Question about Hoover HCA390FFK Bottom Freezer Refrigerator
Fridge problems Hi, I am having problems with the fridge compartment. There is ice on the back wall of the fridge and food is frozen!
  • iankorky Sep 06, 2008
    I have the same problem, but I know what is causing it; it's the thermostat as it makes no difference whether I turn the stat up or down, it still keeps running on max, none of the lights are illuminating the "super" light and "on" light and the fast freeze doesn't work because it's on max freeze already.
    I have been informed that you cannot purchase a thermostat for this model as it is a new circuit board that's required.
    Do you know where I can buy one and are they easy to fit? The problem is that I bought the fridge/freezer in the UK but have since moved to France and it's very difficult to find someone who is willing to do the job.
    Many thanks Ian
    Scholar:
  • 57 Answers
There is a damper between the Freezer section and the Refrigerator sections. If the damper is open to much the refrigerator will freeze up and it will freeze food. Find this damper and close to about 1/2 way.
The Thermostat is seperate make sure this is set around the middle setting. If the thermostat is bad it can cause the refrigerator to also freeze. Turn the dial down and listen for the compressor to click off. then wait a few minuites turn it up and see if the compressor come back on. If you turn the Thermostat all the way down it will shut off with the switch. not shut off by satisifying the temp. so just turn it down slowly and see if it is working.
Posted on May 20, 2008
Samsung "Cool-n-cool" fridge freezer defrosting food
Is it "defrosting" the food or unable to keep it frozen? Probably unable to keep frozen. Many possible problems. 1. Defrost element bad and evaporator coil is iced over, or 2. Failed evaporator fan inside freezer, or 3. Low freon causing iced up evaporator coil....Do you see any ice build up on the back wall of freezer? Do you hear the freezer fan running or not? Take a look and get back to me.
Oct 12, 2013 | Refrigerators
Whirlpool Refrigerator Model No. WRN28RWG6
if the flap was open then truely excessive cold air is coming out/escape from the freezer causing no freezeing. you need to defrost your fridge.
Note also that frost build up increases time to freeze your food on the freezer. it also causes your fridge an increase in electricity consumption.
defrost your fridge for some time ti remove the frost build-up.
Nov 19, 2007 | Refrigerators
TOP HALF OF FRIDGE COVERED IN ICE AND FREEZING FOOD/DRINK
I have had this problem in the past. You will need to get the automatic defroster fixed or take all products out of freezer part of fridge. Remove back panel of freezer unplug from wall let defrost. put fan in front of it to speed proses. usually an hour or so depending on how badly frozen it is. good luck.
Apr 10, 2013 | Refrigerators
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
I have a frost free refrigerator (MODEL #: FGTD 20V4GW2 and SERIAL #: ba00230071) yet the ice/frost builds up of the door, top and front of the freezer. Also the bottom compartment where the milks,...
if ice is on the door and ceiling and frozen water dropleats on the food packages the door was left open and the air ducts are frozen.when you open the freezer door do you hear the fan blowing,if not it could be bad or iced up,if the ice is on the inside back wall of the freezer you have a defrost problem,get back to me and tell me if the ice or like snow is just on the back wall or if the door was left open ice will be on ceiling ,door and shelves and food packages,also that's not a good model number if the freezer is on top look at the left wall up near the ceiling in the fridge section,you should see a tag there with the model number.
Sep 25, 2011 | Frigidaire 14.7 Cu. Ft. Top-Mount...
My sub zero refridgerator (freezer on bottom fridge on top) is cold on the bottom of fridge and warm on the top of the fridge. Any idea what is causing this. Items are also damp in fridge. We just vacumed...
the evaporator coil inside the freezer compartment is iced over and can't transfer cold air in thes condition,remove panel inside freezer on back side of freezer compartment and thaw it out with a hair dryer,then check the defrost heating element for continuity,if its open replace it,if its good, ,check the defrost control that powers the defrost heater
Jul 15, 2010 | Sub-Zero 611 / O Bottom Freezer...
Bosch KSU 40 fridge leaks water
I found that the entire defrost system had frozen over. to check the fridge for this problem you will need to:
pull out fridge, turn off power, remove cord (whilst at the back check the grills are clean, all dust in the cavity of the house and the condensor is clean and ensure that the 'travel wedge' has been removed from the engine.
remove food and shelves from freezer compartment.
with small (2.5mm wide) standard pop the three white screw covers up from the bottom tray. Undo the 2 philips head screws (with a 2 point screwdriver) Pull tray out. Lot of ice underneath? It's frozen over! you're going deeper!
Remove centre tower by squeezing the sides at the base near the rear wall. remove.
Chisel ice and remove, pour a little hot water down the two funnels at the rear.
To examine how fair the problem is and to let air to circulate you can remove the rear wall and polysterene insulation by removing the panel in the left upper portion with the 2.5mm screwdriver and removing the red, far right socket (this is the fan's point). Use 2 point and remove the 2 screws on the rear wall and remove, remove insulation. You're in.
Let completely defrost, clean up and dry all water and re-install.
Jul 02, 2009 | Refrigerators
Freezer not freezing properly, ice on back wall
Ice on the back wall indicates a problem with the defrost cycle. The ice builds up and starts to choke off the air flow, so your symptoms would indicate that may be happening.
Defrost problems are usually any of the three components, the heater element, the defrost termination temp switch, or the defrost timer.
May 29, 2009 | Amana ABB1927DE Bottom Freezer...
My freezer keeps icing up and my fridge won't get cool
The small cooling fan in the freezer compartment that sends chilled air to the food side is defective and needs replacement.  Sometimes that are only frozen stuck.
When you receive advice from this website you have to understand that without the item in front of us, we are only able to provide "a best guess" as to what the problem might be based on you description of the defect.  If you haven't described a clear and precise description of the defect you decrease the chances of an accurate reply.  Thank you.
Apr 29, 2009 | Haier HTE18WAA Top Freezer Refrigerator
Hoover HCA390FFK Bottom Freezer Refrigerator Logo
264 people viewed this question
Top Hoover Refrigerators Experts
Charles T Nevin
Charles T Nevin
Jim Goldsmith
Jim Goldsmith
JONFRIDGEDOC
Level 1 Expert
Are you a Hoover Refrigerator Expert? Answer questions, earn points and help others
