Question about Sharp AL-1641CS All-In-One Laser Printer
No Copies My Sharp AL1641CS stopped making copies. The paper transports through the machine normally and no trouble lights are displayed anywhere. The copy is completely blank, not even a faint image. We changed the toner cartridge, no difference. Any ideas?
  • 3 Answers
It could possibly be your main charge assembly. If there is no charge on your drum, it can lead to blank copies.
Posted on Jun 27, 2008
Tip
Sharp AL Series Copier H3 H-3 code reset procedure
To reset the H3 condition on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
This works on the following models:
Sharp AL1000, Sharp AL1010, Sharp AL1020, Sharp AL1041, Sharp AL1200, Sharp AL1215, Sharp AL1220, Sharp AL1250, Sharp AL1251, Sharp AL1340, Sharp AL1451, Sharp AL1520, Sharp AL1521, Sharp AL1530CS, Sharp AL1540CS, Sharp AL1551, Sharp AL1551CS, Sharp AL1631, Sharp AL1641CS, Sharp AL1651, Sharp AL1651CS, Sharp AL1655CS, Sharp AL1661, Sharp AL1661CS
on Mar 20, 2010 | Office Equipment & Supplies
Tip
Sharp AL Series Copier H4 H-4 service code reset
To reset the H4 condition on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
on Jan 04, 2010 | Office Equipment & Supplies
Upon replacing the drum on my Sharp AL-1631, the drum indicator light is still illuminated and the copier still won't function. Is there something I need to do after replacing the drum to get it to copy...
To reset the drum light on your Sharp AL1631 series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone.
Good Luck and Thank You for using Fixya.
Sep 08, 2010 | Sharp AL 1631 Copier
Suddenly, there was a high tone pitch when I make copies...
TRY CLEANING AND LUBING THE SCANNER RAIL WITH A LIGHT GREASE.
Apr 28, 2010 | Sharp AR-M205 Copier
Tip
Sharp AL Series Copier Drum Light Cartridge Counter Reset
To reset the drum light on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Turn the machine off then on again and your drum light should be gone!
You can usually reset this counter at least once to get twice the life out of your drum unit.
This works in the following models:
Makes noise and will not copy
Check the scan head lock. It can easily be locked or unlocked. It is used to protect the moving parts inside the machine when it is moved/transported. Someone in our office was just making copies and ttapping their fingers on it and they locked it without even realizing it. it is under the top of the machine where the paper comes out. sometimes they are a slide or turn knob.
Dec 30, 2009 | Sharp AL-1655CS Copier
Reset drum counter on Sharp AL-1644
This works on MOST sharp AL series copiers.
Press these keys in sequence:
Clear → Density select → Clear→ Density select
display should go blank. Then enter:
24 as if you were making 24 copies then press print
then enter 7 as if you were making 7 copies then press print
if successful you should see flashing 000
turn machine off then on again and the drum light should be gone.
Good Luck
Nov 03, 2009 | Sharp Office Equipment & Supplies
Top load copies are blank
I tried changing the the size to a reduction. It took the sheet from the top and copied it at a reduced size with no problem. Then I switched back to normal size and it worked just fine. I would have never thought to try a different size without your suggestion. Thanks for the help
Randy
Jul 17, 2009 | Sharp Office Equipment & Supplies
Misfeed trouble with sharp ar-337
Dear sir;I suggest you go to simulation mode 30 & 40 to find out which sensor got problem procedure as follow;
1, press "program", "interupt" "clear", "interupt"
2, enter 30, press "start", enter 01, pres start again,then all the sensor light in the paper path are on the abnormal one blinking.
3, repeat same step for 30 sub 02 that's for paper path in the feed section.
4, repeat same step for simulation 40 sub code 01,that's for by-pass paper path sensor.
After you done those procedure you will find out which sensor block out or defect, good luck.
HAVE A HAPPY HOLIDAY !!!
Dec 11, 2008 | Sharp AL 1631 Copier
Sharp AL-1641CS All-In-One Laser Printer Logo
100 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
