Yahoo messenger not signing in
Yahoo messenger (version 8) not signing in when the pc (windows xp pro) is part of the local network, the internet is working. When i disconnect the pc from the local network (pull out the network cable) and connect to the internet with a vodafone 3g card and then sign in the yahoo messenger it works.
  • Anonymous Apr 19, 2009
    i am getting problem signing in yahoo msngr. it simply gives me error that yahoo can't sign in try again later.
    any solution??????
    President:
  • 2,291 Answers
Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences."
2. Enable the "No network detection" option and then click the "OK" button at the bottom of the window.
3. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button.
4. Enter your Yahoo! ID and password and click the "Sign In" button.
you may have a registry problem download registry cleaner reg in out to fix the issue
Posted on Oct 07, 2010
I cannot open my Yahoo messenger after I download Window Internet Explorer 8
Do you have the latest release of Yahoo messenger? I think the easiest thing to do here is just do a system restore to the a day previous to this problem, this will restore the earlier version of Internet Explorer which is stored in the system restore files on a separate section of the Hardrive.
Here is the way you do a "System Restore" on windows XP and 7. You will find two links to sites that explain the procedure in depth. 1st is XP then Windows 7.
http://support.microsoft.com/kb/306084
http://www.sevenforums.com/tutorials/700-system-restore.html
Feb 25, 2011 | Yahoo Messenger
We have yahoo messenger 8 we cant get signed into it
If you have tried restarting your computer, signing in with your Yahoo e-mail prefix (without the @yahoo.com) and your e-mail password without sucess, and you are sure your caps aren't locked and your information is correct, Yahoo Messenger Help suggests the following:
Copied and pasted from Yahoo Messenger Help:
Why can't I connect with Yahoo! Messenger?
No go, eh? We're sorry to hear you're having problems connecting to our servers. Your Yahoo! Messenger connection information may be incorrect. Follow these steps to configure your connection:
Click the Messenger menu in Yahoo! Messenger and select "Connection Preferences."
Enable the "Firewall with no proxies" option.
Select the correct Internet connection type and country from the pull-down menus.
Click the OK button at the bottom of the window.
Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the OK button.
The above configuration works in most situations. (However, if you connect in this way, you won't be able to use the Voice feature.) If this configuration doesn't work, follow these steps:
Enable the "No network detection" option and then click the OK button at the bottom of the window.
If neither of the above options work (sorry), you're probably behind a firewall or proxy server that requires you to enter its address. Follow these steps:
Enable the "Use proxies" option.
Enter your firewall or proxy server's address and port number. Contact your network administrator (if you're at work), or your Internet service provider (if you're at home) to determine the correct firewall and proxy settings.
Yahoo! Messenger will ask you if you want to sign in with your new proxy settings. Click the OK button.
Nov 05, 2010 | Yahoo Messenger
Sir my yahoo messeng cant sign in plz slove this problem
You just can't sign in easily and or it will take you some time before a successfully log in to yahoo messenger if the version of Internet Explorer that comes with your windows operating system did not meet that recommended compatibility with the version of your yahoo messenger.
The best suggestion to solve this problem... is to upgrade the version of your Internet Explorer to version 8 (it's the latest). It doesn't matter if your using other web browser like Mozilla, just upgrade Internet Explorer.
Then unistall your yahoo messenger and install its latest version too, Yahoo Messenger 10.
To get to download these needed software, just visit this helpful tip in solving Can't Sign Problem With Yahoo Messenger
Jul 24, 2010 | Yahoo Messenger
I cannot sign in
If you wanted to sign in with your Yahoo Messenger in just a second you will need to improve its connection.
The easiest way for you to establish a good connection is to upgrade your Windows Internet Explorer. In case you didn't know Yahoo Messenger rely its connection from Internet Explorer.
The best suggestion to improve the connection of your Yahoo Messenger is to upgrade the Internet Explorer of your computer. Compatible to the system software you are currently using. (Example if your operating system is windows vista, Install Internet Explorer 8 for Windows Vista)
After you upgrade your Internet Explorer, uninstall the yahoo messenger on your computer and then reinstall again. After doing this, restart your computer and try to log in. You will surely see the difference.
