Question about Toshiba 51H93 51" Rear Projection HDTV
Will not turn on
My 51h93 Toshiba unit will not turn on either with the remote control or directly on the front button. Technician came to repair as part of warraty but boards came cracked and were returned but it took to long to get the new part that store gave me credit for the unit and I still kept the unit and would like to repair it but don't know what's the parts. I know there were two circuit boards that needed replacement, but don't know the part # to order them. Any help?
  • 2 more comments
  • mxragz Jul 03, 2008
    TV won't turn on. I can see an orange light inside the rear case when I plug it in, and then it fades away
  • kyicky Oct 23, 2008
    Won't turn on. Reset button on front panel didn't work either as suggested in the manuel. I can hear something "click" when it is plugged in. Is God telling me I need to get a flat panel???
  • Gilllee Jan 03, 2009
    I disconnected and moved my Toshiba 51H73 unit and now it will not turn on by the remote control or directly on the front control button. When I press the reset button I can hear a clicking sound.
  • jsaleo Apr 08, 2009
    TV worked fine the day before. Next day TV would not come on by using power button or reset. Hear a clicking; then a sound like it is going to start; then nothing.
If main power supply is working check sub power supply.should be 1.5 volts on pe 42 pin8 and 9.
if missing replace ce36 and ce 39. i mounted mine caps on foil side.
Posted on Dec 18, 2008
The remote will not turn the TV on. When I turn it on with the button on the front, the power light on the TV starts blinking (no sound or picture). The red light will blink forever, and the TV will n
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician
Nov 01, 2014 | Toshiba Televison & Video
Why do center row of buttons on my remote not work?
Its circuit board fault. Open conductor track [carbon track]. It can be repaired. Contact any experienced service technician.
Gopakumar Gopalan Google
Jun 26, 2014 | Toshiba SE-R0305 Remote Control
Locked DVD Toshiba
Disconnect the AC power for at least one minute to reset the clock.
Adjust the volume to the minimum using the Volume down button on the front of the unit.
Press and hold the Volume down button on the front of the unit and the 0 button on the remote control at the same time, holding them down for at least 10 seconds.
The user menu will appear with the V-Chip cursor blinking.
Press the ENTER key on the remote control and the NEW PASSWORD menu will appear.
Enter your new password.
Nov 05, 2012 | Toshiba Televison & Video
Toshiba won't function with remote
All universal remote controls should have to setup with the TV by its codes. There are codes, given below, to synchronize the TV with remote control. Brand name of the remote control you have isn't matter. Check these codes. Proceedings also is given. If you want further details, check this link, and select the site 'Electro-help'. pull up older posts there for more details.
Setup codes for Toshiba TV are:
0159 0178 0109 0120 0181 0105 0049 0095 0170 0260 0358 0394 0924 0012 0095 0117 0141
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Jul 10, 2012 | Toshiba 46 46SL412 TV
Yamaha RX-V1000 volume control erratic, remote doesn't work. All was well then the volume control knob became erratic (volume would change erratically as knob was turned in either direction, remain...
sounds like you need to take it in to have it looked at. no simple fix unless you are an appliance technician. hard to walk a beginner through. i suggest calling an stereo repair guy.
Fix Ya
FixYa Support
Please accept solution and rate 4 thumbs up! Thanks for your feedback!
Aug 21, 2011 | Yamaha RX-V1000 Receiver
Unlock instructions for Toshiba dr570 DVD
Turn on your DVD player and television. Select the appropriate input source for your DVD player on your television.
Press the "Setup" button on your DVD player's remote control to display the main menu.
Navigate to the "Rating" menu option using the "Down" button on your remote control. Choose the "Parental Control" item by pressing the "Right" arrow button, followed by "Enter."
Enter the parental control access password using the numerical pad on your remote control, followed by the "Enter" button. If you did not previously setup a unique password, enter "8888" when prompted for the password.
Press the "Enter" button to display the parental control rating menu. Select the "8: Adult" menu selection by pressing the "Up" or "Down" directional buttons on your remote control, followed by "Enter." Press the "Open/Close" button on the front of the DVD player to complete the process.
Nov 21, 2010 | Toshiba DR570 DVD Recorder
Toshiba 27A41 27" TV Remote is lost. Need to change the input. Can I do this using the buttons on the TV? Can I program my DirectTV remote to change the input?
You can't chage it with your Direct TV remote control. If there is menu button in front of the tv, just go through the menu, and see the vedio options. From there you can change the input selection. If there is no menu button, you can't do anything without the help of remote control handset.
Oct 15, 2010 | Toshiba 27A41 27" TV
Remote control SENSOR not working
This could be a fault with your remote control. It will need checking by a Television Technician.
You can clean the remote control yourself if you are careful. You will need a spray can of Servisol IPA 170.
  • Carefully split the remote control unit along the seal between the top and bottom of the unit.
  • Carefully notice how you then dismantle the inner components. (I lay the components out in the order I take them out of the unit).
  • In a logical order spray, clean and dry each part.
  • When you have cleaned all the components, reassemble in their reverse order of the way you dismantled the unit.
  • Fit new batteries and test the remote control.
If this fails to solve the problem, you will have to take the remote control to a Television Technician for testing.
If the remote is found to be beyond repair, visit who may be able to supply you with a replacement remote control. I trust this information will be of help to you.
Dec 04, 2008 | Toshiba 32A60 32" TV
Toshiba 51H93 51" Rear Projection HDTV Logo
476 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
