Question about E-Machines 6809 Notebook
Wireless LAN connection indicator
The indicator has a red cross through it, i can't get connected to the internet, Have i turned off the wireless adapter somehow? How do i get it working again?
  • peter_church Aug 04, 2008
    Yes! same problem and cannot find a way to fix it. computer works through direct lan connection but will suddenly not pick up any wifi signals. the pc is a packard bell which was working fine on home wifi from orange live box then suddenly cannot find a signal - usually picks up more than one. the wireless lan connection is crossed out. checked the ralink wireless status is on and supposedly working properly tried the normal repair but says it cannt see anything to connect to. Another computer can see the wireless signal. suspect it happened after putting the pc in standby??
    Peter
Same problem
Posted on Nov 20, 2008
    Problem Solver:
  • 19 Answers
Try this:
Right click on your wireless icon in the tray.
Left click on "repair". If there's nothing wrong with it, it won't hurt it. If it's gone stupid, it may fix it.
Left click on "status". This will tell you if your wireless actually has a connection. Without knowing the rest of your setup that's about as far as I can go for now. Good luck.
Posted on May 21, 2008
I had the exact same problem and native_babyg solution was spot on, thank you
Posted on Jun 07, 2010
Press fn and f1 to activate wireless switch, this should cure your problem
Posted on Oct 03, 2008
    Problem Solver:
  • 5 Answers
 don't follow you on "without plugging a usb" so I'm going to give you someadvice, if I'm wring or have the wrong machine, please correct me, before you rate me.
I believe this machine has a built in wireless card. If so, then you need to follow the link below and download the wireless drivers for it. If the wireless drivers are already there, then you need to uninstall them and reboot the machine. The machine will find the wireless card and reinstall the drivers automatically. Many time this type of problem is a driver glitch, and this procedure will fix it. If it doesn't have an internal wireless card installed in it, it does have the slot and you can purchase one to go in it. Here's the link for the Inspiron B130 wireless drivers. You'll find the wireless drivers in the network section, and you may have to try more than one if you don't know the make and model of the wireless card.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INSPIRON1300/B130&os=WW1&osl=en&catid=&impid=
Posted on Sep 07, 2008
Notebook won't connect wifi
Hi, assuming your laptop is switched on.
Above the keyboard on the right side are the three 'Easy buttons'. The one on the left is for the wireless function.
Push this button to activate or deactivate the Wireless LAN. When you activate the wireless LAN function, it will search for a wireless LAN signal automatically (assuming you have the wireless LAN driver installed). Just below the screen on the right side is the Status LED Panel, which show six icons, each with its own LED. The first one on the left indicates Wireless LAN status. When the LED is displaying a green light, it indicates that the system is accessing data from, or retrieving data by wireless LAN. So whenever you press the Easy button, you should see the green status light come on or go off. To repeat, if the light is not on, you need to press the Wireless LAN 'Easy Button'. NOTE! If you can't get the button to come on, you will need to re-install the Wireless LAN driver.
Jan 16, 2014 | Averatec 5110H Notebook
How do i connect my wireless d-link to my internet?
Using a LAN cable connect the router to your internet modem. Usually use LAN port 1 on each unless indicated otherwise.
Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
The using the setup wizard, configure your WAN according to the requirements of you modem PPPoE, Dynamic, etc. In some case the router will sense the correct set-up.
Feb 07, 2011 | D-Link DIR601 WirelessN 150 Home Router...
Belkin Surf Network Adapter installed on my desktop connects to my wireless network and looks to be working ie. wireless icon in lower right hand corner is flashing blue with no red cross etc. However, I...
I got your issue , for your issue , I f you want to go online hard wired to the router , make sure the Local are connection in the comp is enabled as well you have coted that u can see red cross in the wireless network connection icon, so make sure do not have any preferred networks in the comp.
