Question about X2Gen MG19MY 19" LCD Monitor
X2 gen monitor
At first the monitor said no input when the computer was on when I unplugged the cord and plugged it back it it now has a box that says burning.... bouncing around the screen like a screen saver while the screen color changes
  • gregnikki May 30, 2008
    Thanks for the help, the computer works when hooked up to another monitor. The x2gen is still doing the burning screensaver thing but wwill now work when attached to the computer, however if it is not connected to anything and when the computer goes to sleep it does the burning box bouncing around the screen.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
This sounds like a straight hardware issue. However, to be certain, try to attach another monitor to this PC, and if it works properly, you will know that there is nothing wrong with the graphics card/driver or other related component of the PC involved. (Also make sure you are using the proper type of cable - analog/digital - for the connection.) Also suggest switching out cables to eliminate that. Further, you could try to see if the monitor functions properly when attached to another machine. If the machine is not functional and another is, that will confirm that the issue is hardware-based.
Unfortunately, X2Gen has declared bankruptcy (see http://x2gen.com/) and there is no way to go back to the manufacturer for either support or warranty service. If you are still within a given time frame with either the retailer, or perhaps through a credit card company, this would be your best recourse. Here is the link to the form via which you could file a bankruptcy claim: http://www.x2gen.com/files/Claim.pdf. Hope this may help, if you can't get reimbursed through some other means.
My experience with this type of issue is that the hardware has gone bad. Particularly with the nature of your problem, it seems that it is not a minor problem, and does not appear to involve drivers or other software-type fixes. If you could get a professional tech to repair it, the cost would most likely be more than replacement of the monitor. Sorry for the bad news, but I don't think there is a better solution.
If the monitor continues to behave in the same manner, I think that is absolute confirmation that you have a "nonnegotiable" hardware issue. If not - in other words, if you see something different with switch of connections/machines, there could be a graphics card/driver or other issue that we could work on further.
Please post back if you need additional assistance, or this does not answer all your questions. Otherwise, thanks for using and rating FixYa!
Posted on May 29, 2008
  • Cheryl Whalen May 30, 2008
    Definitely glad to know that you are working. But since you have lost the ability to pursue your rights for repair/replacement under warranty, I would suggest that you might want to go ahead and file a claim with the bankruptcy trustee.The lnk to the claim form is above - hope all continues to be well!
    smartsolve
Can't get my new monitor to connect with pc
Well, I guess to fix this, UNPLUG the box's power cord for 5 minutes to reset it, plug it back in, wait 3 minutes for the cable/satellite box to reboot, then power up the box...
Oct 02, 2012 | Samsung Computers & Internet
Misplaced my power plug for my X2 Gen monitor. Need to purchase one.
We carry the power cords in stock on our site at: http://www.ccl-la.com/catalog/index.php?cPath=25
Buddy
Corporate Computer
www.ccl-la.com
Apr 16, 2010 | X2Gen MW22U Monitor
Blank screen-HELp!
check the power cord of the monitor and all so the input output cord from monitor to cpu if the fit of the cord is uniform proper because if some of the fit is turn down the monitor is mall function. after you check the same problem that you encounter the monitor has a problem don't not think that you cpu has a problem.. only the monitor..
Mar 02, 2010 | HP Pavilion F1703 17" LCD Monitor
Monitor says no input signal going in sleep mode
TRY UNPLUGGING COMPUTER AND MONITOR AND DISCONNECTING MONITOR FROM THE BACK OF THE COMPUTER. BE SURE TO UNPLUG AND NOT TURN OFF. WAIT ONE MINUTE THEN PLUG COMPUTER BACK IN . RECONNECT MONITOR TO THE BACK OF THE COMPUTER AND PLUG IN. IF THIS WORKS, WAIT FOR NEW HARDWARE RECOGNIZED TO COME ON. FOLLOW INSTRUCTIONS, IF ANY. RESTART COMPUTER.
Feb 08, 2010 | HP vs15 15"LCD Flat Panel Monitor
How do i connect my cable tv to this monitor?
It all depends on what your cable box output is.
This monitor appears to support a standard cable cord input. So in essence all you should have to do is connect a cable cord from your box to your monitor.
Oct 03, 2009 | Samsung SyncMaster 940MW 19" LCD Monitor
How to know if the monitor is totally dead?
Generally, if the power light (LED) doesn't come on and there is no screen display with or without input signal, it's dead. Probably a failed power supply.
Aug 29, 2009 | Samsung SyncMaster 540N 15" LCD Monitor
X2 gen 17" lcd monitor, no display
This indicates either a problem with the monitor cable(ie shorted) or the display adapter. Try plugging the monitor into a different computer and if it works you will need to install a new display adapter in your computer. If it doewn't work on the new one either you can try a different monitor cable if yours isn't permanently connected. Hope this helps
Mar 29, 2009 | X2 MG17R 17" LCD Monitor
No power
Check your power cord very carefully....especially the plug ins (square box)....could be the power supply itself. Regarding fuses; You can't see it inside the computer it is an electronic component. Got to go to store
Feb 27, 2009 | KDS 17S 17" Monitor
Sceptre X7g Monitor Flashing Red & Blue Lights. Blank Screen
i fixed this problem by unplugging the monitor, unplugging the video cables. Then hold down the power button while plugging it back in. Release power button and then press power button for on. It worked then. I got the icon for no signal, i plugged back in my monitors. Sceptre X9W
Sep 11, 2007 | Sceptre X7GNAGAV 17" LCD Monitor
X2Gen MG19MY 19" LCD Monitor Logo
100 people viewed this question
Top X2Gen Computers & Internet Experts
jason
Sandy Moore
Sandy Moore
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
