Question about Yamaha RX-V1500 Receiver
Yamaha rx-1500 av receiver
Subject will power up , but seconds later turns off. I tried disconnecting unit, still the same thing happens.
  • 2 more comments
  • unnyaa Jun 29, 2008
    I have the same power up, shuts itself down in about 3 seconds.
    I pulled all speaker wires, and it still shuts down.
    Unplugged the receiver power for an hour, no change.
    Changed the power source away from the monster power filter and directly into the wall, no change.
    I am glad I kept the trusty old 1973 Marantz around; plugged it in and it works fine for now.
  • Bob Gahlert Oct 15, 2008
    I also have the same problem with my 1500 but only in winter when the unit is started in a cold room. When I warm up the room it works fine.
  • Anonymous Oct 21, 2008
    Thanks for the advice.. mine has the same problem.
  • Anonymous Mar 15, 2014
    Yamaha rx v475 receiver will not power on
Some times the speaker cables are touching, double check, I had this with my amp and it kept turning itself off
Posted on Jun 25, 2008
  • 4,234 Answers
The unit is in protect mode. There is a problem with the last stage of the amplifier section and the unit shuts down to prevent further damage. The most common cause if this is shorted output transistors. If you are comfortable with soldering, you should be able to repair this. Check the transistors attached to the heatsink for a shorted condition. Replace them in pairs.
Keep us posted.
Dan
Posted on May 20, 2008
My Yamaha RX-673 not powering on. On standby mode
Have you tried switching the unit on with no cables or speakers connected and yes the unit can be repaired not problem.
Jun 15, 2016 | Yamaha Audio Players & Recorders
My yamaha rx-v473 wont turn on
disconnect all wires from behind unit, speakers, input, and then try to power it up ,
if problem persist then try to tighten screws on back panel of the unit,
may sound silly but if amp board does not have good ground connection it can do that , go in protect mode .
happened to me ...
Jan 26, 2013 | Yamaha RX-V473 A/V Receiver Black
Yamaha RX-V595 receiver won't stay on
check ur speaker wires, try disconnect all wires from back of unit and then try to turn on unit .
if it stays on whit no wires attached than u have short connection at speaker wires .
if doesn`t come on then try to fasten screws at back of the unit ,
may sound like BS but if amp board don`t have good ground connection it can go in protection mode happened to me on RX-V592
Dec 23, 2012 | Yamaha RX-V595 Receiver
RX-V665 turns on for a second then turns off
don`t open it yet
Dec 13, 2012 | Yamaha RX-V665 Receiver
How do I reset my yamaha rx-v671 receiver?
If there is no apparent cause for the protection mode activating (such as shorted speakers, burning smell, blown fuses, lighting strike or mains power surges), reset the protection as follows and see what happens.
Connect power cord to mains and wait 5 seconds or so. While holding down "info" and "tone control" buttons, press "main zone" power button briefly and release, but keep "info" and "tone control" buttons pressed for at least 3 more seconds. The unit should power up. Assuming the reason for the protection has passed or been fixed, the unit can now be turned off and then back on with the "main zone" power button to restore normal operation mode.
If the protector activates again, the fault is still present and the unit needs to be repaired, ideally by a Yamaha authorised repairer.
There are dangerous voltages present in high power amps and a lot of grunt in terms of stored energy - best left to trained technicians.
Apr 20, 2012 | Yamaha RX-V671 7.1 Channel AV Receiver
My Yamaha RX V461 receiver will not turn on. When pressing the ON/STBY button, I hear the familiar "click" when pressing the button and a second one about 1-2 seconds later that comes from the...
Your receiver probably went into protect mode because you were overloading the output stage with concert blast. In some units, protection consists of fuses that blow; in others protection is provided by thermal shutdown devices.
Mar 04, 2017 | Yamaha RX-V461 AV Receiver
Yamaha rx-v456 av receiver, shut down with optica cable
Does it work without PS3 attached?
When receiver turns off, it is usually due to badly connected/configured speakers. Try powering on the receiver without speakers.
Jan 06, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag.  press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
Jan 02, 2009 | Yamaha RX-V995 Receiver
Unit won't turn on.
My unit turned on and off a few seconds. I try several times and no lights. When disconnecting the power supply of A / C back and does the same.
Dec 29, 2007 | Yamaha RX-V657 Receiver
Yamaha RX-V2400
Get another receiver! I had the same problem and had the power supply replaced $250 and after 3 months it started doing the same thing.  I just purchased a Pinoeer Elite VSX 90TXV.
Jun 04, 2007 | Yamaha RX-V2600 Receiver
Yamaha RX-V1500 Receiver Logo
999 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
