Question about Frigidaire GLER341A Electric Dryer
Take frigidaire dryer apart to replace bearing
I need to take the top off my frigidaire dryer. There are two screws in the back of the dryer holding L-shaped clamps. I've removed the screws but I can't see how to remove the clamps?
Help, Brent
  • 2 more comments
  • dummyz Jan 04, 2009
    the top of my dryer is burning hot and I have just taken it off, not sure what to replace. I have checked all the vents and the inside of the dryer, there is no clog and no build up of any kind. help
  • Gary Davd
    Gary Davd May 11, 2010
    sorry i thought you had a diffrent model on that last post . there are 2 spring clips on the front you need to push in with a putty knife to release the top but before you do that reinstall the hinges in the back so it can lift up like a car hood
  • Gary Davd
    have you pulled the top towards you (back of ther unit) after you have removed the screws
  • Anonymous Mar 31, 2014
    Dryer will not top beeping
Thanks Brent for asking the question.
Thanks Master Tech. Your post answered my question.
Posted on Aug 30, 2008
  • 770 Answers
Did that work for you?
Posted on May 20, 2008
How to replace the start button on a frigidaire affinity dryer aeq7000ego?
There will be screws along back at the top holding the top panel. Using the appropriate screw head screw driver you will have to get these screws out, lift the top panel slightly and push out towards the front. This should disengage the panel from the notch on the main body and come out. That will get you access to the console.
For an assembly view refer to parts manual you can download from this site
Frigidaire AEQ7000EG Parts Catalog
Aug 16, 2014 | Frigidaire AEQ7000EG Affinity Series...
How do I Disassemble a GE Profile Dryer to replace Drum Bearings? Model: DPSQ475ETOWW?
remove 4 torx screws from the top of control panel,then slide control panel sideways till you can lift it up off the top cover,then open the dryer door on the upper door land area there are 2 screws going up into the top cover remove them then you can remove the top cover,then on each side at the top there is a screw holding the front panel in place,remove these then you can remove door switch wires from the door switch and lift up on this panel to remove it off the gussets on the bottom of the door,then you can install the top door bearing and 4 drum slides
Nov 29, 2012 | Dryers
Frigidaire dryer has recently become noisy. scraping, grinding sound. dont know if its belt or motor. any info b4 i take it apart? no error lights on panel.
The problem with the dryer is not the belt or the motor. the problem is either going to be the drum bearing or the front upper and lower felt and glides.I'll list a walk-through for you if your interested .
1)The first thing you need to do is unplug the dryer.
2) You will need to pop the top of the dryer. This can be done with a flat screwdriver. Place the driver between the top and the front of the dryer and basically just pry upwards.
3)Now, that you can see inside the dryer, the next thing is to remove the front of the machine. At the upper left and right sides you will find a screw that holds the front to the frame of the dryer.Remove these screws and you can take the front off.
4) The glides and felt are located on the inside of the front piece you just removed.The drum actually rest on these and if damaged will produce a metal on metal dragging sound. If these parts are good, continue to step 5)You now have access to the belt and idler pulley, which is good because the belt needs to taken loose .
6) WIth the belt off spin the drum and listen for the sound that has been bothering you, if any sound other than a smooth sound is emitted when turning the drum your rear bearing is out.
7)You can remove the drum by lifting the back end up and pulling it out. Once you have it out the bearing will be exposed and the rest is just swapping out the old bearing and putting it back together.
Jun 16, 2012 | Frigidaire Electric Dryer
Frigidaire Dryer GLER642AS3 loud squeaking. Squeaking sound probably coming from drum rotation bearing. Is there an easy way to get in to oil that location to stop squeaking noise? Thanks!
yes but you will have to take the front of the dryer apart and pull out the drum/tub. to do this you must open the dryer door and look up for two screws, remove them. next close the door and using a flat head screw driver, pop the dryer lid/top up (be careful not to bend apart the two green snaps that are holding it tight on each side). now using a phillip head screwdriver in each inside corner you need to unscrew the screw. now lift up and out slowly to remove the front of the dryer ( unplug the dryer door wires before removing front completely). now you must pull the tub straight out (you might need to reach in and take the belt loose first). Now you are where you need to be.
