Question about Vizio L32 32 in. LCD HDTV
Black Rectangles on 42" Vizio HDTV LCD
Small black rectangles appear on my screen at various times and places, sometimes if I turn off the direct tv they go away, or if I turn the tv off and then on again...not sure if it's the tv or direct tv?? I've also had time when I turn the tv on and the whole screen stays black or half the screen will...any advice would be greatly appreciated.
  • 124 Answers
Your DirecTV signal is probably too low. That would produce the small black rectangles (pixilation). Also, try replacing the cable you are using to get the signal from the DirecTV receiver.
Posted on May 30, 2008
Some channels on direct tv have a black rectangle
Either your tv or your directv receiver is on the text mode of the closed captioning function turn closed caption off and this will disappear.
Oct 15, 2009 | LG 42LC2D 42 in. LCD HDTV
Mitsubishi tv; black & wht rectangles only on screen.
Bad capacitors and probably a surface-mount fuse on the Formatter board.
There will probably be bad caps on all five boards within the chassis.
Sep 14, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Black Rectangle appears on screen for no reason
Just use your remote or the tv menu to turn off closed captioning.
Jun 03, 2009 | Insignia 42" Flat-Panel Plasma HDTV
Vizio 42" LCD - Random appearance of small black rectangles
There is a processing fault that is starting to occure. What you are seeing is a type of aliasing. This can be in the main signal processing or in one of the control areas.
The set will require service. The service rep will test the set by using board substitution. There are typicaly a number of areas in the TV set that can cause this type of fault. Once the defective board is located the fault will be easy to service with a simple board swap and some adjustments.
If the set is out of warranty, it may be expensive to service. With many of the no-name brands, spare parts can be difficult or impossible to have.
Jerry G.
Jan 02, 2009 | Vizio L32 32 in. LCD HDTV
I would check and see if you have the text option on under your closed captioning. With the new digital transition the signal for text captioning has been getting messed up during broadcast here lately. If it is on i would just shut it off or go to regular closed captioning.
Nov 02, 2008 | Vizio GV42L 42 in. LCD Television
Vizio L23 HDTV 10A
Sounds like the power supply board blew. You can purchase a new one directly from Vance Baldwin. They are the only parts supplier for Vizio. http://www.vancebaldwin.com/
It's just plug and play. remove the old circuit board and replace with the new one. Not difficult and it should solve your problem for less than $100.
Jul 18, 2008 | Vizio L32 32 in. LCD HDTV
Black Squares on the Screen
this kind of problem is normally do of bad cable box or sat
Apr 05, 2008 | Vizio L32 32 in. LCD HDTV
Black squares or rectangles over picture
It's the closed captioning. The reason it doesn't go away when you press the "caption" button is because there are four option for closed captioning: Text 1, Text 2, Text 3, and Text 4. The fifth option, which has no designation, is the "off" option. Using the remote, just click on the "caption button until the option has no designation.
Mine was a large black rectangle in the middle of the picture. It's not like Nina3's problem.
Feb 01, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
62' Mitsubishi WD-62525 little black and white squares instead of picture but I have sound
Mitsubishi list this problem and has a solution of replacing several small surface mounted caps and diodes. we have tried this repair 5 times and only successfully done it once. so replacing what is called the formatter board part # 930B924002 for around $ 350.00 usually repairs this type of failure, However changing this board is a time consuming thing and takes a lot of Patience. It is buried deep in the set and several other board have to be removed just to get to it
Oct 17, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Small black squares appear on Vizio 37
Sounds like a digital cable issue to me. Try connecting the cable directly to the TV bypassing the cable box and I bet that the issue will be gone. If so then contact your cable provider as the box or the incomming signal may be at falt.
Apr 01, 2007 | Vizio L37 Television
Vizio L32 32 in. LCD HDTV Logo
249 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
