Question about HP Pavilion dv4000 Notebook
Memory Installation I installed 2 new memory cards (512 replaced 256) in my HP Pavilion DV4000, but now the computer screen is black. Did I do something wrong or forget a step? Everything seemed fairly straight-forward.
  • Carinc May 21, 2008
    Thanks, Wayne. I "reseated" the new memory cards - both at the same time - and that seemed to do the trick. I had read somewhere that the installation sequence might affect results. I appreciate your help! CC
  • 300 Answers
Have you tried putting the old memory sticks back in, if they still work, i would try just putting one of the 512's in. If that don't work try the other.
I'm guessing either one or both of the 512's are either faulty or not compatible.
Hope this helps.
Posted on May 20, 2008
My HP DV4000 beeps when I press the power button and the screen will stay black.
This POST error code maybe -
one long, two short beeps
  • System board failure
  • Video adapter problem
  • LCD assembly failure
Dec 04, 2012 | HP Pavilion dv4000 Notebook
Memory Problem
bad sticks there,
BSOD screens?
finding good memory for such and old PC is not easy
did you buy them direct from Crucial or Kingston, ? or off fleabay.?
memory must match the MMC, chip, memory managers.
and the specs are not trivial. at all.
if it runs on the old sticks and not on the new,?
why wonder why, ( answer wrong sticks or bad sticks.)
#1 reason for this is memory
#2 is XP (and bad drivers to it)
buy from Crucial?
btw, why not test the sticks 1 by 1,
see which one is bad, and if all are identical (new set) then
all can be bad if using wrong sticks.
speed (too slow, faster is ok)
density rules, lots,... the older the CPU the worse this gets.
HP dropped all support on A-nnnnn PCs
so the pages showing all memory that work is gone now.
leaving only top memory makers are authorities no same.
I say ask them. in all cases this old PC.
Jul 15, 2017 | HP Pavilion a1330n (EL466AA) PC Desktop
What kind of ram memory can I put on my notebook HP Pavillion 4000? I have 512 kb and I need more. What can I do? DDR2 or DDR3 or SDRAM? Please, help me!
The spec of RAM used by this computer is DDR SD RAM
Maximum RAM that this computer can take is 1 GB (2 X 512 MB)
Nov 21, 2010 | HP Computers & Internet
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
Can i upgrade my Ram and hard disk in my HP pAvilion dv4000?
according to the specs you can install up to 2 gb of memory and the manual states that a 100 gb hard drive was an option. not sure if you can go higher then that.
Robert
Please take a moment to rate this solution thanks
Jan 29, 2009 | HP Pavilion dv4000 Notebook
512 MB memory boards do not work in my Fujitsu Lifebook S2020
frquance is not set and it is not recommand that 2 different friquance ram is not working propaties
Jan 09, 2009 | Fujitsu LifeBook S2020 Notebook
Sdram capacity
its that 512 mb total capacity for your computer memory?? if so read this:
To find the total amount of RAM that can be added , subtract the amount of RAM currently in the computer from the maximum amount of memory the computer can hold. For example, a computer has 256 MB of RAM. If the maximum amount of memory the computer can hold is 512 MB, then 256 MB is the amount of RAM that can be added. this info from the HP website , to find out more , go to http://www.hp.com/support , enter the model number , and look for more information about your computer specs, hope this helps , please rate & thanks AJ
May 24, 2008 | HP Pavilion 8860 (P2941A) PC Desktop
Memory upgrade
The memory should be DDR II Ram. To find how much ram you have simply click on Start then right click on "My Computer" and click properties. Chances are you have 512 ram. It will tell you in the lower right hand side along with your processer and windows version. Once you have found out how much ram you have, turn off your computer flip it upside down and pull out the battery. Then you should see a cover with one or two screws in it that measures about 3 inch by 4 inch. Remove the screws and take the cover off. This is where your memory goes. If there is 512 memory in your computer you will either have 1 512 memory stick or 2 256 sitcks. Remember that any time you upgrade memory it is best to take out the old memory and replace with either one stick of higher ram or two of equal ram. Never mis a 512 and a 256 or 512 and 1gig ect. Take the ram stick/sticks out and bring them down to the store with you just so as to get the correct memory. Also, remember when you replace the memory, if you are just upgrading to one 1gig stick to put it in the A DIMM slot. This is the primary ram slot.
Apr 29, 2008 | HP Pavilion dv6000z Notebook
Hp Pavillion laptop freezes when I install secondary memory
You may not put all together the 256 and 512, the system encountered error when two memory are not equal size and not equal brand.
Either you select 2 units 256 memory or either 2 units 512. or use only 1 unit 512 memory so that no freezes will happen.
Jan 17, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv4000 Notebook Logo
97 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
