Question about Dell Axim X50 Pocket PC
Dell Axim X50 won't boot
When I turn the device on it starts to go through the normal boot screen but when the bar almost reaches 100% it locks up and just sits there. Is there a way of re-imaging the entire phone or a way to get this back running?
  • 3 more comments
  • Anonymous May 23, 2008
    exactly same problem, I even did a hard reset and same thing.
  • Rob McGowan
    Rob McGowan May 23, 2008
    I left it up for a couple of hours and it never booted.. :( It gets to about %80 and just sits there...
  • Rob McGowan
    I actually left it up at the boot screen for more than 3 hours one day here at work. It gets stuck at about %80 and just sits there...
  • dsharp667 Sep 10, 2008
    Dell Axim X50 locked-up (non responsive) on Home screen. I did a hard boot. The device shut down and then starts with the progress bar only going about 40% then stops. I've left it on in the cradle for hours, out of the cradle for hours charged it, rebooted it and still no change. I've been attempting to fix it with boots and watching it for days now.
  • cbalabama Nov 10, 2008
    Same prob for me. After a week of non-use it boots to 80% after a soft or hard reset and will go no further. I let it sit on my desk all day and it never moved.
  • 4 Answers
Well mine did the same and if you wait long enough it will boot maybe giv it at least 15 min. Then upgrade it to prevent it happening again.
Posted on May 23, 2008
I have a touchpad pda that has a bad battery and i lost my password since its a long time since i used it it is a dell axim x50,how do i get the battery and charger since both burst due to an electric...
A "soft" reset clears all open programs and "reboots" the Pocket PC. When the Pocket PC powers back up, you'll start with all active programs closed and the device ready to use. This procedure is intended to reset the Pocket PC if it is malfunctioning or has become bogged down. This reset is also sometimes necessary after software is installed. A soft reset is the Pocket PC equivalent to restarting your Desktop or Laptop. The Dell Axim X50 and X50v can be soft reset by pressing the recessed button on the rear of the unit above the battery. A "hard" reset wipes the RAM and returns the Pocket PC to its factory specs. In effect, the Pocket PC will be just as it was when you purchased it. All data entered, preferences set or software installed (other than ROM updates) on the Pocket PC after purchase will be lost after a hard reset and will have to be transferred or reinstalled via ActiveSync. The Dell Axim X50 Series Pocket PCs can be hard reset by performing the following procedure: With the X50 turned on, press and hold the power button at the top of the unit. While holding the down power button, use the stylus tip to press the "Reset" button mentioned above. Allow the screen to fade to off. Release both buttons. The unit will power back on and display a menu to confirm the hard reset request. The Axim will be hard reset, just as it was when it left the factory hope this helps
May 06, 2011 | Computers & Internet
Can i use my mobile device specifically a Samsung Mythic A897 as a modem on my dell axim x50
Yes you will be able to use it. Use the PC studio which will help you to connect with just couple of steps.
Jan 01, 2010 | Dell Axim X50 Pocket PC
Axim x50, buttons all work, syncs without a problem but sometimes freezes
You might need to hard reset it or update your Dell Axim x50
it is important to know if you have an x50 or a x50v. here are two vids. first one is for x50, x51. second one is for x50v, x51v.
Dell Axim x50, x51
http://www.youtube.com/watch?v=9K2P_SNTuGo
Dell Axim x50v, x51v
http://www.youtube.com/watch?v=vEDvCklrNs0&feature=fvw
Dec 15, 2009 | Dell Axim X50 Pocket PC
Not working with Dell Axim x50
No, the la-4137 is not compatible with the Axim x50 or x50v.
Dec 14, 2008 | Symbol Spectrum24 Wireless Neworker...
Dell Axim x51v
You can get a replacement rechargeable one at batterytrader, here is the link - Dell Axim X51 battery, they also do a couple of extended versions just search on the site, this also fits the dell axim x50 pda batteries
Sep 18, 2008 | Dell Axim X50 Pocket PC
Dell Axim X50 PDA won't turn on
try a hard reset
Dell Axim x50 / x50v / x51 / x51v:
Make sure the device is on before performing hard reset. To hard reset, press and hold the power button and press in on the reset button (reset hole) on the back of the unit for about 2-3 seconds. Release both buttons and you will see a confirmation screen asking you if you would like to clear all data in memory. To do so press the Contacts button. To cancel press the Mail button.
IT may be that the mainboard is faulty and would need to be replaced.
Aug 03, 2008 | Computers & Internet
Had the same problem. Did some research and fixed the problem by performing a "soft reset". Tap the reset indentation on the back once quickly. Do NOT hold it in or you will lose all saved data. Mine's working fine now.
Feb 25, 2008 | Dell Axim X50 Pocket PC
Dell Axim 50 suddenly will not turn on.
Press the power button and the left side record button simultaniously for about 10 seconds. Usually this problem happens when the primary software image cannot be located or is corrupt. Also check to ensure your SD Card is in properly. If that doesn't do the trick upgrade.
Jan 23, 2008 | Dell Axim X50 Pocket PC
Axim 50 will not turn on
I suggest making sure the lock switch on the upper left side of the PDA is not in the lock position. I had this problem and I think that I just bumped it into the lock position. This lock switch prevents any buttons from being a input to the PDA. Hope this helps, Duane.
Oct 25, 2007 | Dell Axim X50 Pocket PC
Axim X50 locked up during boot up process
May have to do a factory reset on your device.
Nov 02, 2017 | Dell Axim X50 Pocket PC
Dell Axim X50 Pocket PC Logo
520 people viewed this question
Alun Cox
