Question about Sony Handycam DCR-DVD201 DVD Camcorder
Sony camera adapter
I need to order a replacement adapter/battery charger for my sony DCR - DVD 201. I believe the part number is AC-VQ50.
  • 2,322 Answers
Click here to find the charger.
Posted on May 20, 2008
The ac power adaptor ac-v515 is dead.
I can't find the AC v515 adapter any where! But You can buy the next best thing. A battery charger one that will at least fit an NP-F730 battery. Go on to eBay and type Sony vc1000 and anything related will come up. These chargers can be used in your car and at home, what's more they are not expensive.
Nick
May 02, 2012 | Sony Handycam DCR-VX1000 Mini DV Digital...
I need a charger a/v out put and lanc all cables 4 use of sony modle number dcr-hc19e 7.2v how much 4 all the cables
Required info for Sony DCR-HC19E accessories are appended below.
AC-L AC Adapter, part number 147753411 available in Shopping.com
A/V connecting cable, part number 182315651 available in Shopping.com
USB cable, part number 182986831 available in Shopping.com
DV/ IEEE1394 4x4 cable available in Shopping.com
Click on above links for prices.
Let me know if you have additional question.
Thanks.
Aug 06, 2010 | Sony DCR-HC19E Mini DV Digital Camcorder
The dvd's that i create with my sony handycam DCR-DVD610 are not viewable from my dvd player only the camera what do i have to do to change this?
You need to Finalize recorded discs in camcorder as finalize option is available in camcorder menu.
make sure that camera gets power from ac adapter/ charger when finalizing disc. It wont finalize disc on battery.
Thanks.
Jun 03, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
How do i know if my battery or the charger is the problem causing my camera not to turn on
If the camera works when the AC adaptor is connected its the battery, if dosent work with the AC adaptor, its the AC adaptor.
Jan 22, 2010 | Sony DCR-DVD610 DVD Camcorder
Sony DCR- DVD108 switches off automatically while recording
Follow this procedure to troubleshoot if the camcorder turns off by itself.
  1. Remove the battery from the camcorder.
  2. Connect the AC power adapter to the camcorder.
  3. Plug the AC power adapter into a working electrical outlet.
  4. Attempt to turn on the camcorder.
  5. Reset the camcorder back to factory settings.
  6. NOTES:
    • If the camcorder does not operate using the AC adapter, service may be required .
    • If the camcorder does operate using the AC adapter, proceed with the steps below to troubleshoot the battery.
  7. Ensure the battery has been fully charged.
  8. Ensure the battery is properly inserted into the camcorder.
  9. Remove the AC power adapter from the camcorder.
  10. Attempt to turn on the camcorder.
  11. NOTES:
    • If the camcorder does not turn on, then the battery may need to be replaced.
    • If the problem persists using a different battery, service may be required .
Aug 13, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Lost my charger trying to figure out how charge?
You normally charge the battery directly with the adapter that came with the camera.
To order a spare battery and charger go to
http://www.eastcoastphoto.com/nav/bfinder.asp?category=Camcorders&manufacid=13&itemno=DCR-DVD610&trng=AW&gclid=CLLIxqXUn5wCFRlcagodrgjXeA
You may be able to order the lost direct charger from them also.
Please rate this solution. Thanks.
Aug 13, 2009 | Sony DCR-DVD610 DVD Camcorder
WERE TO FIND A BATTERY CHARGER FOR SONY DCR-TRVL140 NTSC
DCR-TRV140 requires ACL-15 AC Charger as shown in below image and its available in Sony Accessories Store under 147928313* ACL-15 AC ADAPTER part number for $56
Jun 04, 2009 | Sony Handycam DCR-TRV140 Digital Camcorder
Sony handycam just quit.. won't charge or work it just died no notice given.
Does it power up if connected with AC Power Adapter?
Have you tried extra AC Power Adapter or tested with another Sony Camera?
Let me know to guide you further.
Nov 08, 2008 | Sony Handycam DCR-DVD201 DVD Camcorder
DCR-SR42 Camcorder does not power up
I think AC power charger of your camera got defective first and later on battery lost its charge so no power for camera now to power up.
Try to borrow same charged battery from friend. neighbors etc and test your camera.
If camera power up, it is sure that charger has gone and you need new one.
let me know in that case to guide you further.
Oct 05, 2008 | Sony Handycam DCR-SR42 Camcorder
AC Power Adapter
Hi here is link where you can buy this ac adapter/charger for DCR-DVD108
http://azsurplus.com/index.php?main_page=product_info&cPath=1_85&products_id=1910
it is also works with more models as mentioned bellow
Compatible Part Numbers: AC-L20A, AC-L25A, AC-L25B, AC-L200
Input: AC 100V-240V 50/60Hz
Output: 8.4V 1.5A
Dimension Approximate: (48mm x 29mm x
To Use With :
CCD-TRV138
CCD-TRV338
DCR-DVD103
DCR-DVD105
DCR-DVD108
DCRDVD202E
DCR-DVD203
DCRDVD203E
DCR-DVD205
DCR-DVD305
DCR-DVD403
DCRDVD403E
DCR-DVD405
DCR-DVD505
DCR-DVD508
DCR-DVD7
DCR-DVD92
DCR-DVD92E
DCR-HC1000
DCR-HC1000E
DCR-HC16E
DCR-HC17E
DCR-HC18E
DCR-HC19E
DCR-HC20
DCR-HC20E
DCR-HC21
DCR-HC22E
DCR-HC26
DCR-HC28
DCR-HC30
DCR-HC30E
DCR-HC32
DCR-HC32E
DCR-HC36
DCR-HC39E
DCR-HC40
DCR-HC40E
DCR-HC42
DCR-HC42E
DCR-HC46
DCR-HC65
DCR-HC85
DCR-HC85E
DCR-HC90
DCR-HC90E
DCR-HC96
DCR-HE20E
DCR-HE22E
DCR-HE30E
DCR-HE32E
DCR-HE40E
DCR-HE65E
DCR-HE85E
DCR-IP1
DCR-IP1E
DCR-IP210E
DCR-IP220
DCR-IP220E
DCR-IP45E
DCR-IP5
DCR-IP55
DCR-IP55E
DCR-IP5E
DCR-IP7BT
DCR-IP7E
DCR-PC1000
DCR-PC106E
DCR-PC107E
DCR-PC108E
DCR-PC109
DCR-PC109E
DCR-PC350
DCR-PC350E
DCR-PC53E
DCR-PC55/B
DCR-PC55/R
DCR-PC55/S
DCR-PC55/W
DCR-PC55E
DCR-SR100
DCR-SR200
DCR-SR300
DCR-SR40
DCR-SR60
DCR-SR80
DCR-SR82
DCR-TRV280
DCR-TRV480
HDR-CX7
HDR-HC3
HDR-HC5
HDR-HC7
HDR-SR7
HDR-UX5
Jul 11, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
Sony Handycam DCR-DVD201 DVD Camcorder Logo
44 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
