Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
No Power Hi. My dishwasher wont start. I loaded it and cannot get any lights to light up on it. There is no power to it at all it seems. I tried flipping the breaker but there is still nothing. The door locks, so that shouldnt be the issue. Is there a way to reset the machine? What should I do?
I have the exact same problem with my Kenmore Type 575-0. It was working one daym it went into dry storage for a year and then when I took it out of storage it would not work. Ive already tested the thermal fuse and there is nothing wrong with that. So does anyone have any other suggestions please ??.
Posted on Aug 01, 2008
    Problem Solver:
  • 19 Answers
Your themal fuse needs replacing. you access the fuse by unsrewing the control panel then then removing the plastic cover that protects the power supply board. the fuse is the white piece that's located on your power supply board that has 2 wires connected to it. a black wire and a black wire with a white stipe.
Posted on Jun 10, 2008
Elctrolux dishwasher won't start, display won't light. Any suggestions?
Good Morning Friend,
I understand your Electrolux dishwasher, model# EWDW6505GS, seems like it is not receiving power to the control panel. I suggest resetting your appliance, by either unplugging your appliance or shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and try any cycle. If you are still not receiving any lights, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing your control panel to not have power.. Hope this is helpful.
-Best Regards-
WP
Jul 04, 2014 | Electrolux EWDW6505GS Fully Integrated...
Cancel Light Flashing on Kitchen Aid Dishwasher
I found this post elsewhere. It seems to have worked for me: Our KitchenAid KUDP series dishwasher went into a mode where it would not start and would only respond to the cancel/drain button. The clean light would flash 7 times in a row, stop, and then repeat. I read that the 7 flashes indicates an error code and that the dishwasher has detected a problem in the heater element circuit. I tried to reset the error mode by turning off power for 15 minutes, however, that did not work.
We called for a repair. The service person found that the dishwasher was completely fine except that it had gone into an error mode. The technician reset the error mode and charge us $115.00.
The reset sequence used was reported to be the following:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
We were told the dishwasher expects to see the dish water temperature rise in a certain way. If the water does not heat in this way, the dishwasher becomes confused and thinks the heater element has failed. In deed, this happened just following and extended power failure and our hot water tank was cool. I am curious if this code will work for anybody else with the same problem and save a service call and 115 bucks. Overall, this seems to be a serious logic flaw in the design.
Sep 21, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
DDW1802W ran fine yesterday. Panel light os, no start. Door seems to latch okay. It's not an overflow switch issue. No burnt smell.
dishwasher wont turn on. power is ok. when you turn the dial with the power switch on it clicks motor turn on pumps do not turn on wont fill or empty power light does nnot light up latch seems to be fastening proper is there a reset switch
Apr 09, 2011 | Danby 17 in. DDW1802W Designer Series...
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
Quick Rinse light was flashing at end of cycle. Opened and closed door and pushed Start. Quick Rinse and Cancel/Drain light are now flashing and machine won't start. Turned off power supply (30 seconds) /...
Ok try this, open the door and then hit these buttons in the following combination. HI TEMP - DRY - HI TEMP - DRY...then close door and press cancel...then wait for the pump to shut down. you should be able to run a cycle after this...If this fails to fix the problem give me the make and model # of the dishwasher, this can normally be found just inside the door.
Jun 22, 2009 | Dishwashers
Dishwasher wont run after pressing START ... green light blinks
NOT TOTALLY SURE ABOUT THIS MODEL, BUT IS THERE A "LOCK" BUTTON ON THE PANEL? ON SOME MODELS YOU NEED TO PRESS IT TWICE TO ENGAGE START. HOW OLD IS THE UNIT? HAVE SEEN THE INTERNAL TIMER RELAY MALFUNCTION ALSO AND IT WILL NOT ALLOW DISHWASHER TO START CYCLES. HOPE THIS HELPS
May 30, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Kenmore Model 587 -- Will not run - Power lights come on/wontrun
Hello I am V- Mari and i own a Kenmore dishwasher model Number 587.1574590 and it doesn't work at all. The power light comes on and it seems to make noise, but it does nothing. Is there a recall for these models or free fix help please respond to miss_vmari@netzero.net. I would like to solve my dishwasher problems as soon as possible. Thank you!
Dec 12, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Power Light Flashing - Machine wont Start - Whirlpool ADP5966
this is a fault code. it will flash so many times and then pause.
let me no how many flashes before the pause and i will tell you what fault code it is
Feb 21, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
FDW60
Tom, If your dishwasher is still under warranty, best thing will be to contact Hotpoint's service center for repair the problem.
Aug 29, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
318 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
