Question about Whirlpool RBD305PD Electric Double Oven
Upper oven locked and control panel is not working
Our oven is three years old. My wife used the self-cleaning feature on the oven. After it finished, the upper oven never unlocked and the control panel went off.
  • Anonymous Nov 26, 2008
    During self cleaning oven went off the top locked down and the panel wont come on
  • Anonymous Mar 27, 2014
    how long does it take
First off this oven sucks. Now to fix the problem replace the Fuse assembly with #4451042 an $11.00 part. SHUT OFF THE POWER AT THE BRAKER PANEL FIRST. Then open the lower oven door and remove the two small screws that hold the side trim pieces, slide them up a bit to remove. At the top of the track remove two more small screws that hold the display panel in-place and lift the cover up and away from the oven. The fuse is inside of a clear plastic tube with a female spade connector at each end of it. replace the failed part and put things back the way that they came off. Next time don't by a Whirlpool.
Posted on Jul 09, 2008
  • Margaret
    Margaret Dec 02, 2013
    Ours is a single oven mounted in the base cabinets. How can we access the screws to pull it out of the cabinet when it it died in door lock mode?
Unlock oven door on model #FGGS3065PF
If the oven display is showing LOC, then the lockout feature was enabled. Press and hold the key pad with the padlock symbol for 3+ seconds. This is just below the Timer On/Off key pad and to the right of the Light key pad. You should see the word DOOR and the padlock icon flash until the door is unlocked and the control panel is released.
If the word DOOR and the padlock icon are lit, then the oven is in the self-clean mode. The lock should release after you cancel the self-cleaning cycle by pressing off and the oven cools down (at least one hour). Unfortunately, sometimes the heat of the self-clean cycle will damage the oven. Either the oven temperature sensor will not give the release signal or the door lock will not disengage. In that case, the oven needs to have the correct part serviced.
The documentation for the Frigidaire FGGS3065PF is available on the product page at Home Depot: https://www.homedepot.com/p/Frigidaire-Gallery-30-in-4-5-cu-ft-Slide-In-Gas-Range-with-Self-Cleaning-Convection-Oven-in-Stainless-FGGS3065PF/204759413 . See page 15 for the Oven Lockout feature. See page 28 for the self-cleaning information.
I hope this helps.
Feb 13, 2018 | Ovens
How to operate the self-cleaning feature?
Remove the racks and go for it. What it does is locks the oven and superheats the oven space which turns any grease or splashes to ash. When the cycle is finished, the door will unlock.
Dec 26, 2015 | Ovens
I have Whirlpool double oven, model number gbd307pdb7, that after the self clean on the top oven quit working. The original message on the key pas was locked, then it said hot and lastly it had the error...
this most likely happened from when you self cleaned the oven,the oven gets up to 1000 degrees and can damage the electronics on the oven.i will never use this feature for this reason,i use easy off,but the f2 e1 error says it's a bad key panel or the touch pad that you push to control the oven.do you see upper and lower off?if you want to cancel the upper oven you press upper off,you can try to unplug the oven for like 10 minutes and see if it resets it or kill the power,pull the oven out enough to remove the top panel,unplug the ribbon and plug it back in and see if it resets,that code means the board can't read the touch panel,if you press the upper off and it clears and then returns the touch pad is bad part WP8300440 go here go to control panel
https://www.searspartsdirect.com/model-number/GBD307PDB7/1198/0125300.html?searchType=modelSearch&q=gbd307pdb7&searchTerm=gbd307pdb7
Sep 28, 2017 | Whirlpool Ovens
Double oven no model number Whirlpool 14 years old Door is locked after self clean and display is blank
Your oven has resetable high limit thermostat that tripped off on the self clean cycle,im not sure if you have free standing,or a wall oven if freestanding the t-stat is on back panel if wall oven its behind control panel on upper oven and for lower oven its behind the grill between bottom of upper oven and top of lower oven. In either case it has a small red button that can be pushed in to reset it
Hope this helps and if it does please give me 4 thumbs up
Gene
Jul 28, 2011 | Whirlpool Ovens
Have a Kenmore Elite Built-In oven 790.4812. It's a double oven. Was working fine. 1 year old. Wife self-cleaned upper oven for first time. Oven does not work now. Sears Repair guessing that the oven...
It has nothing to do with the tight fit.
It has everything to do with self-cleaning on ovens.
The thermal fuse blows due to extreme temperatures.
Replace the fuse to use the oven.
Use an oven cleaner to clean the oven OR replace more fuses in the future.
Jul 25, 2011 | Ovens
Gerangeoven door won't open
Is it in time bake?
Oct 04, 2009 | GE Ovens
I am in the process of cleaning my Whirlpool self cleaning oven and it seems like there should be about 2 hours left on the timer and when I came out to the kitchen the timer was off and the door is still...
most likely the safety latch got stuck from the super heat of the oven while cleaning. try tapping the latch with a screwdriver and hammer, spray a bit of wd-40 on it wont hurt. i believe the self cleaning on ovens is crazy, as the heat damages things, including the finish of the unit.
Jun 22, 2009 | Whirlpool RBS275PD Electric Single Oven
Old Amana - no manual; can't operate self clean feature
Can you locate the model number on the oven? Also any particular name of the stove? The manufactured year. These should all be available on a stainless steel or aluminum attached plate , probably on the back of the stove or inside the door.
I wouldn't try using the self cleaning feature until we get some advice. it could lock up on you and not UNLOCK. Normally self cleaning takes place at 600 or more degrees .
I'm sure others still have the same stove., I will see what I can find for you.
Aug 21, 2008 | Amana AEW4530DDS Electric Single Oven
Bottom oven not working
It is quite possible the control electronics have failed. There are separate relays for the upper and lower ovens. Ours recently failed the upper oven with the same symptoms and it was the electronic control. The other part is the overheat thermal sensor for the oven may be out.
Aug 01, 2008 | Whirlpool GBD307PRS Stainless Steel...
Whirlpool RBD305PD Electric Double Oven Logo
198 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
