Question about Sony DHR-1000 DVHS VCR
Sony DHR1000 Chirping in Audio output
DHR1000 picture great, audio outputs but with "chirping" in the audio-- any ideas?
  • gdaymude Feb 13, 2009
    I have the same problem, but with a small Audiovox 8" Kitchen LCD TV. These are made exclusively for Target, and it's a well known issue across the many customer reviews I read. It appearantly affects more people using Over-The-Air (OTA) reception, and only on certain channels, rather than channels received using cable or satellite sources, but I don't have any personal experience with it. Don't know what this could be.
    Champion:
  • 221 Answers
"chirping" in the audio may be an indication of a tape path alignment problem. if the tape path alignment is off, the audio will "chirp" or drop out.
Posted on Jun 27, 2008
Vizio E371VL television powers on normally, but the audio is just a chirping sound regardless of volume setting. Muting the volume mutes the chirping.
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Mar 08, 2015 | Vizio E371VL 37 Class 1080p LCD TV
Philips 60pp9202 I get no sound, no picture and a chirping noise
Chirping in a phillips is usually related to the HOT ( Horizontal Output Transistor) or the Flyback ( HV Generator having a issue.
Dec 11, 2009 | Philips 60PP9202 60" Rear Projection...
Sony bravia chirping audio
It's likely that the volume on your cable box at the new place is set much lower than your old place, so you have to turn it up.
Turning up the television too loud will cause the annoying chirping in some cases.
Try using the cable box remote, and turn up the volume on your cable box, as you turn down the volume on your television.
Feb 16, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Philips mod. # 60PP920217F
Hello bradahman,
The chirping sound is either a shorted Horizontal Output Transistor / Power FET (whichever one is used in this case) or the IHVT (Flyback Transformer) has developed a short in its windings. In ether case both components will have to be replaced. I would suggest you have a qualified TV technician come over and troubleshoot the problem and give you an estimate on the repair.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 06, 2008 | Philips 50P8341 50" Rear Projection...
Philips 55PP9352 Rear Projection, no picture or sound, chirping.
This is a common problem with this model. The convergence circuits have shorted out causing the HVG to chirp.
Goto the site www.TvRepairKits.com and get their "chirping" tv repair kit. It will fix the no audio+no video + chirping problem.
Nov 16, 2008 | Philips 43PP9202 43" Rear Projection...
60pp9202/17f purchased in 2004
the flyback or the horizontal output needs replacement.
May 27, 2008 | Philips Televison & Video
Samsung PCL542R Chirping noise
There is problem in sound IC. First check it
Feb 17, 2008 | Samsung PCL5415RB 54" Rear Projection...
Phillips chirping
two STK392-120 convergence modules that usually cause the beeping. So I changed them both again, but I also found two open 7.5 ohm resistors are in the general area of the convergence modules, and I replaced them as well. I also replace 1 swollen capacitor that was probably going to blow in the future but not really a problem yet.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 25, 2008 | Philips 43PP9202 43" Rear Projection...
RCA F27667 No Picture / Chirping sound
I will bet you 10 to 1 that the flyback transformer and the horizontal output transistor is bad. an no at this point the set is not worth fixing.
Sep 28, 2006 | RCA F27667 27" TV
Sony DHR-1000 DVHS VCR Logo
164 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