Jul 16, 2011 | Dryers
Dryer making a loud skreetching noise
Sounds like either a Frigidaire or model 417 kenmore. If it is the rear bearing has gone bad. Usually just the bearing cup needs replacing as long as you don't forget to use the proper grease.
Jan 26, 2010 | Dryers
How to install rear bearing on Frigidaire model fex831cso dryer
Not sure you are up to the job as everything has to come out from the front door panel all the way to the back of the machine.
If you are up to it there is a ball like a trailer hitch on the back of the drum that rides in a plastic saddle screwed to the back of the machine, both have to be replaced. MAKE SURE MACHINE IS UNPLUGGED
The kit was about 30 dollars last time I did it and comes with everything you will need. Don't try to reuse the three screws that hold the ball onto the rear of the drum or you will find out what aggravation is.
Also don't leave out the little ball bearing, it has a purpose.
Good luck
Quentin
Sep 12, 2009 | Frigidaire FEX831CS Top Load Stacked...
How do I get my model 453 dryer apart to replace the belt and drum bearing?
Open the door. Remove the two screws holding the top down. Lift the top, this will give you access to the two screws holding the front on. Goodluck.
Aug 08, 2009 | GE DBXR453EV Dryer
Frigidaire FSE446RHS2 electric dryer makes bumping noise when drying. Opened the top, belt is ok.
Rear bearing and drum coupler needs to be replaced
bearing kit part #WC5303281153 is available online from many parts stores. You may want to replace the belt at the same time while you have the unit apart. Also inspect the front upper drum felt if it is worn replace it. The whole repair time for me was about 45 minutes dryer now runs like new.
Jul 30, 2009 | Frigidaire GLGQ2152ES Gas Dryer
Fridgidare dryer problem
Frigidaire dryers use a post and bearing support system. The noise you hear is the post grinding away on the support.00069740.jpg This is the kit to fix that dryer and a link to the kit
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1851&PPStack=1
It cost 24 bucks and ships overnight.
Now to fix it requires a phillip screw driver to undo all those screws, I would start with unplugging the unit, removing the two screws in back for the top panel, two screws for the bottom kick panel, located all the way down, hard to see so tilt unit back to access. Next is four screws at the front corners above the user panel and two inside at front left and right sides about nine inches down, now there are two more at the bottom of this door panel where you pulled the kick panel off. After this there is two wire harness clips, squeeze and pull they come off and gently pull at the top sides as there is retainer clips which secure the panel. Ok? Alright now you see the drum with belt attached, get a flashlight at memorize how the belt loops on the tensioner to the motor pulley and take a photo if needed:) Remove the belt and one more screw top middle in front holding a yellow bumper for the drum. The drum while come off by lifting the back of the drum firmly as it clips in place on the bearing support. Now pull the drum out and if I didnt warn you watch out for sharp edges. You will see the flange with shaft on the drum to replace and the bearing support on the back. The back portion screws together with two screws through a retainer to hold a small ball bearing in, I suggest getting a buddy to hold the back clip when replacing as it is a stretch. In the photo above you will see all the pieces on right go in this order metal clip, plastic cup, ball bearing onto panel and hold clip on back and insert two screws, with a buddy and some grease to hold the ball bearing this is the easy part. The flange has three screws and you must thread them with out stripping the heads off. A buddy again to share the moment is best to hold the drum while you insert the screws. The last part is putting a 1/2 tsp of grease in the plastic cup and following the instructions in reverse. Dont forget the wire harness as you reassemble or the belt looping on the tensioner.
Searstechtoo
Sep 13, 2008 | Frigidaire FGR341AC Electric Dryer
Dryer marks clothes
it could be the adhesive that holds the felt bearings on the front housing. you see the back of the dryer drum has a bearing in its center, the front of the drum rotates on two or more felt pads or bearings in/on the front cover where your door is. you'll need to remove the front cover to replace these felt bearings. there should be two screws, maybe more holding the front cabinet to the rest of the dryer. the bearings will be mounted to the front cabinet right around the hole for the door.
Aug 09, 2007 | Frigidaire FGX831C Top Load Stacked Washer...
Frigidaire GLER341A Electric Dryer Logo
2,577 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