These are the link files that you will need to upgrade.
Click it to save.
1. Internet Explorer8 (winXP, winXP-64, winVista, winVista-64) - select your operating system and download IE8
2. Yahoo Messenger 10 - download and install this after you remove previous version of yahoo messenger on your computer
(Note: if you are using different web browser, It doesn't matter. Install Internet Explorer 8 and just don't default it as your web browser)
There is also a helpful tip on how to solve Yahoo Messenger Trouble Connecting issues.
Visit this link http://www.fixya.com/support/r5025589-easiest_way_solve_yahoo_messenger
Try this one. you will surely like the outcome.
Please comeback and give me some ratings if your connection is establish.
Jul 22, 2010 | Yahoo Messenger
Just set up an account last week and now I cant sign on
What you are experiencing is trouble connecting issues with Yahoo Messenger. It is easy to set up an account with yahoo messenger and it will let you sign in for a few days but if the Windows Internet Explorer installed in your computer is outdated then after a few days it will be impossible for you to sign in at Yahoo messenger.
The connection of Yahoo Messenger rely on the Internet Explorer of Windows. The best solution for your problem is to upgrade Internet Explorer with a newer version. The best to suggest is Internet Explorer version 8. It doesn't matter if you are using a different web browser. Just install Internet Explorer 8 and do not default it as your browser if you are using other web browser as your default.
After installing IE 8, the next thing to do is uninstall and reinstall your Yahoo Messenger. It will be better if you install YM version 10. After you have completely install it, restart your computer and sign-in in just a second. It will surely works.
Refer to the solutions I gave to another asker who have the same problem like yours, and my solution worked for him. Visit this link http://www.fixya.com/support/t5031693-yahoo_messenger_not_working
Let me know when you can now sign-in in a just seconds. Come back and give me some ratings.
Please visit also this helpful tips on how to solve trouble connecting issues of Yahoo Messenger for non computer experts and rate this also.
Thank You for using Fixya!
Jun 07, 2010 | Yahoo Messenger
Yahoo messenger automatically shut down
Please upgrade first the version of your Windows Internet Explorer. The connection of Yahoo Messenger rely on Internet Explorer.
If you are using different web browser like Mozilla Firefox, It doesn't matter. Just install Internet Explorer 8 compatible with your operating system and do not default it as your browser.
Do this and you will find it easy to access your yahoo Messenger in just a second.
Here is the link for downloading Internet Explorer version 8. Select the operating system you are currently use.http://www.microsoft.com/windows/internet-explorer/worldwide-sites.aspx
After installing the IE8 and Yahoo Messenger 10, restart your computer.
Please comeback after establishing your Yahoo Messenger connection and give me some rating.
Thank You for using Fixya.
Jun 05, 2010 | Yahoo Messenger
Cannot sign in yahoo
pleasw check your user name and password
Dec 24, 2009 | Yahoo Messenger
Unable to download files needed 4 installation
Go to Start>Control Panel > Add or remove programs remove all the things related yahoo ( Yahoo toolbar, Yahoo mail advisor, Yahoo installer, Yahoo browser plus etc.) Try download and install then....If still same try download offline installer http://download.yimg.com/ycs/msg/dl/msgr10/us/b4/msgr10us.exe
if still you are having difficulty download old version like Yahoo messenger 8 or Yahoo messenger 7
I think it will help you..Further result please let us know... Thanks for being with Fixya...Good Luck
Nov 10, 2009 | Yahoo Messenger
Cant sign in to yahoo messenger
I believe this problem is caused by a proxy error.  Does Internet Explorer connect to the Internet OK? Do you or your network provider use a proxy? Or a local proxy program such as Privoxy? If no, make sure that Yahoo is set to connect "Firewall with no proxies".  If yes, set Yahoo Messenger to use HTTP proxies.
Nov 12, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
1,149 people viewed this question
David Payne
David Payne
