Question about Brother HL 5140 Laser Printer
Brother HL 5140
Printer properties are in Swedish. Using windows XP Pro. We are trying to get English. Have already uninstalled and reinstalled driver English version.
In Windows XP Pro...
Go to printers and faxes window. File-Server Properties. From dialog go to drivers then select the problem driver and pick Replace button. Select Yes to replace driver.
This has worked to solve the problem on the printer server machine but not on the other machines using the printer as a shared printer.
Posted on May 21, 2008
Brother HL-1435 printer not printing. Alarm and data lights stay on. I tried replacing the toner, replacing the drum, factory resetting printer (both are genuine Brother products), uninstalling and...
try reseting drum unit
Open the front cover. Locate the black button under the LED lights on the left side. Press and hold in the button until all the lights are lit. Release the button. The counter is reset!
its toner soup
Nov 18, 2013 | Brother HL 1435 Laser Printer
Looking for new printer driver for brother hl 1440 and windows 7
As per the printer manufacturer website, Brother Hl-1440 printer is not compatible with Windows 7.
http://www.brother-usa.com/Printer/ModelDisclaimer.aspx?Model=HL1440#SysReqs
However, you may download & try installing the XP drivers for the printer in Windows XP mode.
To install in compatibility mode:
1.a. Right click on the setup file of the driver.
b. Click Properties.
c. Click Compatibility tab.
d. Under compatibility mode, check mark "Run this program in compatibility mode for:" and select "Windows XP (Service Pack 2)" from the drop down list.
e. Click Apply and then click ok.
2. a. Under "Privilege level", click "Run this program as an administrator".
b. Click apply and then click ok.
3. Install the driver successfully and restart the computer for the changes to take effect.
Jun 07, 2012 | Brother HL 1440 Laser Printer
My printer has somehow disconnected from my computer...how can I reinstall it?
Hello
Plug in your printer to your computer whether it uses parallel, serial or usb port
Find the driver from the provided cdrom supplied by your printer manufacturer, if it's not found, you can locate on from the manufacturer's website
Turn on your printer, and if you use windows xp, it will pop-up a new add hardware wizard
First, you can try to have windows configure your printer manually, if not found, locate the driver for your printer or wherever you save the driver on.
Oct 01, 2010 | Brother HL 5140 Laser Printer
Brother HL-2140 printer driver problem - won't load
Uninstall the completly the printer driver form add and remove program and dissconect the printer cable and restart the computer. after that download the latest driver from herehttp://welcome.solutions.brother.com/BSC/public/us/us/en/model_top/monolaserpri/hl2140_all.html?reg=us&c=us&lang=en&prod=hl2140_all and install it.
Nov 13, 2009 | Brother HL 2140 Laser Printer
Our printer is printer in a different language
This means your printer is using generic driver, not the real driver, make sure you install the correct driver, you can download it free from the manufacture website.
Thanks for using Fixya
Oct 19, 2009 | Office Equipment & Supplies
I don't speak SWEDISH!!!
Have you tried going to Brother support and download the drivers in English?
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_index.html?reg=us&c=us&lang=en&prod=hl5150d_all&type2=1&os=5&flang=English&dlid=
Jun 26, 2009 | Brother HL 5150D Laser Printer
Brother HL-1440 Printing Preferences Language Problem
I had the same problem. I finally totally uninstalled the printer from my computer, downloaded the "new" software from the Brother site, and reinstalled it. This is what finally worked for me (WinXPProf.).
Jan 05, 2009 | Brother HL 1440 Laser Printer
Need English version on 5250DN
You need to remove the printer and reinstall it. You need the English version from the Brother website, or an all language version. Make sure to select English during install.
Windows will see that it already has drivers and ask to keep them; say no and let Windows overwright the old drivers.
That should do it.
Rigsby
Sep 19, 2008 | Brother HL 5250DN Laser Printer
No 600 DPI with Vista
Bonjour, réponse en français je suis pas bon en anglais je mettrai une traduction en anglais juste après, donc la solution est d'installer manuellement le driver de la HL 1250 de Vista cela fera fonctionner la HL 1240 mais avec les 600 dpi (pour information la 1250 est à 1200 dpi mais bridée à 600 dpi sous vista)
Vincent De Lémos (http://www.loisirsfr.com/)
Hello, response in French I am not good in English I will put a translation in English immediately following, therefore the solution is to install manuellement to drive it HL 1250 of Vista that will do to work the HL 1240 but with the 600 dpi (for information the 1250 is at 1200 dpi but bridled to 600 dpi under vista)
Jun 29, 2008 | Brother HL 1240 Printer
The printer is now in Swedish writing
small test... Hit the Go button 3 times, fairly fast like tick-tick-tick, normally by doing this the printer will print it's internal configuration pages. Are these in Swedish as well?
If I'm correct you selected the wrong supported language when installing the printer.
Go to your controll panel, remove the printer driver in "printers and faxes" as well as any brother software in "add/remove programs".
Then disconnect and reconnect the printer, install the driver and try to select the proper language while doing this.
Mar 07, 2008 | Brother HL 5170DN Laser Printer
Brother HL 5140 Laser Printer Logo
125 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
