Question about E-Machines (308714) Motherboard
L7vmm i have a l7vmm motherboard i need help with it 1st what kind of board is it and what power supply do i need and 2nd where can i find a step by step guide with pics to help me switch it out
    Sergeant:
    Champion:
  • 362 Answers
E machine uses FIC motherboards and you can get a manual from FICusually an atx 500 watt power supply will run any board
Posted on Dec 05, 2008
Schematic diagram for power supplys LG 60PC1D-AA
I do not have the schematic, but have a testing / troubleshooting guide for the 60PC1D 1st and 2nd generation, which gives some good insight in organization and functionality of the power boards.
This is what we ourselves step on when repairing - LG often does not publish schematics for power boards and sustain boards.
contact us if interested
Sep 30, 2012 | LG 60PC1D 60 in. Plasma Television
Tip
How to Reset Your BIOS
*Power down your PC.
*Remove the cabinet cover
*Find the 3-pin jumper near the power supply on the motherboard, typically labeled "clear cmos" or "reset bios".
*Remove the jumper from the default position (typically connecting the 1st and 2nd pins).
*Replace the jumper to connect the 2nd and 3rd pins.
*push the power button of ur pc once
*After a min Return the jumper to its default position, connecting the 1st and 2nd pins
* Turn on the PC now,
on Oct 25, 2010 | Computers & Internet
My problem with the Gigabyte GA-8I848P-G Motherboard is when i press the power button I do not hear the speaker beep I also do not see the display on my monitor screen after a few seconds my cpu is...
Hi, what you have not tested for isolation is your power supply, re-seating of processor for 20 minutes, cmos clearing or battery removal and mother board swapping. If all your isolation seems futile the worst is the mother board.
Jun 22, 2011 | Gigabyte GA-8I848P-G Motherboard
I cannot understand where to connect the speaker slot in my intel ZX-I945LM4 motherboard please help.....
Good day
you can find the sulotion in your motherboard manual.. what kind of speaker slot?
the speaker for mother board is 2pin
1st find the reset/led/on pin
2nd you can see the speaker slot..
May 24, 2011 | Intel Motherboard
HOW TO INSTALL MOTHER BOARD
These general instructions are intended to supplement or simplify some of the information in your motherboard manual Step 1 Make sure to read the manual that came with the motherboard - instructions differ for each one.
  • Step 2 Ground yourself with any professional grounding equipment you have. Otherwise, ground yourself by touching the computer power supply.
  • Step 3 Place motherboard on its anti-static bag.
  • Step 4 Configure motherboard: Set jumpers or DIP switches for CPU, voltage(s), and bus speed, if necessary. If your motherboard is configured by software, you will need to configure it after you complete the physical installation.
  • Step 5 Position motherboard in case. Line up holes in board with holes in case.
  • Step 6 Insert spacers, plastic stand-offs, washers and screws, as necessary. Tighten screws carefully, but securely.
  • Step 7 Make sure motherboard is not touching metal anywhere.
  • Step 8 Make sure slots and connectors fit into openings on back of case.
  • Step 9 Connect motherboard to power supply.
  • Step 10 Connect CPU fan, if you have one, to power supply.
  • Step 11 Connect reset and power switches to power supply.
  • Step 12 Connect LED indicators to power supply.
  • Step 13 Connect case speaker to motherboard.
  • Step 14 Check all connections.
  • Step 15 Test motherboard (and configure in CMOS if necessary) before installing other components of computer system.
  • TIPS AND WARNINGS
    • If possible, do installation in an uncarpeted area.
    • Be careful not to touch any chips. Handle board by its edges. Static damage (and even oil damage) may cause a failure months after the incident.
    • If you do not understand these instructions or you lack good manual dexterity, have a qualified technician install the motherboard for you
  • Mar 20, 2010 | Intel D946GZIS Motherboard
    L7vmm mb. display went out. Monitor works on
    Dear User. to plug in the AGP card you dont need to check or see the CMOS. if u have pluged an AGP card and problem still persist then the problem is at *********** side or in RAM. just plug out RAM and other hardware except Processor and cables of switches. the switch on it and if it gives beep then your motherboard and processor is OK. there would be problem in your RAM so change RAM. and if it dont give the beep at startup then the problem is in your motherboard or power supply.
    Apr 17, 2009 | Computers & Internet
    RE: Won't even start
    ouch that hurts well i wish you well hopefully u get a new board and get the computer up soon best regards mike
    Aug 07, 2008 | EliteGroup (L7VMM) Motherboard
    No power
    1st of all change ur power supply may be it is coz of it coz if da fan is not spining then i am sure there wud be sum problem of power supply n as u said it was returned n tested good by the owner then i am sure u mite have some problem in power suppy n i prescribe use some good quality of ram like kingston if ur a gaming freak!
    Nov 14, 2007 | Biostar P4VMA-M Motherboard
    ASRock K7VM3 2nd IDE won't detect any drives
    Go into the BIOS and make sure the 2nd IDE channel is enabled and set to auto detect.
    Feb 04, 2007 | Asrock K7VM3 Motherboard
    E-Machines (308714) Motherboard Logo
    179 people viewed this question
    Top E-Machines Computers & Internet Experts
    Alun Cox
    Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
