Question about HP Computers & Internet
What connection do i need to connect my dv6700 to my printer l7680
    Guru:
  • 1,342 Answers
You will need a USB cable.
Posted on May 20, 2008
I have an HP L7680 all in one printer/fax/copier. It prints just fine, it copies just fine, but INCOMING faxes do not print the entire page. What do I need to do?
first check all the connection to the printer check the phone line connected firmly on the printer then check for dial tone try to dial from the fax in the printer to any other number then return the call to the fax
Apr 01, 2011 | HP Officejet Pro L7680 All-In-One Printer
I connect to my HP Officejet Pro L7680 All-in-One Printer the wrong power supply and now dnt swicht on, in the back lights goes green but nothing happens. I have electronics knowledge to fix it but maybe i...
Hi live_intheda
I 'm not familiar with the device but isn't it just a question of replacing a burned fuse ?
Is the power transfo inside the unit or is it external together with the connecting power cable ?
Regards ,
fanaudi .
Mar 13, 2011 | HP Officejet Pro L7680 All-In-One Printer
Hp Pro L7680 not coming on
Check if you see any light glowing in the power adapter, that is connected to the printer . If there isn't , then probably you may change to a new power cord and adapter.
You can also try a different wall socket.
Even afte that if the problem persists , then it could be printer issue. it needs to be replaced.
Sep 07, 2010 | HP Officejet Pro L7680 All-In-One Printer
Hp l7680 won't power up.
Check it by connecting to a different wall socket and try to replace the power cord, if still the issue is same, the printer needs to be serviced .
Jun 21, 2010 | HP Officejet Pro L7680 All-In-One InkJet...
HP L7680 All-in-One will not scan or fax
connect the phone line in printer and set the parameter like auto answer and sending and receving mode also install the scanner driver .just reinstall the printer driver it will installl the missing components.
Dec 18, 2009 | HP Officejet Pro L7680 All-In-One Printer
I work in a office that we have to dial 9 then a phone number to get a outside line we have a hp L7680 when I got to use it it says busy then beeps but dosnet go through
You need to put a pause after the 9 to allow time for the line to connect. On some machines you press 9 and then a minus key or pound key a couple times to add the necessary time to connect, and then the rest of the number to dial.
Nov 03, 2009 | HP Officejet Pro L7680 InkJet Printer
CAN I CONNECT THE L7680 WIRELESS?
here r hp link u can try
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00909927&cc=us&lc=en&dlc=en&product=1156651
and second one is also
http://www.microsoft.com/athome/moredone/wirelesssetup.mspx
Jun 09, 2009 | HP Officejet Pro L7680 All-In-One Printer
Stopped printing from the net; all connections secure. Using Imac on Safari.
Try unluging the printer and plug it back in do the same with the eathernet cable. The make shure you have the right ip adress inputed into each computer for the port the computer uses to print to that printer this my cause you printer to not print.
May 03, 2009 | HP Officejet Pro L7680 All-In-One InkJet...
How to hook up this printer wireless to my main computer
We cannot connect the pro l7680 printer wirelessly. Connect the printer to the router via ethernet cable and connect the desktop to the router wirelessly.
May 24, 2008 | HP Officejet Pro L7680 All-In-One Printer
The scanner wouldn't work on a HP L7680 All In One Printer. I downloaded the newest Hp drivers. The scanner started working, but then I couldn't print from Quickbooks(bookkeeping). I uninstalled the...
Hi ,
go to printers in the control pannel.
click on add a printer
in the wizard click on local printer but un check search for the connected printer, under ports check the usb virtual port on which the printer is connected .. under drivers choose HP as manifacturer and under drivers use DESKJET 550C in case of windows XP or DESKJET 990C in case of vista operating system .. try to print is should print .. issue resolved on near about 100 cases
wishing u good luck
Mar 08, 2008 | HP Officejet Pro L7680 All-In-One Printer
Computers & Internet Logo
13 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
