Question about Dell 5100cn Laser Printer
Dell 5100cn Laser printer with 016-370 restart printer
My printer wount take the download. it never changes to "writing" ,the control panel just stay's on waiting. Ive left it on all night and no changes.
Ive replace the controller (interface) board and the mother board it attaches to with only one change. it now reads 003-340 restart printer. any idea's.
  • solara7 Jun 18, 2008
    This is not a printer Driver issue. It's a Flash download issue. Flash Memory is the onboard program in the printer. This happens when I try to upgrade the onboard "Flash Memory" that I downloaded from the Dell site.
  • solara7 Dec 17, 2009
    No I'm talking about the Firmware upgrade availabe from the Dell site. I've tried everything including all the logic and power boards. It's sitting in the trash now.
What do you mean by "not take the download?" Are you trying to load the drivers from the Dell site and have the printer work? I ask because I could not get mine to work with just the drivers offered on the web site. I have to use the original install disk when loading to a machine using Windows XP SP2. Vista on the other hand started running with the downloaded drivers just fine. Have you used the install disk that came with the printer? I am on a home office network but had the same result when I ran a USB cable from my pc directly to the back of the 5100cn. The disk is the only way I can load it and I have had to do it several times over the years when changing the settings on the network. Hope this helps.
Posted on Jun 16, 2008
Dell 5100cn Error cod 010-397 Restart Printer
ahmad, does the printer show as default? if not make it. Try test print and make sure all printer compartment are securely closed.
Jan 11, 2014 | Dell 5100cn Laser Printer
Please can someone help me to get the service manual for the Dell laser 5100cn printer (.pdf) Thank you
The dell 5100cn is a rebranded Xerox Phaser 6300. You can buy the maintenance manual for under $4 on ebay. I did, and it was emailed to me as a pdf.
Apr 24, 2010 | Dell 5100cn Laser Printer
Dell 5100cn change ip address
Changing Printer's IP Address isn't that complicated. There are two ways on how to change the printer's IP Address.
If you know the old printer's IP address, you can simply type that old IP address on the Address Bar of your Internet Explorer or any other browser (ex: http://192.168.1.101). It should redirect you to the printer's User Interface. From there you can go to Network then TCP/IP settings. You can change the IP address of the printer. Make sure to use an IP address within the same range of your network.
The other way to change the printer's IP address is by its own Menu/Settings on the printer's LCD panel.
On your printer, press Menu then got Settings. Look for Network or LAN settings and click on Advance. Select TCP/IP and click on Edit. You can now change the IP address of the printer from there. Click on Done or Save after that.
Note: Make sure the use the correct IP address within the network's range.
Jul 16, 2009 | Dell 5100cn Laser Printer
Need IP address for Dell 5100cn printer
You will need to print off a printer settings page. Usually found under the Reports menu or something similar. It will list the IP address. Once you have the IP Address, make sure it is set correctly in your printer drivers in the Control Panel on your computer.
May 26, 2009 | Dell 5100cn Laser Printer
Problem code 094-911
hope this will help... look on google for a dell 5100cn user manual. there will be a pdf copy you can download. it may assist you in solving this. good luck. let me know if it works.
Jul 15, 2008 | Dell 5100cn Laser Printer
Dell 5100cn Laser Printer Multipurpose Feed Problem
I had the same problem, my solution was:
1) Go into the Print dialog window, select your 5100cn printer and click the "Properties" button next to it.
2) Select the second tab, labeled "Paper Tray".
3) Select "MPF" from the "Paper Source" drop-down list.
4) Click the "MPF Settings" button and select "Envelope".
That should allow your program to print to MPF for envelopes. This needs to be done in your software, setting it on the printer's control panel didn't work for me.
Dec 17, 2007 | Dell 5100cn Laser Printer
Error Message 016-370 restart computer
turn off the printer
1. Connect the printer through USB.
2. hold the enter button (the one in the middle of the circle) with the cancel button simultaneously
3. turn on the printer you will see the following message on the LCD screen
4. " download mode… ready"
5. Start the firmware update from the computer.
6. The LCD will change to "writing…"
7. After about 10 minutes it will prompt you to restart the printer.
Nov 27, 2007 | Dell 5100cn Laser Printer
Dell 5100cn Laser Printer Logo
654 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
