Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
Pool Heater My pool heater will not ignite. It will turn on gas will flow but no ignition. Need help on how to test ignitorb
  • 1 more comment
  • nottoohandy May 23, 2008
    I have a Laars Lite 2 heater. Pilot is on, but nothing happens when the toggle switch is flipped to "on". I've taken the filter out and cleaned that. Also, I have turned the tempature switch from "min" to "max", and everywhere in between.
  • wilks61 Jun 05, 2008
    where can o down load owner manual for the laars lite 2 250k btu
    thanks
  • wilsonbruce Aug 24, 2008
    Just hooked up a used Laars Lite 2 lg 175000. Was stored in a garage for 3 years. Pilot on no but will not ignite. The installer reduced the piping to 1/2 inch, stated as it was only 5 feet from meter it would not matter. Also in the manual regarding spring start up it states that oil should be poured into tube that attaches to pressure switch. Is this necessary?
You can light the pilot with a B.B.Q. lighter.
Nottoohandy. Backwash you filter, make sure it's really clean. If that doesn't work it could be the pressure switch. You can by-pass the switch with a piece of wire to see if it fires up. If it does, it's the switch. There is a picture of the switch in the manual.
C
Posted on May 26, 2008
Brand new Raypak gas pool heater started up ok but when shut down for the night electronic pilot won't kick in to start heater.
makesure gas is on, gas valve also turned on. check to make sure you are gettin proper voltage to igniter. ensure proper water flow from pump.
Aug 02, 2013 | Pool & Spa
Getting ignition lockout code
1-water flow ? gas related , is propane or natural gas ?
Jun 09, 2013 | Legacy Jandy Lrz250en Swimming Pool Spa...
Heater takes a long time to fire up.
There is a flow switch if that's not working. same problem needs to be tested Gas valve solinoid could cause this Igniter could cause this problem Gas pressure regulator wrong pressure should be about 2.7KPA LPG Gas valve should be set to about 2.6 KPA LPG
Mar 28, 2013 | Rheem M206A 206K BTU Pool and Spa Propane...
Jandy LXi gas heater error message "ignition control failed
if ignitor is glowing try changing position of the shutter 1/2 to 3/4 open should lite
Dec 22, 2012 | Jandy Laars LX Pool Heater / 250,000 BTU /...
Pilot comes on but no gas flow.
Hello. you need to replace the thermocouple which is a safety device that turns the gas on and off. Joe
please rate my answer as very helpful. Thanks.
May 01, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Hayward h250ed1 heater wont stay lit
Try cleaning your filter if dirty there will not be enough flow to llet heater fire. If filters clean you can try jumping the pressure switch.
Jun 24, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Heating & Cooling Logo
279 people viewed this question
Top Lite On Heating & Cooling Experts
Paul Carew
Michael Galve
Michael Galve
Craig Butler
Craig Butler
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
