Question about HP Officejet 4315v All-In-One InkJet Printer
Fax problem I am faxing for the first time, I have a HP officejet 4315v all in one system. I do not have the book on hand and was wondering if anyone could walk me through the process
  • sambo24 Jun 17, 2008
    When the fax is plugged in, I can't send or recieve any faxes. Plus my telephone won't work. When trying to call it, it gives me a bussy signal. It's like its allways off the hook. What can I do to fix this?
I am having a problem receiving faxs, please help.
Posted on May 28, 2008
HP Officejet 4622 after installing I only see the printer on fax not under the printer list
you may have to reinstall printer from cd. Both Printer and fax should show. check settings on printer for functions.
Nov 06, 2013 | HP Officejet 4315v All-In-One InkJet...
Connecting my HP Officejet 4315v All-in-One Printer.Fax.Scanner.Copier with a phone modem in order to use the fax machine
The power cable goes in the socket on the far left. The phone line goes into the port named 1-LINE and runs to the wall. 2-EXT is for you to connect you phone or fax machine if you so wish.
If it is your first time installing the printer I would take a moment to go through the setup as mentioned in the manual here. It seem the USB port should be connected at a specific point during installation.
Hope this helps.
Sep 14, 2012 | HP Officejet 4315v All-In-One InkJet...
I disconnected the hp officejet all-in-one from my computer and later reconnected it. Now it thinks its a fax machine, and won't print from the computer.
it (Hp officejet 4315v series FAX) must be set to default that's why it would not print.The default printer should be the Hp officejet 4315v series,the one without the word fax in the end.
Here's how you do it:
for windows XP operating system
  1. click on the start button on your computer.
  2. click on printers and faxes.If it is not on the start-up list you can click on control panel ,click on printers and faxes or printers and other hardware.
  3. in printers and faxes,it will display all the printers installed on your computer
  4. look for officejet 4315v series or officejet 4300v series then right-click on it's printer icon then left- click on set as default.
  5. try printing from the computer.
for windows vista operating system
  1. click on the start button on the computer
  2. in the search box,type in printers,hit enter key on the keyboard.
  3. in printers,it will display all the printers installed on your computer
If it does not print download the print diagnostic utility from the hp website.It is a helpful tool in diagnosing printing problems.I will provide you the link.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-91793-1&lc=en&dlc=en&cc=us&os=228&product=1138346&sw_lang=
Jul 09, 2011 | HP Officejet 4315v All-In-One InkJet...
Hello all I have a hp 4315v all in one printer /fax and i would like to see if the fax is working is there a test number i can use to test it out with
HP has a Fax no. to test.
Send any test page as fax on the 1-888-473-2963 and wait till it is send. Once the fax is sent, you will receive a fax as notification ( confirmation ) of the fax being received by HP.
This above no. sometimes is busy so you may need to give couple of tries till you succeed.
Or the best way is to send fax to any of your friend who owns a fax machine and ask them to send fax back to you.
Regards,
Ron
Mar 07, 2011 | HP OfficeJet 4315V All-in-One Printer
4315v Officejet all in one not faxing
Perhaps it is not connected to the phone line? Maybe you don't have a fax number set up? If your phone is having issues, it will affect this.
Apr 20, 2010 | HP Officejet 4315v All-In-One InkJet...
Hp4300 series disc won't work with my new hp window vista computer my printer is a 4315v
Please perform the steps given below and check if yuo are able to fax
1. Open a MS Word Document.
2. Click File -> Send to -> Recipient using a fax modem.
3. Follow the instructions given in the fax wizard. Ensure that you select the HP all-in-one as the fax program.
Now check whether you are able to send the fax.
OR
Try setting up the Fax once again
=== Fax Setup wizard ===
- Double-click on the HP Solution Center to open it.
- Go to Settings --> Fax Settings & Setup --> Fax Setup Wizard.
Complete the fax setup wizard and then, try to fax
Vishwanath V U
May 19, 2009 | HP Officejet 4315v All-In-One InkJet...
My HP 4315v won't fax or receive faxes. What can I do?
printer said check manual, cartridge problem. i also tried to fax, would not let me.
May 01, 2009 | HP Officejet 4315v All-In-One InkJet...
HP Officejet 4315v All-in-One turns off automatically. I turn it on and it stays on just a few moments to tell me my ink is low. Then it turns off. I moved the printer yesterday and it worked at the place...
IT SOUND LIKE IT SETUP TO ANSWER A FAX MACHINE MODE.
I WOULD GO ONLINE AND TYPE THE FOLLOWING INFORMATION :
HP OFFICEJET 4315V TURNS OFF AUTOMATICALLY
ENTER
SEE IF ANYONE ELSE HAD THIS PROBLEM AND MAYBE HOW TO SOLVE IT OR IF IT IS A RECALL OR MFG ERROR.
Mar 27, 2009 | HP Officejet 4315v All-In-One InkJet...
HP Officejet 4315v Error Code 344*
1. issue may be with telephone line conditions,  try sending a fax at a different time 2. Disable Error Correction Mode 3. reduce thefax speed 4. try a fax test to  hp at 1888 473 2963
Jan 26, 2009 | HP Officejet 4315v All-In-One InkJet...
Hp officejet 4315v all in one
my printer was unpluged. i put it back, now my printer will not work,help
Apr 01, 2008 | Office Equipment & Supplies
HP Officejet 4315v All-In-One InkJet Printer Logo
85 people viewed this question
Seeker5211
Seeker5211
