Question about Garmin nuvi 350 GPS Receiver
Using my car speakers with my Garmin Nuvi 350
Is there someway to connect my Nuvi 350 to use my car speakers? My car doesn't have a plug in port (that would be too easy). I only have a CD player and AM/FM radio.
    Problem Solver:
  • 11 Answers
I purchased an FM transmitter, plug it into the earphone jack on the nuvi, tune the radio to the frequency set on the transmitter and play thru my car stereo.
The transmitters are widely available and inexpensive. The cheaper ones have preset frequencies that can be selected. The better ones (not necessarily more expensive) have infinate selection capabilities. The latter will allow you to better find a clear frequency (one not used by a nearby FM station). Mine has the presets and works fine all over England.
Hint - Buy a set of 4 rechargable batteries. Two for the unit and two for take along spares. Recharge the depleted batteries and put them back into your car as spares repeatedly. Saves money in the long run.
Posted on Jul 20, 2008
  • 504 Answers
No, unfortunately ther is no way to get the unit to use your car speakers. To do this, the unit would have to have an FM transmitter or be able to connect to one. It does not have this capability. Sorry.
Posted on May 21, 2008
Shut off
You should only see the computer icon when plugging the 350 into a USB port on the PC. If you see it when plugging in a car charger/adapter, then there may be a problem with the mini-USB port on the 350 or the charger is an after-market charger that is not electrically compatible with a Garmin charger. Please see this link for more info:
http://www.sharc.net/gps_charger_repair.htm
May 29, 2013 | Garmin Nuvi 350 Car GPS Receiver
Nuvi 350 will not run on DC charger
Make sure your DC & AC charger is a OEM charger.
There is a good chance that there is a bad connection on the mini-USB port.
What happens when you plug the unit into the cradle and NOT use the mini-USB jack?
- Jim
SHARCNET-USA
Apr 19, 2010 | Garmin nuvi 350 GPS Receiver
When i plug in my garmin to a car charger it
u need to replace the battery, they last about 2 years on average.
Sep 10, 2009 | Garmin nuvi 350 GPS Receiver
Nuvi 350 System Software Missing
If you have a nuvi 350 download the software to your computer and then load the software onto a formatted sd card. Insert the sd card and bootup the Nuvi 350. The sofware will then load onto the Nuvi 350. If you have a Nuvi 200 I would think it works the same but I have not tried it.
Hope this helps
May 12, 2009 | Garmin nuvi 200W GPS Receiver
Garmin gps won't charge while driving
If the Nuvi won't charge when connected to charge but charges on USB, then the charger port is faulty.
If the Nuvin does not charge at all , then the battery must be replaced.
Dec 27, 2008 | Garmin Nuvi 350 Car GPS Receiver
Nuvi 350 wont charge with car adaptor. But charges with ac charger in usb port of Nuvi. Any thoughts? I have another Nuvi 350 that does charge with this ones car adaptor.
Are you using the same port on the Nuvi to connect the car adapter and the ac charger, or two different ones? If not, then the jack could be broken (solder joint, pin?).
Aug 10, 2008 | Garmin Nuvi 350 Car GPS Receiver
Garmin Gps Nuvi 300/350 stopped talking
I got a solution for this issue - buy a SPI Mini-Hi-Fi speaker - it's to be connected directly to the GPS output, there is no cord or cable, it's very light, sounds pretty well and it's totally affordable (around $10).
I've been used it for weeks, no problem at all!!!!!!!!!!!
Jun 07, 2008 | Garmin Nuvi 350 Car GPS Receiver
Garmin Nuvi 350 Traffic Receiver connection
You have to power the unit via the mount by either using the cigar charger in the car or snap off the mount from the ball and socket and power it via the mains adapter.
Jan 02, 2008 | Garmin GTM 12 FM TMC Traffic Receiver...
Nuvi 350 blown speaker
When you tap the GPS it is probably doing one of two things:
1. The tapping is temporarily reconnecting the broken voice coil in the speaker (speaker will need to be replaced)
2. The tapping is temporarily reconnecting a bad solder joint from the GPS motherboard to the speaker. (The solder joint will need to be resoldered)
You can either send the unit back for repair or purchase a FM modulator and retrieve the audio through your FM car stereo.
You can purchase an external FM modulator like those used on IPODS and CD players. I am using one on my Nuvi 350 and it works well. Just plug it into the headphone jack. Advice: Be sure to buy one that is crystal (PLL) controlled and NOT using a tuning dial. The FM modulators that use a tuning dial often tend to drift and they will also change frequency when you hit a bump in the road.
If you decide to send it back for repair, be sure to have your serial number handy. Register it online https://my.garmin.com/mygarmin/marketing/register.htm
if you haven't already done so.
Hours:
Monday - Friday
8 a.m. - 7 p.m.
Central time (closed holidays)
1-800-800-1020 (U.S.)
1-866-429-9296 (Canada) or (913) 397-8200
Good Luck,
- Jim
Nov 25, 2007 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
511 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
