Question about Toshiba Computers & Internet
My computer doesn`t recognise disk in dvd drive
    Problem Solver:
  • 6 Answers
1. Make sure you use DVD's in good condition.
2. Reinstall the driver..( right click My Computer->properties->Hardware tab -> Device manager-> DVD rom-> right click Uninstall and again install using Dvd rom driver cd)
3. Clean The Drive lens using Dvd lens cleaner disc kit available in maket.
4. Removing DVD rom. opening it up manually and cleaning the lens with cotton( this tedious for novice users.. instead give it to servicing shop)
Posted on May 20, 2008
My cd drive does not recognise cds
Okay. First of all is it a cd drive in your computer as opposed to a DVD drive? If you put a dvd into a cd drive it cannot recognize the dvd. A dvd drive can recognize a cd, but a cd drive cannot recognise a dvd.
Does your computer actually recognize the drive as being present?
If the drive isn't recognized by the computer try:
power off the laptop
Physically remove the cd or dvd drive
power -up the laptop without the cd/dvd drive
power off the latop and refit the dvd/cd drive
power it up again and see if the drive is
recognized
If the drive IS recognized by the laptop but won't play any disk it's probably the drive itself at fault. You can try gently cleaning the inside of the drive - the optic that reads the disk. However, the usual cause is failure of that optic which read the disk information. It cannot be repaired.
The alternative to fitting a new drive is to buy a portable dvd drive. They connect via a usb cable. Have a look on Ebay
Dec 21, 2014 | Computers & Internet
How to recover deleted video from toshiba rd xv48dt hard disk?
try hard drive data recovery software, recommended Asoftech Data Recovery which helped me before. You may take a look at this hard drive data recovery guide that helped me before
How to recover deleted video from hard drive
good luck!
Dec 07, 2012 | Toshiba rd xv48dt
My dvd drive doesn't work
If it happens for only one particular disk:
Bring that disk to a game store like Gamestop or Rock30 Games and have them professionally clean the disk for a couple bucks.
If it happens for all disks:
Clean the cd/dvd with a laser lens cleaning kit. If that doesn't fix it then the cd/dvd drive will need to be replaced.
Jul 31, 2012 | Acer Aspire 5738Z Drivers Recovery Restore...
DVD drive recognised but disc not recognised
not sure how its recognised on control panel
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Apr 05, 2012 | NEC MultiSpin ND-1300A (ND-1300A)...
My TSST Corp DVD+RW does not recognize MAXELL DVD+RW single sided 4x4.7gb 120 min disk(s) WHY?
Does it recognise other make disks?
A DVD reader/writer may not recognise a blank disk for two main reasons;
The disk is not "prepared" or formatted for use,
or
The computer has been instructed not to "auto run" new disks.
Either way, there is no other reason why it won't see a blank disk.
If the disks have been written on by another computer and not "finalised" your drive might not be able to utilise anything that is on it.
I hope that answers your question.
Nov 28, 2010 | HP Computers & Internet
CD drive does not recognise my discs(Sims 3)
Sims 3 comes on a DVD-ROM, therefore you need a DVD drive on your computer rather than a CD drive. As a test, take a disk that you know is a DVD (like a store bought or rented movie) and see if you can read that on your computer. If you cannot, then you probably have only a CD drive in your computer. DVD drives are inexpensive and easy to replace. You can purchase one at a local computer store.
Jun 05, 2009 | Evesham Computers & Internet
"disk error" occurs when disk is inserted
the drive cannot read data from the disk, follow these instutions:
if you are using vista, right click on "computer" then select "manage" then select "device manager". look down the list until you find CD/DVD and click on the + icon next to it, then right click on the CD/DVD and select un-install (make sure that there is a disk in the drive, preferably a movie or music CD) then restart the computer, when the computer restarts vista will detect the drive and install the drivers again, look in computer to see if the disk has been recognised
let us know how you get on
and please remember to rate us
regards
Nov 28, 2008 | Televison & Video
My computer doesn't recognise my D: drive when I click on My Computer
Right click on 'My computer' and select manage and there you will find the option that is "Disk management".You can change the drive letter there..
Sep 04, 2008 | Lite On LiteOn 16x Black internal oem DVD...
DVD-RW not recognising blank disk
Usually HPs are good with +R DVDs unless things have change over the last year or two.
Whats the model number on your computer?
Aug 09, 2008 | Tablets & eReaders
Drive E
does the pc recognise the cd drive , if it does but still not recognise the disk,s then its maybe faulty , replacement dvd drives are soo cheap , £25 ans easy to fit , if you can not see the drive in "my computer" the click start.right click my computer,click properties.click hardware and then device manager.scrool down ,look for dvd/cd rom drives or any yellow question mark???, click item and properties and go from there ,
Dec 12, 2007 | Acer Aspire L100 PC Desktop
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
