Question about Microsoft Xbox 360 Console
Xbox 360 overheating
My xbox 360 will only open for 7 seconds and then the 2 red lights will appear > and I don't know what to do I have tried everything possible > PLEASE HELP ME>>>>>>>>>>>>>>>>>>>
  • ANTWILLDO May 20, 2008
    JUST HAPPENED TO ME TODAY....BEST THING TO DO IS CRY LIKE A SISSY. SEND IT BACK SERIOUSLY
  • Anonymous May 21, 2008
    yea same thing happened here. Where do i send it back to?
2 red light and overheats shutting off in about ten minutes.
Posted on Jun 30, 2008
CRY AND CRY HARD...MY 360 JUST DID THE SAME THING, WANNA CRY TOGETHER? I HAVE THE TISSUE IF YOU HAVE THE SHOULDER.
Posted on May 20, 2008
What would cause a 2 ring malfunction?
2 red lights is overheating, try giving it a dust out and if this does not work you will need to stop the heat build up inside.
To do this you can send it in or use a good Xbox 360 Repair guide to fix it.
2 red lights is purely overheating.
Feb 22, 2010 | Microsoft Xbox 360 Console
Xbox360 show 2 rings
2 rings means overheat
leave it in a cold place for some hours and it should be ok
Oct 21, 2009 | Microsoft Xbox 360 Console
My xbox360 will not stop flashing red
Sorry, only answer is to phone xbox and arrange to have repaired. Good news is its all free and should be back with you in 2 weeks.
Sep 20, 2009 | Microsoft Xbox 360 Console
2 red flashing lights
The Xbox console is overheated.
  1. Let your Xbox 360 console cool. You may have to wait several hours for your console to cool enough. Don't turn on your Xbox 360 console when the console is hot.
  2. Verify that your Xbox 360 console has enough ventilation and that the fans are operating.
  3. If the two lights continue to flash red after you try steps 1 and 2, contact Xbox Customer Support.
To try to prevent this problem, follow these precautions:
  • Don't block any ventilation openings on your Xbox 360 console.
  • Don't put your Xbox 360 console on a bed, on a sofa, on a carpet floor, or on any other soft surface that may block ventilation openings.
  • Don't put your Xbox 360 console in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well ventilated.
  • Don't put your Xbox 360 console near any heat source, such as a radiator, a heat register, a stove, or an amplifier.
Taken from Microsoft support.
Best of Luck.
-Mind
Jun 30, 2009 | Microsoft Xbox 360 Console
Xbox 360
It's overheating. Consider buying an external cooler at a local Target or Best Buy.
Jun 08, 2009 | Microsoft Xbox 360 Console
Laser is not reading disc says "open tray" after 2 sec. xbox 360
my xbox 360 elite has 2 red lights, which im led to believe is over heating, but it had only run for 15 seconds so cant of overheated so whats the problem? regards paul.
Jan 16, 2009 | Microsoft Xbox 360 Console
I have 2 red rings on my xbox 360 but i dont understand what they mean...
The 2 flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. The main thing that causes the 2 red lights to start flashing is because of overheating and as the motherboard within the console takes more heat it actually warps and bends until the solders become loose.
Once this happens you will receive the 2 red lights. Even before you get the 2 red lights you may have noticed your games freezing and this is caused in the same way, by overheating. As the chips take more heat they shut off to prevent lasting damage, although they can only do this a number of times until you get the Xbox 360 2 Red Lights.
To fix the problem you need to stop the level of heat the motherboard takes and you can do this in a number of ways, but it will involve opening up your Xbox and working on it. In addition, you could always send your Xbox back to Microsoft as they are offering free repair for this error, you will just need to wait 3-4 weeks that's all.
There is one more option available in the form of DIY Video Guide, that will explain you step by step approach to fix red ring of death within one hour without any technical knowledge.
Jan 13, 2009 | Microsoft Xbox 360 Console
2 red rings of light appear on my 360 every time I turn it on. I am aware this is an overheating problem but what should I do to stop it?
THINGS TO TRY loadTOCNode(1, 'whattotry'); 1. Let your Xbox 360 console cool. You may have to wait several hours for your Xbox 360 console to cool enough. Don't turn on your Xbox 360 console when the console is hot. 2. Verify that your Xbox 360 console has enough ventilation and that the fans are operating. For more information about ventilation, see the "More Information" section. 3. If the two lights continue to flash red after you try steps 1 and 2, contact Xbox Customer Support. For more information about how to contact Xbox Customer Support, please visit the Xbox Support (http://www.xbox.com/support/) Web site. uparrow.gifBack to the top
MORE INFORMATION loadTOCNode(1, 'moreinformation'); To try to prevent this problem, use the following precautions: • Don't block any ventilation openings on your Xbox 360 console. • Don't put your Xbox 360 console on a bed, on a sofa, on a carpet floor, or on any other soft surface that may block ventilation openings. • Don't put your Xbox 360 console in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well ventilated. • Don't put your Xbox 360 console near any heat source, such as a radiator, a heat register, a stove, or an amplifier. If these solutions do not work for you, best to contact Xbox support at http://xbox.agent.asahost.com/ to talk to a live agent. :)
Sep 05, 2008 | Microsoft Xbox 360 Console
Xbox 360 two red lights
The fan sounds like it is malfunctioning. Two red lights mean the 360 is overheating. I suggest you don't turn on the 360 until you get the fan replaced as this may damage your 360 more and lead to more problems with the motherboard. If its under warranty then you should get it fixed for free but if not then you might have to pay.
Aug 17, 2008 | Microsoft Xbox 360 Console
As playing Xbox 360 system shuts off two red lights occurs.
Two red lights mean your 360 is over exceeding the inside temperature. Your fan must not be working at all and your 360 is overheating tremendously. That is what I know about the 2 red lights. Im not sure what to tell you to fix this but to just call 18004myxbox.
Mar 01, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
65 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
