Question about Maytag Neptune MAH5500B Front Load Washer
LR MAYTAG WASHER
THE FUSE IS BUNED IN THE CONTROL PANEL. WHAT TO I NEED?
  • 975 Answers
OPEN BACK PANEL !!
Posted on May 23, 2008
What is the wiring and winding?
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak Maytag Neptune washer motor/motor control circuit board ...much this is very helpful, my machine is coming up with a "Lr"code which I believe .
Aug 20, 2015 | Maytag Neptune Washing Machines
My Maytag washer will not complete a cycle. The code Lr is display on the front of the washer. I have pulled the plug and reset the breaker.
Hi.
LR stands for locked rotor. The code is returned by the Motor Control Unit (an electronic module connected to the motor and to central control unit). The code is returned when no motion from motor rotor is detected. With many models LR may be due to a factory defect. Please call Maytag and check if any recall has been issued for error LR concerning your washer model. If recall has been issued you will get a kit comprising a new motor and wiring harness.
You can also try temporarily resetting the error by disconnecting power at circuit breaker (or unplugging power cord). If the error message is prompted again call Maytag.
Regards.
Ginko
Aug 08, 2011 | Maytag Washing Machines
I have Maytag Neptune front loader washer. When
Hi.
Error LR means Locked Rotor.
Either the motor is faulty, there is a wiring problem, or the control assembly is faulty.
Try tripping the circuit breaker to reset the machine, if code comes back a technician must have a look at the motor.
Jun 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
LR CODE ON A NEPTUNE 55OOBWW WASHER
Hello there:
The LR error on your non-spinning Maytag Neptune is usually, thoughnot always, accompanied either by a burn spot or a blown fuse on theMotor Control Board.
Burn Spot on a Maytag Neptune Washer Motor Control Board (click to enlarge)
Blown Fuse on a Maytag Neptune Washer Motor Control Board (click to enlarge)Either way, it means just one thing: a new motor and motor control board kit are in your future.
Hop this is very helpful for you
Best regards Michael
Dec 29, 2009 | Maytag Washing Machines
Neptune - has Lr displayed where time remaining for wash usually displays. Doesn't finish.
Hello there
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Blown Fuse on a Maytag Neptune Washer Motor Control Board (click to enlarge) Either way, it means just one thang: a new motor and motor control board kit are in your future.
Dec 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Code lr ?
hate to interject
but lr stands for locked rotor
your motor control has blown a fuse or heat sync.
you can verify this by removing the door and front panel,
the motor control is on the bottom right front
inspect this board with a flashlight
im almost sure you will find some sort of burning
if you do and would like to repair the unit im including a link
that will show you the part you will need
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47812
make sure you oder the part that comes with a new motor is actually cheaper AP4010145
Oct 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Display error code of Lr on control panel
L means "Lid or Door Lock" problem
r probably means 'release' I couldn't find it anywhere... so I'd guess that Lr means the machine did not detect that the Lid Lock released and cycle end (which means either the sensor is bad or the Lid Lock dosen't lock the Lid).
Either way, something with the Lid Lock system ais not right. Be glad it releases ;-)
Mar 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
What does error code Lr mean and how do I fix it?
http://www.bobvila.com/wwwboard/messages/155863.html
says:
just an FYI to anyone who might need to know. my neptune started kicking up an error of LR and stopping. i ended up sending an email to maytag and got a response back from one of their techs. the LR code means "Locked Rotor". when this happens the cause is one of two items. 1) the circuit board at the top of the unit has lost connection to the motor and its control board at the bottom (connector loose) or 2) the motor and or control board at the bottom have trashed and need to be replaced (P/N 12002039).
hope the info helps someone as i had a heck of a time finding it.
Dec 21, 2008 | Maytag Neptune Washer
Washer machine maytag neptune front load
take the back panel off,see if the belt has broke if not,check your motor control board for burn spots ,front bottom right inside washer,if not that then your motor has gotten weak and will not turn the drum,let me knoe what you find-mike
Jul 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
