Question about Bosch WFL 2063 Front Load Washer
WFL 2066 NOT DRAINING FULLY - NO SPIN
Drains about 90% water and works properly for 3-4 washes then accumulated water prevents spin. Manual draining solves problem for another 3-4 washes. Motor, pump and belt all seem ok.
    Genius:
  • 3,422 Answers
THIS LINK may help you understand what is actually wrong.
Goodluck,
Please don't forget to rate or accept the solution.
Posted on May 20, 2008
  • 1,031 Answers
The air gap that prevents the wash water from being siphoned into the household water supply. located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. made of translucent plastic is blocked, you may need to replace it.
check The a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If its blocked it can make water to accumulate.
A washer that leaks only during the spin cycle often has a leak in the main drain hose.check the entire hose ,correct any problem you find. Also, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. :
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it.
Pump: If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Main tub seal: The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Outer tub:The steel or plastic outer tubs can rust, split, develope a hole in some way. If this happens, you may have to replace the outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
  • 3,037 Answers
Check for a kink in the hose first.
Also check to see if it is clogged at all or if the screen over it is blocked up at all.
Please let me know what you find when checking these two things and we can go from there to fix this problem.
good luck and feel free to ask any questions that you have about doing what I suggested or anything else and I will be here all of the way through this to help you
    Genius:
  • 1,447 Answers
Try to dismantle pump and reposition it and clean dirts that have accumulated on it that prevents water to fully drain. best i got
Water not drane setisfewctori Cloth not dry
There are 2 possible reasons for this .The drain for the washer may be kinked at the back preventing the water being pumped out . The pump is virtually a water circulator and not a pressure pump so any obstruction will keep water in the washer.. Next --the spin cycle may be to slow for the water to be spun out of the clothes. Check the load is not above the recommended weight as this makes the spin cycle slow. IT is better to do 2 washes rather than to cram it all into 1 wash. Check the filter at the pump as they tend to block up with lint and other gunk from the clothes and the water may be unable to get to the pump Powdered detergents are 90% clay( fine as talc powder and used to carry the detergent) and this settles out in the lower parts of a machine so if you use powder I would recommend changing to liquid
Mar 11, 2014 | Bosch Classixx WFL 2066 Front Load Washer
WIll not drain water.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 02, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Washing machine not spinning
Check the belt. You might have to replace the belt of the washer. If the belt has deteriorated, you need to replace it.
If the machine does not spin because it still detects water inside, the problem could be in the pump. It probably has trouble draining water or pumping out water. If the pump has corroded, you can also try replacing it.
source: http://www.washingmachineadvisor.com
Dec 06, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Spin light flashes & it won't rinse, drain or spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 03, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Spin wont work and machine wont spin cloths
The machine mite not be draing if so cheak the drain pipe to see if it is bloked or not installed properly. if the water drains out and you hear the moter running the belt might of gone. but if the machine if not making a nosie the moter might be gone and there is two things to cheak before getting a new moter 1 cheak the cables a blugged in sucurly 2 make sure the carbon brushes are ok if it seams all ok the moter might be broken or the control panel.hope this helps
Sep 02, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Water not draining
your chicken wish bone may have broken your drain pump- it may have prevented the impeller to spin while the motor was on-not good. you may want to consider changing the drain pump...
Mar 15, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch WFL 2063 Front Load Washer Logo
201 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