Thanks,
Prema
Sep 27, 2010 | Belkin F5D4070 Network Adapter
The wireless internet connection wont work. we previously had a wireless connection and now it wont register. we lost the connection completely and it doesnt show up on the list of internet connections....
Try turning off the router for 30 secs, then power it up again.
Then try connecting a LAN cable from the computer to the router and see if you can connect to the Internet.
If you can connect to the Internet then -
With the LAN cable open a browser and type in the configuration URL and check the Wireless settings, then check and/or the wireless card settings (it should have the router's SSID and encryption settings etc.)
Also install the latest wireless card driver.
Then test the wireless and Internet connection. If this doesn't work -
Next connect the computer with a LAN cable to the cable or DSL modem to see if you can connect to the Internet.
If you cannot get an Internet connection with the LAN cable, contact your ISP and get them to test the connection to your modem.
If the modem and Internet is OK and you still cannot get a wireless connection then the problem could be a faulty wireless router.
Dec 25, 2009 | Dell TrueMobile 2300 Wireless Router...
I have a cisco linksys wrt54g2 v1 that I have hooked up to my verizon dsl modem. My computer says I am connected but it wont let me get on the internet. If I plug the ethernet cable from the modem to my...
Connect the cable from the LAN port on the DSL modem to any of the 4- LAN ports on the Linksys Swicth (not the port Labelled Internet), then from any of the remaining 4 ports then connect your computer. Also try using a cross-over cable to modem from the DSL LAN port to the Linksys.
Oct 24, 2009 | Linksys Wireless-G WRT54G Router
Trying to connect a wired network wirelessly to a router
No. You'll need to run a "cross-over" Ethernet cable from one of the "LAN" ports on the "downstairs" router, connecting to the "WAN" port on another router that you will need to buy, and place "upstairs", and connect the 4 devices to the 4 "LAN" ports.
Or, run a long "straight-through" Ethernet cable from your DSL-modem (or cable-modem) that is "downstairs", and move your wireless router "upstairs", and connect the 4 devices to the router's "LAN" ports.
Your laptop "downstairs" should still be able to connect (wirelessly) to the wireless-router that is "upstairs".
Sep 16, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Cant connect wired to my router modem? it works via wireless
Do you know for sure that:
A) The cable you are using is correct? Have you used it elsewhere?
B) Is the network connection enabled? Goto Start, Network Connections and look at the status of the connection. It may just be disabled or miss-configured.
Apr 09, 2009 | Belkin (F5D7230-4) Router (587009)
INternet connection
install drivers for lan card
open run cmd
ipconfig/all
it will show u ur ip adress
then ping to gateway
Jan 27, 2009 | Dell Ethernet Card Network Adapter
Using 2 routers
You may use your wireless router as an Access Point:
1. Connect one of the LAN port of the Belkin to a LAN port on your Voyager. If the link light on both side are not coming on, try using a cross-over cable. Important: Do not connect anything to the WAN port of your Belkin.
2. Configure the LAN IP address of your Belkin in the same subnet as the Voyager. By example, if your Voyager has 192.168.0.1, you may give your Belkin 192.168.0.3.
3. Disable the DHCP server on the Belkin since the Voyager most likely already has one.
4. Configure the Wireless parameter of your Belkin as you would normaly do.
Using this method, your wired and wireless devices will be able to communicate together since they will be on the same network and your Belkin will act as a bridge between the wired and wireless network.
Apr 20, 2008 | Belkin (F5D7231-4) Wireless Router
Packard Bell Easynote E4 - Wireless Switch
i've been having the exact same yrouble with my Easynote E4 laptop and have just fixed it.
in the bottom left hand corner of the keyboard theres a key with Fn written in blue, hold this down and press F1it should beep and the 'wireless lan connection indicator' in your system tray the red cross will disipear then you will pick up wireless!
Apr 02, 2008 | Computers & Internet
E-Machines 6809 Notebook Logo
1,966 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
