Question about Kenmore 77870 Top Freezer Refrigerator
Warm refirig compartment
Refrig compartment is warm but freezer is working fine
  • 770 Answers
Is there a heavy frost build up in the freezer section?? do you hear the fan running?
Posted on May 20, 2008
Emerson CR500: freezer is cold; refrig is not
If your refrigerator freezer compartment is cold, but the refrigerator compartment is warm--It could be a defrost system problem. When a defrost problem occurs, it is usually the fault of one or more of three basic parts: defrost timer/adaptive defrost control, freezer thermostat or the defrost heater element. See in detail how to dx and fix: Refrigerator Defrost Parts .
Aug 24, 2014 | Emerson Cr500 Refrigerators & Freezers
It is warm in the refrigerator and we have the control set on maximum cold
the damper vent door in between the freezer and refrige compartments isnt opening or the evaporator fan isn't operating as long as the freezer is ok,then this door is at the rear floor of the freezer and the roof of the refrige compartments and is behind a plastic grille remove this grille to see if door is frozen open or broken
Jun 01, 2011 | Kenmore Top Freezer Refrigerator
Refrigator side losing its cooling
Normally what causes the refrigerator not to be cold enough is that the fan that pulls the air from the freezer is not working. Check to make sure it is working, if not then you will have to replace it.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Please do not forget to rate me,
Thank You
May 25, 2010 | KitchenAid KSRP25FN Side by Side...
Kenmore refrig/freezer. freezer side is cold,
Check your condenser coil (should be below the refrig.). If dirty, you can clean it with a condenser brush from Home Depot or Lowe's. Turn the appliance off while cleaning. Be careful not to damage the refrigerant tubing (copper). If this doesn't solve the problem, then there may be an issue with the defrost thermostat, defrost heater(s) or the main temperature control assembly.
Contact an appliance service company.
Feb 17, 2010 | Kenmore Refrigerators
Fridge compartment of westinghouse bj433v-r is not refrigerating, freezer is refrigerating. The fridge fan is working.
The freezer control on most units is just a door that you open or close to let more or less air into refirig from freezer. The higher the setting, the less air to the frig side.
If frost build-up on freezer side, then you have a defrost problem. Too much frost build-up on evaporator is blocking air flow to refrig.
Nov 05, 2009 | Dryers
Frezer works fine (-5) on this gas refrige but refer is warm
How much are you willing to pay to find out how I fixed it?
_$14
_&28
_$42
Jul 09, 2009 | Dometic RM2193 Compact Refrigerator With...
Warm refrigerator compartment
There is a fan that blows the cold air down from the freezer to the fridge compartment. It is usually called a freezer fan. Most of them are behind the plastic lining in the freezer. I just noticed that your fridge is a side by side. I have never wored on a side by side but I imagine there is fan in them as well.
Jul 06, 2009 | GE GSH25KGRWW Side by Side Refrigerator
Freezer cold /refrigator warm . we have a side by side unit a couple of years old the freezer seems to work fine but the refrigator is warm .It don,t seem to make any funny noises and the back is clean
When the compressor is running, if the fan by the compressor and the fan inside the freezer are both running, and there is no frost on the back wall of the freezer (if there was frost would indicate a defrost issue) then check the air dampener. It is located at the very top left back side of the fresh food section. If it is not opening up, no air will flow from the freezer compartment (where all the cooling takes place) into the refrigerator section.
Jul 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
We had similar problem. Found the interior lights of refrig. were not turning off. Found out this was a recall problem and was fixed by sears for free.
Jun 21, 2009 | Kenmore 73503 Stainless Steel Bottom...
Freezer and fridge running too warm
sounds like you might have a bad compressor or the start components for the compressor is bad.
Apr 25, 2009 | Refrigerators
Kenmore 77870 Top Freezer Refrigerator Logo
110 people viewed this question
Top Kenmore Refrigerators Experts
John Tripp
John Tripp
minguy15
Level 1 Expert
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
