Howling noise from freezer fan, GE side-by-side
Replace the fan, Remove the evaporator cover in the back of freezer, and probably another cover for the fan. Unplug your refer first. Usually their are two screws holding the fan bracket to the wall or mount. disconnect the wires, and replace. Their is a newer model evap fan motor that does not have wiring terminals to disconnect, it is hard wired together and you have to practically remove everything in the freezer compartment to get at it. You have to cut wiring and splice the new fan motor in. Fairly tough job. Usually an evaporator fan motor bearing fails from the refer being moved or in storage for a few days at least with the doors closed and the unit unplugged. This allows all that moisture that was in the freezer to get into the metal parts of the fan motor and cause this problem. To prevent this always block the doors open if your refer is going to be off for a few days. This will allow the unit to dry out without damage. Sometimes it was just a bad motor from the factory. Good Luck, Appliance Specialists
My freezer makes a constant high pitched whinning sound. It works fine and this has been going on a long time. But it get on my nerves. What can I do?
I have the same problem. It sounds like the fan is hitting something, maybe a surround shroud. If you open either the freezer or refrigerator door the fan (and the noise) stop. The noise started out as just once in a while, but now that it is hot outside and the fan runs much more than normal, the noise has become a real nusiance.
It makes a loud whistling sound . the repair guy said it was the compressor fan motor , he put in a new one and it still whistles . Could you please contact him with the answer .
Northwest Service Centre
144 Pitt Avenue
Dryden , Ontario Canada
Phone 807-223-3444
Thanking You In Advance
Mae McArthur
GE Refrigerator GSS22QGPHCC makes a howling noise from the freezing compartment.
