My Gateway Notebook MX7500 most likely needs the following : #1. Replacement of Cooling Fan Assy. #2. Replacement of the screen Is there a specific repair shop in Calgary that does Gateway ?
Protect my notebook
Posted on May 20, 2008
I need a replacement for gateway notebook M-7317U cpu fan
Hello kimmietimesg,
Below is the website where you can buy M-7317U CPU fan.
http://www.dealtime.com/gateway-m-7317u-cooling-fan/products
If you like my answer please rate me.
Thank you.
Apr 19, 2012 | Gateway Computers & Internet
I have a Gateway 820 GM PC and want to replace the rear exaust fan. What size of fan should I get. Do they sell these on Amazon?
you could get this on Ebay if you dont have an account you will need to create one
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
be very specific when you type in the search
always ask questions? before you make a purchase
you will even see the pictures of your item so you cant make a mistake and get them home delivered
hope this helps
Apr 13, 2011 | Gateway Replacement Fan Board Assy
I have an old gateway 7023ge computer and i wanted to find out the size of my cooling fans so i can replace them. i have 2 fans one front and one rear. they are both the same size.
Computer case fans for older computers were usually standard sizes of 80 millimeter or 92mm, maybe120mm. 25.4mm = 1 inch, so an 80mm fan is about 3 inches. Measure the diameter of the fan from the tip of one fan blade to the tip of the opposite fan blade. A 92mm fan is about 3 1/2 inches in diameter and a 120mm fan is about 4 3/4"
Again, these sizes are _nominal_, so whatever your measurement is closest to is what you need. You should be able to measure the rear fan from the outside back of the computer without taking anything apart.
Jan 29, 2011 | Gateway (8008625) Cooling Fan, Heatsink...
What size is the rear case fan on a gateway dx420s
Gateway DX420S has a case that can handle either 8X8cm or 10X10cm. Take a look at this part of the picture
If you want to be sure just take measurements from one screw hole to the next one.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "flags".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 05, 2010 | Gateway Replacement Fan Board Assy
Installation of fan
Not knowing if you have ever taken one apart, start by laying the screen all the way back(flat) and then remove strip with power button. you have to start on the right side where there is a small notch. then remove 4 screws for keyboard. DON'T DROP THEM INSIDE CASE! remove 1 screw for shield. Then 4 screws hold down heat sink/fan assy. remember to disconnect power lead for fan. Installation is reverse. Be sure to use thermal grease between cpu and heat sink assy.
Feb 12, 2009 | Dell Inspiron 5100 Notebook
RADIATOR REPLACEMENT
  • At the time of installation, please refer to the following items.
  • Start the engine, and check for coolant and A/T fluid leaks.
  • Check the A/T fluid level.
  1. Drain engine coolant.
  2. Canada: Disconnect relay block (for daytime running light system) from battery hold-down clamp.
  3. Disconnect upper radiator hose from radiator.
  4. Disconnect lower radiator hose from water inlet pipe.
  5. Disconnect A/T oil cooler hoses from oil cooler pipes.
  6. Disconnect No.1 and No.2 cooling fan connectors.
  7. Disconnect No.1 Engine Coolant Temperature (ECT) switch wire connector.
  8. Remove radiator and cooling fans assembly.
    1. Remove the 2 bolts and 2 upper supports. Torque: 12.8 Nm (9 ft. lbs.)
    2. Lift out the radiator, and remove the radiator and cooling fans assembly.
    3. Remove the 2 lower supports.
  1. Remove A/T Oil cooler hoses from radiator.
  2. Remove lower radiator hose from radiator.
  3. Remove No.1 ECT switch.
  4. Remove No.1 cooling fan from radiator. Remove the 2 bolts and cooling fan. Torque: 5.0 Nm (44 inch lbs.)
  5. Remove No.2 cooling fan from radiator. Remove the 3 bolts and cooling fan. Torque: 5.0 Nm (44 inch lbs.)
INSTALLATION
Installation is in the reverse order of removal.
Nov 06, 2008 | 1992 Lexus Es 300
I need to know which fan i need for my pc
This heatsink & fan assembly is the replacement for the Gateway 500SE & E-machine systems.
http://www.skyline-eng.com/index.cfm?fuseaction=product.display&Product_ID=5564
Under the window: Search by Machine click the dropdown menue & choose as follows.
Type: Gateway Desktop Parts
Series: 500
Model: Gateway 500SE Parts
Than click submit.
Click, Cooling Fan.
More socket 478 CPU fans.
http://www.geeks.com/details.asp?invtid=CR099&cat=FAN
http://www.pacificgeek.com/product.asp?c=238&s=997&ID=39966&P=F
Most CPU fans come with the heatsink. Try not to buy a fan that comes with a grill over it. That slows the fan down & makes the fan work harder.
Mike
Jul 28, 2008 | Computers & Internet
Loud noise
Typical problem in most computers, the fan is experiencing a "burn out." This means there is either something caught in the fan causing it to create noise, or the motor is going bad. there are two fixes for this problem.
1) open you computer's case according to its manual and remove the system cooling fan and give it a thorough cleaning.
2) you may need to replace the cooling fan with its recommended replacement model.
Hope this helps!
Jul 08, 2008 | Gateway 506GR PC Desktop
Cooling Fan Replacement Instructions
Here's the manual, page 48. www.computermedicsofeci.com/GATEWAY-M305.pdf
Aug 29, 2007 | Gateway M305CRV Notebook
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
