200 i try to fomat it it does no format why
Windows won't as a rule allow format of an older system onto a newer system, it goes into protect mode.
If you are trying to format the laptop with say XP and you have XP with SP3 installed, because SP3 is newer than XP it will try to stop you from destroying the newer system. Matbe you are running out of space?
Processor
Mobile Intel® Pentium® III processor at 600 MHz featuring Intel® SpeedStep™ technology, 256 KB 2nd level cache, 100 MHz Front Side Bus
Memory
Hard disk
12.0 GB1) capacity, S.M.A.R.T. hard disk
Battery
Size and Weight
297 x 241 x 25 mm, 2 kg
Diskette drive
DVD-ROM drive2)
Graphics adaptor
Keyboard
Sound System
BIOS
Expansion
1 x PC Card Type III, CardBus support, memory expansion slots
Communication
Interfaces
FDD connector, external monitor, USB, Fast Infrared Port, I/O adaptor connector, RJ 11 modem jack, headphone, external microphone, slot for Kensington Cable Lock
With I/O Adaptor:
Power supply
Casework
Magnesium alloy
Bundled software
Windows® 95 and Windows® 98 selectable installation, Windows® NT 4.0 on request (limited language versions available), PC Card management software, Toshiba utilities and drivers (all pre-installed on the hard disk)
Bundled hardware
Special features
Options
Dec 31, 2010 | Toshiba Portege 7200CT Notebook
Picture won't show up for nancy drew message in a haunted mansion
these are the min. specs for the game>
System Requirements:
  • Windows 95, 98, ME, 2000, XP
  • 166 MHz Processor
  • 16 MB RAM
  • 200 MB available hard disk space
  • 16 Bit color graphics video card that's compatible with direct X 6 or higher.
  • 8x CD-ROM drive
  • 16 Bit compatible sound card
  • A pointing device and speakers
Platform: WINDOWS 95/98/ME/XP
Oct 06, 2009 | Computers & Internet
Hi We had a power failure once and since then whenever we watch movies the picture is in black and white. Can anyone help to restore the colour picture. We have asked some people who experienced the same...
You must set your player's video system to your TV's video system. Go to menu>setup>video. Under video you can select either NTSC, PAL or the likes or simply select AUTO if available.
Sep 24, 2009 | Televison & Video
I accidentally deleted a video
you may get software to try and look for the deleted files (if they were actually written to the SD in the first place) the data in files are usually not deleted until something write over the data. its only marked as free space.
but if it is lost. dont be upset. you will end up with many many hours of videos and pictures of your child :) one single lost xmas video will mean nothing in the long run
How to recover deleted files
Jul 05, 2017 | Vivitar VIVICAM 5188 PINK BNIB Digital...
Panasonic pv gs83
Make sure you have no programs running in the background when your rendering. Make sure your hard drive is defragged. That makes a big difference.
Jun 21, 2008 | Panasonic NV-DS29B Mini DV Digital...
Won't install
it sounds like you are either trying to install a 16 bit program on a 32 bit system, or installing on a very old system with a 16 bit system.
don't work.
cheers
Terry
Mar 20, 2008 | Computers & Internet
Playing back footage on pc
don't know u're cam, but usualy the camera haz to "close" the dvd sesion, so that the computer/dvd player .... to be able to play it ...
Ofecourse u can play the video on PC, using cd/dvd data recovery software, that accesses the data directly and not track based ... (that in the case that the dvd got damaged and the recorder can't finish it ...)
Feb 17, 2008 | Video Cameras
Microsoft Windows XP Home Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
